Hi all, I am looking for a numerical method for differentiation of oscillating signal. I have tried several method like forward/central difference method, fourier differentiator but no help. Does anyone have any idea?
numerical differentiation of oscillating singal
Started by ●October 28, 2003
Reply by ●October 28, 20032003-10-28
"Rex_chaos" <rex_chaos@21cn.com> wrote in message news:f7a7417.0310280538.3d3322dc@posting.google.com...> Hi all, > I am looking for a numerical method for differentiation of > oscillating signal. I have tried several method like forward/central > difference method, fourier differentiator but no help. Does anyone > have any idea?If the signal is properly sampled, then it respresents a continuous bandlimited signal. If you want the derivative of this signal, there are nifty ways to get it, depending on exactly how, for the purpose of extracting its derivative, you want that signal to be reconstructed. Do you want the derivative of the ideally interpolated signal, the signal that shows up at the output of some system, or the signal as interpolated with some other interpolation filter?
Use B=REMEZ(N,F,A,'differentiator') and B=REMEZ(N,F,A,W,'differentiator') For bandlimited differentiation. The problem with differentiation is the noise at high frequencies. HTH -- ----------------------------------------------------------- Dr. Izhak "Rex_chaos" <rex_chaos@21cn.com> wrote in message news:f7a7417.0310280538.3d3322dc@posting.google.com...> Hi all, > I am looking for a numerical method for differentiation of > oscillating signal. I have tried several method like forward/central > difference method, fourier differentiator but no help. Does anyone > have any idea?
Reply by ●October 29, 20032003-10-29
"Matt Timmermans" <mt0000@sympatico.nospam-remove.ca> wrote in message news:<R8vnb.1971$Nz5.205470@news20.bellglobal.com>...> "Rex_chaos" <rex_chaos@21cn.com> wrote in message > news:f7a7417.0310280538.3d3322dc@posting.google.com... > > Hi all, > > I am looking for a numerical method for differentiation of > > oscillating signal. I have tried several method like forward/central > > difference method, fourier differentiator but no help. Does anyone > > have any idea? > > If the signal is properly sampled, then it respresents a continuous > bandlimited signal. If you want the derivative of this signal, there are > nifty ways to get it, depending on exactly how, for the purpose of > extracting its derivative, you want that signal to be reconstructed. > > Do you want the derivative of the ideally interpolated signal, the signal > that shows up at the output of some system, or the signal as interpolated > with some other interpolation filter?>Actually, I am processing a signal f(t) and in each step of time, f(t+dt) = G[D[f(t)]] here D means the differentiation of f(t) and G is a function to form D[f(t)] to a new signal. However, f(t) is a signal with a rapidly oscillating tail. A common algorithm (such as forward difference) to perform numerical differentiation will lead to wrong result. For this purpose, I adopt a high-order difference formula. It's weird that the high-order formula is even worse than the central difference formula. I also take the fourier method but no help D[f(t)] = iff(i*w*F(w)); w denotes for the angular frequency and ifft denotes the inverse fourier transformation. F(w) is the fourier spectrum of f(t).
> B=REMEZ(N,F,A,'differentiator') and B=REMEZ(N,F,A,W,'differentiator') > > For bandlimited differentiation. The problem with differentiation is the > noise at high frequencies.What is remez? Is it a function provided by matlab or other dsp package? Thanks.
Rex_chaos wrote:>> B=REMEZ(N,F,A,'differentiator') and B=REMEZ(N,F,A,W,'differentiator') >> >>For bandlimited differentiation. The problem with differentiation is the >>noise at high frequencies. > > What is remez? Is it a function provided by matlab or other dsp package? >from matlab: REMEZ Parks-McClellan optimal equiripple FIR filter design. B=REMEZ(N,F,A) returns a length N+1 linear phase (real, symmetric coefficients) FIR filter which has the best approximation to the desired frequency response described by F and A in the minimax sense. F is a vector of frequency band edges in pairs, in ascending order between 0 and 1. 1 corresponds to the Nyquist frequency or half the sampling frequency. A is a real vector the same size as F which specifies the desired amplitude of the frequency response of the resultant filter B. The desired response is the line connecting the points (F(k),A(k)) and (F(k+1),A(k+1)) for odd k; REMEZ treats the bands between F(k+1) and F(k+2) for odd k as "transition bands" or "don't care" regions. Thus the desired amplitude is piecewise linear with transition bands. The maximum error is minimized. For filters with a gain other than zero at Fs/2, e.g., highpass and bandstop filters, N must be even. Otherwise, N will be incremented by one. B=REMEZ(N,F,A,W) uses the weights in W to weight the error. W has one entry per band (so it is half the length of F and A) which tells REMEZ how much emphasis to put on minimizing the error in each band relative to the other bands. B=REMEZ(N,F,A,'Hilbert') and B=REMEZ(N,F,A,W,'Hilbert') design filters that have odd symmetry, that is, B(k) = -B(N+2-k) for k = 1, ..., N+1. A special case is a Hilbert transformer which has an approx. amplitude of 1 across the entire band, e.g. B=REMEZ(30,[.1 .9],[1 1],'Hilbert'). B=REMEZ(N,F,A,'differentiator') and B=REMEZ(N,F,A,W,'differentiator') also design filters with odd symmetry, but with a special weighting scheme for non-zero amplitude bands. The weight is assumed to be equal to the inverse of frequency times the weight W. Thus the filter has a much better fit at low frequency than at high frequency. This designs FIR differentiators. B=REMEZ(...,{LGRID}), where {LGRID} is a one-by-one cell array containing an integer, controls the density of the frequency grid. The frequency grid size is roughly LGRID*N/2*BW, where BW is the fraction of the total band interval [0,1] covered by F. LGRID should be no less than its default of 16. Increasing LGRID often results in filters which are more exactly equi- ripple, at the expense of taking longer to compute. [B,ERR]=REMEZ(...) returns the maximum ripple height ERR. [B,ERR,RES]=REMEZ(...) returns a structure RES of optional results computed by REMEZ, and contains the following fields: RES.fgrid: vector containing the frequency grid used in the filter design optimization RES.des: desired response on fgrid RES.wt: weights on fgrid RES.H: actual frequency response on the grid RES.error: error at each point on the frequency grid (desired - actual) RES.iextr: vector of indices into fgrid of extremal frequencies RES.fextr: vector of extremal frequencies See also CREMEZ, FIRLS, FIR1, FIR2, BUTTER, CHEBY1, CHEBY2, ELLIP, FREQZ, FILTER and GREMEZ in the Filter Design toolbox.
Thanks. I try that function. Maybe I misuse it, the effect of the function it not like a differentiator. Would you please give me an example to illustrate how to differentiate a signal numerical with a filter? Thanks a lot
Rex_chaos wrote:> Thanks. I try that function. Maybe I misuse it, the effect of the > function it not like a differentiator. Would you please give me an > example to illustrate how to differentiate a signal numerical with a > filter? > > Thanks a lotHere's a silly-simple example: Suppose the differentiator function is the simple difference between the current sample and the previous one. As a difference function, x[i] - x[i-1]. This is also a transversal FIR whose tap values are 1, -1. (Latest value first.) Any function whose value depends only on past inputs can be represented as a filter. Jerry P.S. That structure is also a silly-simple Hilbert transformer, giving a 90-degree phase shift as a differentiator must. It's main trouble is that its output is half an interval delayed with respect to the undifferentiated signal. We can align signal and derivative by delaying the signal. Spanning three samples in the FIFO is simpler than creating a half-period delay. The differentiator (and Hilbert) output is computed with the taps 1, 0, -1, while the merely delayed output uses 0, 1, 0. Math fills in details that intuition doesn't reveal, but using intuition at first helps us to see where the math is leading. -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
"Rex_chaos" <rex_chaos@21cn.com> wrote in message news:f7a7417.0310282119.35acf7bd@posting.google.com...> Actually, I am processing a signal f(t) and in each step of time, > > f(t+dt) = G[D[f(t)]] > > here D means the differentiation of f(t) and G is a function to form > D[f(t)] to a new signal. [...]Oh, you're doing a simulation? In that case, you can't really get an accurate derivative from amplitude samples, because the derivative depends on past *and future* samples. If you don't have the future samples, you can only guess at the derivative, and and make your time step small enough to provide sufficient accuracy. If your function is oscillating quickly with respect to the time step, then it won't be very accurate at all. Now, your particular case looks very broken. The process you wrote doesn't seem to converge to a smooth function as you decrease the time step, which would explain why you're getting such wierd results. Do you really mean for those f's to be the same signal?
Reply by ●October 30, 20032003-10-30
> Oh, you're doing a simulation?yes.>In that case, you can't really get an > accurate derivative from amplitude samples, because the derivative depends > on past *and future* samples. If you don't have the future samples, you can > only guess at the derivative, and and make your time step small enough to > provide sufficient accuracy. If your function is oscillating quickly with > respect to the time step, then it won't be very accurate at all.Of course, I did all you mentioned above.> Now, your particular case looks very broken. The process you wrote doesn't > seem to converge to a smooth function as you decrease the time step, which > would explain why you're getting such wierd results. Do you really mean for > those f's to be the same signal?As long as the time step is small enough, the signal can be considered as a smooth-vaired one, isn't it?
