What is the theoretically highest possible: 1. Frequency Response (range of frequencies) 2. SNR 3. Dynamic Range 4. SPL 5. Musical Pitch (highest acceptable frequency) of PCM audio?
Theoretically Highest Quality of PCM Audio
Started by ●November 9, 2003
Reply by ●November 9, 20032003-11-09
On Sun, 09 Nov 2003 14:45:19 -0800, Radium wrote:> What is the theoretically highest possible:Based on what theory? Based on what PCM audio? Red Book? DVD-A? Some arbitrary, non-standard interconnect? The main system bus of a computer that processes said PCM audio? Since one can (and does) use PCM at all levels and scales of physical analysis (electron microscopy, earthquake analysis, radar, etc), then the limitations are going to come from what you define to be "audio", in the context of "PCM audio". Once you define your terms, the answers to all of your questions can be simply derived.> 1. Frequency Response (range of frequencies) > > 2. SNR > > 3. Dynamic Range > > 4. SPL > > 5. Musical Pitch (highest acceptable frequency) > > of PCM audio?-- Andrew
Radium wrote:> > What is the theoretically highest possible: > > 1. Frequency Response (range of frequencies) > > 2. SNR > > 3. Dynamic Range > > 4. SPL > > 5. Musical Pitch (highest acceptable frequency) > > of PCM audio?Google up "Shannon Theorem". -- Les Cargill
In article 3FAED264.DC692FE1@worldnet.att.net, Les Cargill at lcargill@worldnet.att.net wrote on 11/09/2003 18:47:> Radium wrote: >> >> What is the theoretically highest possible: >> >> 1. Frequency Response (range of frequencies)DC to just under 1/2 of the sampling frequency (what we normally call the "Nyquist Frequency").>> 2. SNR >> >> 3. Dynamic Rangedepends on what kind of "S" that is being compared to what kind of "N". if the assumption is that S and N have the same kind of qualitative statistics (say, both having uniform p.d.f.), then the SNR in dB + dB of headroom (which is what i would normally think is dB of dynamic range) is 6.02 dB per bit of PCM word width.>> 4. SPLdepends on how high you crank up your volume knob. has nothing to do with PCM or whatever else the audio is.>> 5. Musical Pitch (highest acceptable frequency)theoretically, just below the Nyquist frequency divided by the index of the highest harmonic of the musical note.>> of PCM audio? > > Google up "Shannon Theorem".good advice, Les. also maybe Google "Shannon Information Theory" to get the low-down on bits vs. dB. r b-j
Andrew Reilly <andrew@gurney.reilly.home> wrote in message news:<pan.2003.11.09.23.10.59.63234@gurney.reilly.home>...> On Sun, 09 Nov 2003 14:45:19 -0800, Radium wrote: > > > What is the theoretically highest possible: > > Based on what theory? Based on what PCM audio? Red Book? DVD-A? > Some arbitrary, non-standard interconnect? The main system bus of a > computer that processes said PCM audio? > > Since one can (and does) use PCM at all levels and scales of physical > analysis (electron microscopy, earthquake analysis, radar, etc), then the > limitations are going to come from what you define to be "audio", in the > context of "PCM audio". > > Once you define your terms, the answers to all of your questions can be > simply derived.Sorry, but he DID define his terms. "PCM audio," meaning "pulse code modulation audio" is sufficiently unambiguous to answer his question. We don't have to know DVD, red book or anything else.> > 1. Frequency Response (range of frequencies)The maximum bandwidth possible without the introduction of unwanted artifacts must be less than 1/2 the sampling rate.> > 2. SNR > > 3. Dynamic RangeThe two are equivalent when the signal is the maximum undistorted signal the medium can accept. In such a case, the dynamic range, as defined as the ratio between the smallest unmabiguously encodable sample measured over the bandwidth of the system and the maximum undistorted signal is approximately 6.02 dB per bit.> > 4. SPLSorry, SPL is irrelevant, because it includes factors not relevant to the PCM process, such as amplifier gain, loudspeaker efficiency, distance from the speaker, and any other factors that has nothing to do with "PCM"> > 5. Musical Pitch (highest acceptable frequency)Sorry, but this is a case where your use of the terminology is murky. "pitch" is defined as the psychoacoustic perception as it relates to the frequency of a tone. As to the highest possible frequency, assuming base-band usage, is simply less than 1/2 the sampling rate.
Andrew Reilly <andrew@gurney.reilly.home> wrote in message news:<pan.2003.11.09.23.10.59.63234@gurney.reilly.home>...> On Sun, 09 Nov 2003 14:45:19 -0800, Radium wrote: > > > What is the theoretically highest possible: > > Based on what theory?Sampling rate = 2(highest frequency) Bit resolution = dynamic range/2 bytes per second = information per time The high sample rate and bit resolution the better the audio quality. The shortest amount of time is 10^-43 second. What is the maximum # of bits that can squeezed into this sml amt of time?
dpierce@cartchunk.org (Dick Pierce) writes:> Andrew Reilly <andrew@gurney.reilly.home> wrote in message news:<pan.2003.11.09.23.10.59.63234@gurney.reilly.home>... > > On Sun, 09 Nov 2003 14:45:19 -0800, Radium wrote: > > > > > What is the theoretically highest possible: > > > > Based on what theory? Based on what PCM audio? Red Book? DVD-A? > > Some arbitrary, non-standard interconnect? The main system bus of a > > computer that processes said PCM audio? > > > > Since one can (and does) use PCM at all levels and scales of physical > > analysis (electron microscopy, earthquake analysis, radar, etc), then the > > limitations are going to come from what you define to be "audio", in the > > context of "PCM audio". > > > > Once you define your terms, the answers to all of your questions can be > > simply derived. > > Sorry, but he DID define his terms. "PCM audio," meaning "pulse > code modulation audio" is sufficiently unambiguous to answer > his question. We don't have to know DVD, red book or anything > else. > > > > 1. Frequency Response (range of frequencies) > > The maximum bandwidth possible without the introduction of > unwanted artifacts must be less than 1/2 the sampling rate.He doesn't seem to have defined it well enough for you to give him a precise answer.> > > 2. SNR > > > 3. Dynamic Range > > The two are equivalent when the signal is the maximum undistorted > signal the medium can accept. In such a case, the dynamic range, > as defined as the ratio between the smallest unmabiguously encodable > sample measured over the bandwidth of the system and the maximum > undistorted signal is approximately 6.02 dB per bit.Again, you appear to have to infer definitions, so perhaps the original poster was not precise enough.> > > 4. SPL > > Sorry, SPL is irrelevant, because it includes factors not relevant > to the PCM process, such as amplifier gain, loudspeaker efficiency, > distance from the speaker, and any other factors that has nothing > to do with "PCM" > > > > 5. Musical Pitch (highest acceptable frequency) > > Sorry, but this is a case where your use of the terminology is murky. > "pitch" is defined as the psychoacoustic perception as it relates > to the frequency of a tone. As to the highest possible frequency, > assuming base-band usage, is simply less than 1/2 the sampling rate.-- Peter J. Kootsookos "I will ignore all ideas for new works [..], the invention of which has reached its limits and for whose improvement I see no further hope." - Julius Frontinus, c. AD 84
Reply by ●November 10, 20032003-11-10
On 9 Nov 2003 13:45:19 -0800, glucegen@excite.com (Radium) wrote:>What is the theoretically highest possible: > >1. Frequency Response (range of frequencies) > >2. SNR > >3. Dynamic Range > >4. SPL > >5. Musical Pitch (highest acceptable frequency) > >of PCM audio?There are no inherent limits, the current state of the art is 24/192. This gives theoretical limits of 141dB SNR, which is the same as dynamic range, and 0.0001Hz to 95kHz frequency response, with 95kHz of course being the upper limit. -- Stewart Pinkerton | Music is Art - Audio is Engineering
glucegen@excite.com (Radium) wrote in message news:<464c821f.0311091945.178c4a2d@posting.google.com>...> Andrew Reilly <andrew@gurney.reilly.home> wrote in message news:<pan.2003.11.09.23.10.59.63234@gurney.reilly.home>... > > On Sun, 09 Nov 2003 14:45:19 -0800, Radium wrote: > > > > > What is the theoretically highest possible: > > > > Based on what theory? > > Sampling rate = 2(highest frequency)Fine, you just answered your own question.> Bit resolution = dynamic range/2Wrong. number of bits required to represent a dynamic range of x dB is about x/6.02.> bytes per second = information per time > The high sample rate and bit resolution the better the audio quality.Not so, you just stated so yourself. Once you have exceeded the requirements for dynamic range and bandwidth, NO increease in sampling rate or bits will give you any better resolution.> The shortest amount of time is 10^-43 second. What is the maximum # of > bits that can squeezed into this sml amt of time?Are you REALLY serious or are you just a troll?
"Radium" <glucegen@excite.com> wrote in message news:464c821f.0311091345.2c2c1f12@posting.google.com> What is the theoretically highest possible: > > 1. Frequency Response (range of frequencies)unlimited. You got the bits...> 2. SNRunlimited. You got the bits...> 3. Dynamic Rangeunlimited. You got the bits...> 4. SPLunlimited but irrlevant. You got the bits...> 5. Musical Pitch (highest acceptable frequency)unlimited> of PCM audio?
