eric.jacobsen@ieee.org (Eric Jacobsen) wrote in message news:<41646340.847462937@news.west.cox.net>...> On Tue, 5 Oct 2004 22:46:15 +0200, "Rob Vermeulen" > <rpvermeulen@tiscali-antispam-.nl> wrote: > > >Every time I think I've invented something, it already has a name and was > >invented 10 decades ago :-) > > I think Phase Locked Loops have a few thousand "original" inventors. > ;) > > On the other hand, I've been impressed with the ability of people to > occassionally still come up with really new and cool things. Burt > Rutan recently showed that it's not all that tough to get into space > if you think outside the box just a little bit. Prior to this who > would have thought that you could re-enter the atmosphere without heat > shielding? > > The field of error correction coding has seen some pretty interesting > advances in the last twelve years, but then somebody figured out that > Gallager got _really_ close to figuring out the same things more than > forty years ago. There are, however, still some interesting advances > being made in this area. > > There's cool stuff going on, but sometimes it is in an area so > esoteric and isolated that nobody hears about it. Medicine, > biometrics, genetics, etc., are still very ripe for cool new things. > > Anyway, some areas of DSP do seem to be becoming fairly mature, but > that doesn't mean it's not still challenging, fun, and interesting to > those of us wired up strangely enough to be so inclined. > > ;) > > > Eric Jacobsen > Minister of Algorithms, Intel Corp. > My opinions may not be Intel's opinions. > http://www.ericjacobsen.orgHi, THis thread is going haywire. First 4-5 threads discussions were in the path. Later it went to oigin of Maths and what not. Pls do not use this thread to say how much you know abt other things. Since there are many DSP gurus, they can pitch in & answer to the qn. Thanks Sandeep
Why Side Lobes appear in magnitude response?
Started by ●September 29, 2004
Reply by ●October 8, 20042004-10-08
Sandeep Chikkerur wrote:> Hi, > > THis thread is going haywire. > First 4-5 threads discussions were in the path. > Later it went to oigin of Maths and what not. > Pls do not use this thread to say how much you know abt other > things. > > Since there are many DSP gurus, they can pitch in & answer to the > qn. > > Thanks > Sandeep >Hi Sandeep, I certainly understand what you're telling. Nevertheless, I sometimes enjoy the meanders some people go. It's important not to forget that life is more than mere DSP work. And it's good to know that other people here, especially the so-called gurus, have a life beyond their professional skills. But sometimes, I don't like these off-topics, or they go into a direction, which I don't want to follow. For these cases, my news reader has an "ignore feature", which I use to hide such far-off-topic discussions. That's my recommendation: just ignore what's not of interest for you, but don't try to stop it in general, because others might like it. Be tolerant. Naturally, one of the reasons why I read this group is, because I sometimes need help for an issue, and sometimes may be able to provide some help myself. But another reason is that there are such off-topic-discussions and that nobody of the others does complain. Having said this, be assured that I highly appreciate your contributions in this group, and this one, too. Bernhard
Jerry Avins <jya@ieee.org> wrote in message news:<2sl5qeF1mkg95U1@uni-berlin.de>...> Rune Allnor wrote: > > ... > > > I know, I know. Sure, there are new and exciting thoughts around. > > One usually doesn't recognize them as "new and exciting" (i.e. "unique > > in the history of mankind" sort of thing) until long after they were > > formulated and only when one sees them in context. > > ... > > I just didn't want you sitting around feeling sorry for yourself. The > problem is an old one. See the sig as evidence.I'm not feeling sorry for myself. As far as I can see, there is a lot at risk for both research and engineering. I think that the main problem in research and engineering in the future, will be to detect those few grains of coherent thoughts that exist in vast research literature, that already is on a downwards slope and will degenrerate very quickly in the near future. People want their PhD diplomas. To get them, they have to come up with something "new and exciting" in the first place, and then get it published in the journals. The journals are already under pressure to shorten review times and speed up publication rates. If that pressure persists (which I think it will) the end result will be that we have journals filled with incohesive, unintelligable garbage, and have a bunch of mediocre pompous wind-bags around whos job it is to think "new and exciting" thoughts. I've mentioned it before, PhD degrees should only be awarded to those whose ideas actually survive close scrutiny and the test of time, and that in *hindsight* turned out to make a contribution. Letting ~30-year-olds get the PhD degree is just ridiculous, unless they are at the level of a Gauss, a Newton or an Einstein. Such people exist, but not quite as many as the number of PhD diplomas that are granted every year. Rune
It is appropriate (but seldom done) to change the subject line when a thread deviates from the original topic. The abbreviation OT is commonly used to indicate "off topic" posts. This makes it easier to ignore the OT bits if one desires to do so. "Bernhard Holzmayer" <holzmayer.bernhard@deadspam.com> wrote in message news:1182571.cx2lYyeFIE@holzmayer.ifr.rt...> Sandeep Chikkerur wrote: > > > Hi, > > > > THis thread is going haywire. > > First 4-5 threads discussions were in the path. > > Later it went to oigin of Maths and what not. > > Pls do not use this thread to say how much you know abt other > > things. > > > > Since there are many DSP gurus, they can pitch in & answer to the > > qn. > > I certainly understand what you're telling. > Nevertheless, I sometimes enjoy the meanders some people go. > It's important not to forget that life is more than mere DSP work. > And it's good to know that other people here, especially the > so-called gurus, have a life beyond their professional skills.True, but the purpose of this particular newsgroup is to discuss DSP skills, not the other interests of people in DSP. Obviously there is some flexibility, but just because several DSP people in this group like baseball, that doesn't mean it is appropriate to have long discussions about the baseball playoffs in this group.> But sometimes, I don't like these off-topics, or they go into a > direction, which I don't want to follow. > For these cases, my news reader has an "ignore feature", which I use > to hide such far-off-topic discussions. > > That's my recommendation: just ignore what's not of interest for > you, but don't try to stop it in general, because others might like > it. Be tolerant. > > Naturally, one of the reasons why I read this group is, because I > sometimes need help for an issue, and sometimes may be able to > provide some help myself. > But another reason is that there are such off-topic-discussions and > that nobody of the others does complain.Often ironically, the OT posts generate the most contributions!
Jon Harris wrote: ...> Often ironically, the OT posts generate the most contributions!"All work and no play makes Jack a dull boy." Jerry -- When a discovery is new, people say, "It isn't true." When it becomes demonstrably true, they say, "It isn't useful." Later, when its utility is evident, they say, "So what? It's old." a paraphrase of William James ���������������������������������������������������������������������
"Jerry Avins" <jya@ieee.org> wrote in message news:2so22gF1nm5grU2@uni-berlin.de...> Jon Harris wrote: > > > Often ironically, the OT posts generate the most contributions! > > "All work and no play makes Jack a dull boy."In addition, the OT threads generally are matters of opinion rather than facts/questions. Everyone seems to have an opinion, whereas maybe only a few may know the answer to a specific question.
Jon Harris wrote:> "Jerry Avins" <jya@ieee.org> wrote in message > news:2so22gF1nm5grU2@uni-berlin.de...>>Jon Harris wrote:>>>Often ironically, the OT posts generate the most contributions!>>"All work and no play makes Jack a dull boy."> In addition, the OT threads generally are matters of opinion> rather than facts/questions. Everyone seems to have an > opinion, whereas maybe only a few may know the answer to > a specific question. Well, that is your opinion! All my OT posts are factual and answer a specific question. Now, what was the question? -- glen
Hi Rune. I think the question here is what do we mean by Ph.D., or, what is the purpose of Ph.D. studies? In Denmark we have the dr.scient. or dr.techn. for what you describe. It is kind of an achievement award, what you would get after perhaps 20 years of ground breaking research. You probably have the same in Norway. The Ph.D. in Denmark is a fairly new thing. Until the 80s you couldn't really get a Ph.D. in Denmark. Until then, the highest academic degree among associate professors at universities was a masters' degree and the dr. degree for the exceptional ones. Now, the Ph.D. in denmark is an "educational" degree, which you are awarded after some years as a "research apprentice". Probably, the long term goal is to have higher education levels for people who are going to get the positions at the universities and raise the level in industi as well. Rune> People want their PhD diplomas. To get them, they have to come Rune> up with something "new and exciting" in the first place, and Rune> then get it published in the journals. The journals are already Rune> under pressure to shorten review times and speed up publication Rune> rates. If that pressure persists (which I think it will) the end Rune> result will be that we have journals filled with incohesive, Rune> unintelligable garbage, and have a bunch of mediocre pompous Rune> wind-bags around whos job it is to think "new and exciting" Rune> thoughts. I've mentioned it before, PhD degrees should only be Rune> awarded to those whose ideas actually survive close scrutiny and Rune> the test of time, and that in *hindsight* turned out to make a Rune> contribution. Letting ~30-year-olds get the PhD degree is just Rune> ridiculous, unless they are at the level of a Gauss, a Newton or Rune> an Einstein. Such people exist, but not quite as many as the Rune> number of PhD diplomas that are granted every year. -- /Mads (http://kom.auc.dk/~mgc)
Reply by ●October 9, 20042004-10-09
christensen@nospam.ieee.org (Mads G. Christensen) wrote in message news:<usm8oor7r.fsf@nospam.ieee.org>...> Hi Rune. > > I think the question here is what do we mean by Ph.D., or, what is the > purpose of Ph.D. studies? In Denmark we have the dr.scient. or > dr.techn. for what you describe. It is kind of an achievement award, > what you would get after perhaps 20 years of ground breaking > research. You probably have the same in Norway.That's right, we do.> The Ph.D. in Denmark > is a fairly new thing. Until the 80s you couldn't really get a > Ph.D. in Denmark.Well, the exact label "PhD" is very new in the Norwegian academic system. I have occationally seen the "PhD" be used for "Dr.Philos.", but in general, it is used as the English label for any doctor degree, except possibly for the "Dr.Med.". My for mal degree is "doctor ingeni�r" or Dr.Ing. ("ingeni�r" pronounced as the French "ingenieur").> Until then, the highest academic degree among > associate professors at universities was a masters' degree and the > dr. degree for the exceptional ones.That's how it should be. The problem is that the "image" of the "old-style" PhD persist, so that people (and worse, the PhD themselves) think the PhD degree is awarded for exceptional performance. When people with mediocre skills and knowledge get an excuse to inflate their self-image (and worse, get into positions of power), the game is no fun anymore.> Now, the Ph.D. in denmark is an > "educational" degree, which you are awarded after some years as a > "research apprentice".I have been in universities and research institutions for the past 15 years, and have yet to see the distinction between "Dr. Ing." (the "educational" degree I have) and the "Dr. Tech.", which is the achievement award. Oh, that's not quite true: I saw the specific mentioning of the Dr. Tech. in the papers when I applied to be accepted at the Dr.Ing. programme. The only people who ever make the distinction, are at the Degree Awarding Committee. The way the programme is implemented here, is that anyone who gets salaries over university budgets can get the degree. There are some pro forma requirements on grades and courses taken during the scholarship period, but I have never heard of anybody who entered the programme that havs been kicked out on the grounds of mediocre preformance. People have left on their own initiative or have not been able to finish within the limits of time and money (which, I guess, is "mediocre" in some sense), but no one have ever been kicked out because of "mediocre research performance". Which, in my view, is an indication that anything goes. Which, in turn, undermines both the academic degree system and also the universities themselves.> Probably, the long term goal is to have higher > education levels for people who are going to get the positions at the > universities and raise the level in industi as well.I don't know. Norway has consistently ended last on the OECD statistics when it comes to per-capita spendings on R&D. The long-term political goal on R&D is to "approach the OECD average of per-capita R&D spendings". That goal can be achieved in two ways: A) Spend more money on R&D in universities, to increase activity in R&D related fields B) Expand the "R&D label" in ways that let more of the current activity already being carried out, be counted as "R&D activities". Letting engineers get PhD degrees is one means to achieve this goal (ref. approach B). Certain recent political moves to increase the number of universities in Norway (there are four, nation-wide, the last established in 1968) without making moves to establish a significantly higher academic level in the institutes that are elevated to university status, are also consistent with approach B. Rune> Rune> People want their PhD diplomas. To get them, they have to come > Rune> up with something "new and exciting" in the first place, and > Rune> then get it published in the journals. The journals are already > Rune> under pressure to shorten review times and speed up publication > Rune> rates. If that pressure persists (which I think it will) the end > Rune> result will be that we have journals filled with incohesive, > Rune> unintelligable garbage, and have a bunch of mediocre pompous > Rune> wind-bags around whos job it is to think "new and exciting" > Rune> thoughts. I've mentioned it before, PhD degrees should only be > Rune> awarded to those whose ideas actually survive close scrutiny and > Rune> the test of time, and that in *hindsight* turned out to make a > Rune> contribution. Letting ~30-year-olds get the PhD degree is just > Rune> ridiculous, unless they are at the level of a Gauss, a Newton or > Rune> an Einstein. Such people exist, but not quite as many as the > Rune> number of PhD diplomas that are granted every year.
