On Friday, February 1, 2013 4:48:56 PM UTC-7, Vladimir Vassilevsky wrote:> "Jerry" wrote in message > > news:bc0efc73-56ec-4943-a6ca-6ce90527e55f@googlegroups.com... > > > What kind of analog-to-digital converters are used for the VOICE signal in > > cell phones... > > Number of bits? > > Sampling rate? > > Architecture? > > Typical audio CODEC, ENOB ~ 14, Fsa = 8...48kHz, Delta-sigma > > > What kind of analog-to-digital converters are used for the ACCELEROMETER > > ETC. signal in cell phones... > > Number of bits? > > Sampling rate? > > Architecture? > > Typical MCU ADC. ENOB ~ 10, Fsa ~ kHz area, Capacitive SAR. > > > What kind of analog-to-digital converters are used for the RADIO signal in > > cell phones... > > Number of bits? > > Sampling rate? > > Architecture? > > For GSM, they used Delta/Sigma, 270kHz, ENOB ~ 10. > It would be interesting to know what is actually ised on the handset side > for high speed standards such as LTE.Do recent phones use software-defined radios? I believe that implies sampling at IF. I suppose cell, Bluetooth, GPS all operate as separate radios--but is it possible that even these are integrated somehow? Jerry Jerry> Vladimir Vassilevsky > DSP and Mixed Signal Consultant > www.abvolt.com
What kind of analog-to-digital converters are used in cell phones?
Started by ●February 1, 2013
Reply by ●February 2, 20132013-02-02
On Sat, 2 Feb 2013 16:53:16 -0800 (PST), Jerry <lanceboyle@qwest.net> wrote:>On Friday, February 1, 2013 4:48:56 PM UTC-7, Vladimir Vassilevsky wrote: >> "Jerry" wrote in message >> >> news:bc0efc73-56ec-4943-a6ca-6ce90527e55f@googlegroups.com... >> >> > What kind of analog-to-digital converters are used for the VOICE signal in >> > cell phones... >> > Number of bits? >> > Sampling rate? >> > Architecture? >> >> Typical audio CODEC, ENOB ~ 14, Fsa = 8...48kHz, Delta-sigma >> >> > What kind of analog-to-digital converters are used for the ACCELEROMETER >> > ETC. signal in cell phones... >> > Number of bits? >> > Sampling rate? >> > Architecture? >> >> Typical MCU ADC. ENOB ~ 10, Fsa ~ kHz area, Capacitive SAR. >> >> > What kind of analog-to-digital converters are used for the RADIO signal in >> > cell phones... >> > Number of bits? >> > Sampling rate? >> > Architecture? >> >> For GSM, they used Delta/Sigma, 270kHz, ENOB ~ 10. >> It would be interesting to know what is actually ised on the handset side >> for high speed standards such as LTE. > >Do recent phones use software-defined radios? I believe that implies sampling at IF. I suppose cell, Bluetooth, GPS all operate as separate radios--but is it possible that even these are integrated somehow? > >Jerry >Generally not, because an SDR consumes a LOT more power than a dedicated silicon modem/transceiver, and this is crucial in a handset. This is also why the sort of info you're asking about is hard to come by, as that silicon isn't generally mass marketed so datasheets aren't common. The vendors know who their customers are, and generally talk directly to the design centers. Once in a while somebody does a tear-down and publishes what they find, but even then it can be hard to identify what's going on. You can be sure that the number of bits and the conversion rates are as low as practical, though. How low that is just depends on a lot of other things, unfortunately. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
On Sat, 2 Feb 2013 16:53:16 -0800 (PST), Jerry <lanceboyle@qwest.net> wrote:>On Friday, February 1, 2013 4:48:56 PM UTC-7, Vladimir Vassilevsky wrote: >> "Jerry" wrote in message >> >> news:bc0efc73-56ec-4943-a6ca-6ce90527e55f@googlegroups.com... >> >> > What kind of analog-to-digital converters are used for the VOICE signal in >> > cell phones... >> > Number of bits? >> > Sampling rate? >> > Architecture? >> >> Typical audio CODEC, ENOB ~ 14, Fsa = 8...48kHz, Delta-sigma >> >> > What kind of analog-to-digital converters are used for the ACCELEROMETER >> > ETC. signal in cell phones... >> > Number of bits? >> > Sampling rate? >> > Architecture? >> >> Typical MCU ADC. ENOB ~ 10, Fsa ~ kHz area, Capacitive SAR. >> >> > What kind of analog-to-digital converters are used for the RADIO signal in >> > cell phones... >> > Number of bits? >> > Sampling rate? >> > Architecture? >> >> For GSM, they used Delta/Sigma, 270kHz, ENOB ~ 10. >> It would be interesting to know what is actually ised on the handset side >> for high speed standards such as LTE. > >Do recent phones use software-defined radios? I believe that implies sampling at IF. I suppose cell, Bluetooth, GPS all operate as separate radios--but is it possible that even these are integrated somehow? > >JerryJerry, Just to answer again a little bit better, here are two links to teardowns of competing smart phones, the iPhone 5 and a Galaxy S3: http://www.ifixit.com/Teardown/iPhone+5+Teardown/10525/3 http://www.eetimes.com/design/communications-design/4401948/Galaxy-teardown-reveals-Samsung-modem You can see in each that the level of integration is quite high, but still partitioned among functional lines. Often the partitions are due to different technology requirements or complexity limits that prevent higher levels of integration. e.g., the transceiver chips can't tolerate the noise from a lot of digital processing on the same die, the PAs are often different technology, e.g., GaAs compared to the Si processors, etc., etc. Often the partitions are along expertise barriers as well, since essentially no vendors are completely on top of their game on all of the required technologies and functions. If you push down and follow the trails for the parts, even with the part numbers and manufacturer names in hand, it is often difficult to find out details of the architectures inside the various parts, especially when it comes to something like the number of bits, sample rates, etc. For this application there is so much money at stake and the product shelf lives are so short that anything beyond the interface specs are very often kept proprietary. If you can even get the interface specs. You'll note that separate ADCs or DACs don't exist for any of the functions you mentioned you were looking for. They're all integrated into the various parts listed. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
Reply by ●February 3, 20132013-02-03
Latency for adc + dac is on the order of 500us to 1.5 ms at 48k sample-rate. But the filtering can be either FIR or IIR, it varies from part to part, so if its IIR you have to rely on the group delay curve, if published. Also the sample-rate can vary depending on the use case. Bob
On 3.2.13 2:53 , Jerry wrote:> > Do recent phones use software-defined radios? I believe that implies sampling at IF. I suppose cell, Bluetooth, GPS all operate as separate radios--but is it possible that even these are integrated somehow? > > JerryAt least the established cell phone companies have plenty of patents along those lines, both SDR and zero-IF. Before doing anything drastic, please wade through the patent of at least Qualcomm, Nokia, Apple and Samsung. -- Tauno Voipio
Reply by ●February 4, 20132013-02-04
On Sun, 03 Feb 2013 03:11:00 GMT, eric.jacobsen@ieee.org (Eric Jacobsen) wrote:>On Sat, 2 Feb 2013 16:53:16 -0800 (PST), Jerry <lanceboyle@qwest.net> >wrote: > >>On Friday, February 1, 2013 4:48:56 PM UTC-7, Vladimir Vassilevsky wrote: >>> "Jerry" wrote in message >>> >>> news:bc0efc73-56ec-4943-a6ca-6ce90527e55f@googlegroups.com... >>> >>> > What kind of analog-to-digital converters are used for the VOICE signal in >>> > cell phones... >>> > Number of bits? >>> > Sampling rate? >>> > Architecture? >>> >>> Typical audio CODEC, ENOB ~ 14, Fsa = 8...48kHz, Delta-sigma >>> >>> > What kind of analog-to-digital converters are used for the ACCELEROMETER >>> > ETC. signal in cell phones... >>> > Number of bits? >>> > Sampling rate? >>> > Architecture? >>> >>> Typical MCU ADC. ENOB ~ 10, Fsa ~ kHz area, Capacitive SAR.And as I suspected and Eric wrote below, the accelerometer has a built-in ADC and communicates through SPI or I2C. From the ifixit link: STMicroelectronics LIS331DLH (2233/DSH/GFGHA) ultra low-power, high performance, three-axis linear accelerometer Googling the data sheet: http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00213470.pdf finds a 12-bit internal ADC indirectly documented on page 9. Apparently there's no analog I/O on these things except where absolutely needed, as on the mic, antenna, and battery voltage and current. It's cheaper to have any analog value converted on-chip I've seen a tiny MEMS microphone in some new product announcement blurb, but I don't recall the interface method. I'm guessing it also has an internal ADC and an I2C interface. Scratch out mic in the above paragraph.>>> >>> > What kind of analog-to-digital converters are used for the RADIO signal in >>> > cell phones... >>> > Number of bits? >>> > Sampling rate? >>> > Architecture? >>> >>> For GSM, they used Delta/Sigma, 270kHz, ENOB ~ 10. >>> It would be interesting to know what is actually ised on the handset side >>> for high speed standards such as LTE. >> >>Do recent phones use software-defined radios? I believe that implies sampling at IF. I suppose cell, Bluetooth, GPS all operate as separate radios--but is it possible that even these are integrated somehow? >> >>Jerry > >Jerry, > >Just to answer again a little bit better, here are two links to >teardowns of competing smart phones, the iPhone 5 and a Galaxy S3: > >http://www.ifixit.com/Teardown/iPhone+5+Teardown/10525/3 > >http://www.eetimes.com/design/communications-design/4401948/Galaxy-teardown-reveals-Samsung-modem > >You can see in each that the level of integration is quite high, but >still partitioned among functional lines. Often the partitions are >due to different technology requirements or complexity limits that >prevent higher levels of integration. e.g., the transceiver chips >can't tolerate the noise from a lot of digital processing on the same >die, the PAs are often different technology, e.g., GaAs compared to >the Si processors, etc., etc. Often the partitions are along >expertise barriers as well, since essentially no vendors are >completely on top of their game on all of the required technologies >and functions. > >If you push down and follow the trails for the parts, even with the >part numbers and manufacturer names in hand, it is often difficult to >find out details of the architectures inside the various parts, >especially when it comes to something like the number of bits, sample >rates, etc. For this application there is so much money at stake and >the product shelf lives are so short that anything beyond the >interface specs are very often kept proprietary. If you can even get >the interface specs. > >You'll note that separate ADCs or DACs don't exist for any of the >functions you mentioned you were looking for. They're all integrated >into the various parts listed. > > >Eric Jacobsen >Anchor Hill Communications >http://www.anchorhill.com
Woops, that was an incomplete post. What I meant to say was: On Sun, 03 Feb 2013 03:11:00 GMT, eric.jacobsen@ieee.org (Eric Jacobsen) wrote:>On Sat, 2 Feb 2013 16:53:16 -0800 (PST), Jerry <lanceboyle@qwest.net> >wrote: > >>On Friday, February 1, 2013 4:48:56 PM UTC-7, Vladimir Vassilevsky wrote: >>> "Jerry" wrote in message >>> >>> news:bc0efc73-56ec-4943-a6ca-6ce90527e55f@googlegroups.com... >>> >>> > What kind of analog-to-digital converters are used for the VOICE signal in >>> > cell phones... >>> > Number of bits? >>> > Sampling rate? >>> > Architecture? >>> >>> Typical audio CODEC, ENOB ~ 14, Fsa = 8...48kHz, Delta-sigma >>> >>> > What kind of analog-to-digital converters are used for the ACCELEROMETER >>> > ETC. signal in cell phones... >>> > Number of bits? >>> > Sampling rate? >>> > Architecture? >>> >>> Typical MCU ADC. ENOB ~ 10, Fsa ~ kHz area, Capacitive SAR.And as I suspected and Eric wrote below about all ADCs being internal, the accelerometer has a built-in ADC and communicates through SPI or I2C. From the ifixit link: STMicroelectronics LIS331DLH (2233/DSH/GFGHA) ultra low-power, high performance, three-axis linear accelerometer Googling the data sheet: http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00213470.pdf finds a 12-bit internal ADC indirectly documented on page 9. Apparently there's no external analog signal going to any of these chips except where absolutely needed, as on the mic, antenna, and nonitoring battery voltage and current. It's easier and cheaper for each chip to have its own ADC, and move the data elsewhere with a digital protocol. I noticed a few years ago that analog-output 3-axis accelerometers were being replaced with ones with internal ADCs and digital interfaces. I've seen a tiny MEMS microphone in some new product announcement blurb, but I don't recall the interface method. As it's on a chip, I presume it also has an internal ADC and an I2C interface. Scratch out mic in the above paragraph.>>> >>> > What kind of analog-to-digital converters are used for the RADIO signal in >>> > cell phones... >>> > Number of bits? >>> > Sampling rate? >>> > Architecture? >>> >>> For GSM, they used Delta/Sigma, 270kHz, ENOB ~ 10. >>> It would be interesting to know what is actually ised on the handset side >>> for high speed standards such as LTE. >> >>Do recent phones use software-defined radios? I believe that implies sampling at IF. I suppose cell, Bluetooth, GPS all operate as separate radios--but is it possible that even these are integrated somehow? >> >>Jerry > >Jerry, > >Just to answer again a little bit better, here are two links to >teardowns of competing smart phones, the iPhone 5 and a Galaxy S3: > >http://www.ifixit.com/Teardown/iPhone+5+Teardown/10525/3 > >http://www.eetimes.com/design/communications-design/4401948/Galaxy-teardown-reveals-Samsung-modem>... >You'll note that separate ADCs or DACs don't exist for any of the >functions you mentioned you were looking for. They're all integrated >into the various parts listed. > > >Eric Jacobsen >Anchor Hill Communications >http://www.anchorhill.com
On 4.2.13 4:55 , Ben Bradley wrote:> > I've seen a tiny MEMS microphone in some new product announcement > blurb, but I don't recall the interface method. As it's on a chip, I > presume it also has an internal ADC and an I2C interface. Scratch out > mic in the above paragraph. > >> >> Eric Jacobsen >> Anchor Hill Communications >> http://www.anchorhill.com >How about MP45DT02 from STM? -- Tauno Voipio
On Mon, 04 Feb 2013 09:36:57 -0500, Ben Bradley wrote:> On Sun, 03 Feb 2013 03:11:00 GMT, eric.jacobsen@ieee.org (Eric Jacobsen) > wrote: > >>On Sat, 2 Feb 2013 16:53:16 -0800 (PST), Jerry <lanceboyle@qwest.net> >>wrote: >> >>>On Friday, February 1, 2013 4:48:56 PM UTC-7, Vladimir Vassilevsky >>>wrote: >>>> "Jerry" wrote in message >>>> >>>> news:bc0efc73-56ec-4943-a6ca-6ce90527e55f@googlegroups.com... >>>> >>>> > What kind of analog-to-digital converters are used for the VOICE >>>> > signal in cell phones... >>>> > Number of bits? >>>> > Sampling rate? >>>> > Architecture? >>>> >>>> Typical audio CODEC, ENOB ~ 14, Fsa = 8...48kHz, Delta-sigma >>>> >>>> > What kind of analog-to-digital converters are used for the >>>> > ACCELEROMETER ETC. signal in cell phones... >>>> > Number of bits? >>>> > Sampling rate? >>>> > Architecture? >>>> >>>> Typical MCU ADC. ENOB ~ 10, Fsa ~ kHz area, Capacitive SAR. > > And as I suspected and Eric wrote below, the accelerometer has a > built-in ADC and communicates through SPI or I2C. From the ifixit link: > > STMicroelectronics LIS331DLH (2233/DSH/GFGHA) ultra low-power, high > performance, three-axis linear accelerometer > > Googling the data sheet: > http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00213470.pdf> > finds a 12-bit internal ADC indirectly documented on page 9. > > Apparently there's no analog I/O on these things except where absolutely > needed, as on the mic, antenna, and battery voltage and current. It's > cheaper to have any analog value converted on-chipSample-of-one surveys can be misleading. Of the seven pages of gyros that are listed on DigiKey, four are left when you select analog output. When you select all possible variations of outputs with the word "digital", only one page is left. Similarly, of the 37 pages of accelerometers, 20 pages come up when you allow only ones with "analog", "linear", "ratiometric", "differential" and "voltage" in their output description, while only 13 come up if you allow only ones with "digital", "SPI", or "3-wire" in their output descriptions -- and one of those "digital" definitions was "digital, PWM", which almost doesn't count as digital, IMHO. So the market is far from saturated with sensors with on-board ADCs just yet. -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
Note that devices used in cell phones often do not have data sheets listed on the manufacturers web-site, and neither would they be listed in digi-key. This is because many of these devices are so specialized that they have little use outside a particular cell-phone, and there are so few large-volume manufacturers of cellphones that there is little to gain by public disclosure of the data sheet. Bob
