What kind of analog-to-digital converters are used in cell phones?
Started by Jerry ●February 1, 2013
What kind of analog-to-digital converters are used for the VOICE signal in cell phones...
Number of bits?
Sampling rate?
Architecture?
What kind of analog-to-digital converters are used for the RADIO signal in cell phones...
Number of bits?
Sampling rate?
Architecture?
What kind of analog-to-digital converters are used for the ACCELEROMETER ETC. signal in cell phones...
Number of bits?
Sampling rate?
Architecture?
Jerry
Voice is all sigma-delta types, sampling rates are programmable from 8k to 48K or more, 16 bits or more output, all highly integrated with other functions
Bob
On Friday, 1 February 2013 04:09:10 UTC, Jerry  wrote:
> What kind of analog-to-digital converters are used for the VOICE signal in cell phones... > > Number of bits? > > Sampling rate? > > Architecture? > > > > What kind of analog-to-digital converters are used for the RADIO signal in cell phones... > > Number of bits? > > Sampling rate? > > Architecture? > > > > What kind of analog-to-digital converters are used for the ACCELEROMETER ETC. signal in cell phones... > > Number of bits? > > Sampling rate? > > Architecture? > > > > Jerry
It is not always clear what components are used in mobile phones, but the Samsung Galaxy SII, and the S4 in the UK, I think use the Wolfson Microelectronics WM1181 audio codec hub: http://www.wolfsonmicro.com/documents/uploads/product_briefs/en/WM1811A_ProductBrief.pdf which has 24-bit oversampling ADC and DAC. As Bob said, these devioces now tend to be highly integrated (mixers, EQ, filters, sample rate conversion) and are also typically mixed-signal (analog on the same chip, including Class D power amplifiers). The Galaxy S4 in the USA I think uses the Qualcomm WCD9310 audio codec, with which I am not familiar. Chris ==================== Chris Bore BORES Signal Processing www.bores.com chris@bores.com http://blog.bores.com/ LinkedIn.com/pub/chris-bore/0/612/521
On Jan 31, 11:09&#4294967295;pm, Jerry <lancebo...@qwest.net> wrote:
> What kind of analog-to-digital converters are used for the VOICE signal in cell phones... > Number of bits? > Sampling rate? > Architecture? > > What kind of analog-to-digital converters are used for the RADIO signal in cell phones... > Number of bits? > Sampling rate? > Architecture? > > What kind of analog-to-digital converters are used for the ACCELEROMETER ETC. signal in cell phones... > Number of bits? > Sampling rate? > Architecture? > > Jerry
Are you trying to understand the architectures or trying to ultimately implement real hardware? If you are trying to implement real hardware what are you thinking of doing?
On Thu, 31 Jan 2013 20:09:10 -0800 (PST), Jerry <lanceboyle@qwest.net>
wrote:
>What kind of analog-to-digital converters are used for the VOICE signal in cell phones... >Number of bits? >Sampling rate? >Architecture? > >What kind of analog-to-digital converters are used for the RADIO signal in cell phones... >Number of bits? >Sampling rate? >Architecture? > >What kind of analog-to-digital converters are used for the ACCELEROMETER ETC. signal in cell phones... >Number of bits? >Sampling rate? >Architecture? > >Jerry
Which cell phone? There are many different standards and implementations. There's not a single answer to any of those questions, I think, and many implementations are highly integrated and highly proprietary. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
"Jerry" <lanceboyle@qwest.net> wrote in message
news:bc0efc73-56ec-4943-a6ca-6ce90527e55f@googlegroups.com...
> What kind of analog-to-digital converters are used for the VOICE signal in > cell phones... > Number of bits? > Sampling rate? > Architecture?
Typical audio CODEC, ENOB ~ 14, Fsa = 8...48kHz, Delta-sigma
> What kind of analog-to-digital converters are used for the ACCELEROMETER > ETC. signal in cell phones... > Number of bits? > Sampling rate? > Architecture?
Typical MCU ADC. ENOB ~ 10, Fsa ~ kHz area, Capacitive SAR.
> What kind of analog-to-digital converters are used for the RADIO signal in > cell phones... > Number of bits? > Sampling rate? > Architecture?
For GSM, they used Delta/Sigma, 270kHz, ENOB ~ 10. It would be interesting to know what is actually ised on the handset side for high speed standards such as LTE. Vladimir Vassilevsky DSP and Mixed Signal Consultant www.abvolt.com
On Thursday, January 31, 2013 9:38:50 PM UTC-7, radam...@gmail.com wrote:
> Voice is all sigma-delta types, sampling rates are programmable from 8k to 48K or more, 16 bits or more output, all highly integrated with other functions > > Bob
What do you suppose is the (worst case) latency of a ADC-DAC combination of these converters? Jerry
On Friday, February 1, 2013 3:18:46 AM UTC-7, Chris Bore wrote:
> On Friday, 1 February 2013 04:09:10 UTC, Jerry wrote: > > It is not always clear what components are used in mobile phones, but the Samsung Galaxy SII, and the S4 in the UK, I think use the Wolfson Microelectronics WM1181 audio codec hub: > > http://www.wolfsonmicro.com/documents/uploads/product_briefs/en/WM1811A_ProductBrief.pdf > > which has 24-bit oversampling ADC and DAC. As Bob said, these devioces now tend to be highly integrated (mixers, EQ, filters, sample rate conversion) and are also typically mixed-signal (analog on the same chip, including Class D power amplifiers). > > The Galaxy S4 in the USA I think uses the Qualcomm WCD9310 audio codec, with which I am not familiar.
> Chris >
Thanks, Chris. Good stuff. A data sheet on the Qualcomm device seems a little hard to come by, but presumably it is similar to the Wolfson part. Jerry
On Friday, February 1, 2013 5:43:26 AM UTC-7, brent wrote:
> Are you trying to understand the architectures or trying to ultimately > implement real hardware? If you are trying to implement real hardware > what are you thinking of doing?
Both. I wish I could say more. :-/ Jerry
On Friday, February 1, 2013 4:28:48 PM UTC-7, Eric Jacobsen wrote:
> On Thu, 31 Jan 2013 20:09:10 -0800 (PST), Jerry > Which cell phone? There are many different standards and > implementations. There's not a single answer to any of those > questions, I think, and many implementations are highly integrated and > highly proprietary. > > Eric Jacobsen >
Just looking for ranges of parameters, typical parameters, or even specific examples. Jerry
