Hi, I need to get a prototype DSP board up and running ASAP and was looking at the TI320LF2406 and the Motorola 56F803. Based somewhat on price and GPIO pinouts I selected the TI part and got the eZDSP system kit thinking (incorrectly it appears) that I could develop and then move a design to a prototype board and debug the prototype without additional hardware. It is now sinking in that I seem to need to spend several $1000's to get programming and debugging support on my prototype board. We make extensive use of PIC and Motorola microcontrollers where the $200 kit gets you everything you need to do onboard programming and debugging, so it appears that that experience led me to make some bad assumptions about the DSP development. What is the least expensive way on either TI or Motorola to get a programmable and debugable DSP board? Thanks in advance... Rob
Help getting from eval kit to debugable prototype board.
Started by ●October 8, 2003
Reply by ●October 8, 20032003-10-08
Robert, You can get a board from motorola for their new DSP56F8322 for $79. It include a CodeWarrior IDE with 8Kx16 of FREE Compiler with plenty of Free "Beans" from Processor Expert. No fancy JTAG Emulator to buy like with TI @ $1000 or $1500. If you look at the board schematic it's easy to build your own or even use the small DEMO board to program your target. In fact every part come with a Serial Bootloader. "Robert Norman" < wrote in message news:vo99akq5n0chcc@corp.supernews.com...> Hi, > > I need to get a prototype DSP board up and running ASAP and was looking at > the TI320LF2406 and the Motorola 56F803. Based somewhat on price and GPIO > pinouts I selected the TI part and got the eZDSP system kit thinking > (incorrectly it appears) that I could develop and then move a design to a > prototype board and debug the prototype without additional hardware. Itis> now sinking in that I seem to need to spend several $1000's to get > programming and debugging support on my prototype board. > > We make extensive use of PIC and Motorola microcontrollers where the $200 > kit gets you everything you need to do onboard programming and debugging,so> it appears that that experience led me to make some bad assumptions about > the DSP development. > > What is the least expensive way on either TI or Motorola to get a > programmable and debugable DSP board? > > Thanks in advance... > > Rob > > > >
Reply by ●October 9, 20032003-10-09
Robert Norman wrote:> Hi, > > I need to get a prototype DSP board up and running ASAP and was looking at > the TI320LF2406 and the Motorola 56F803. Based somewhat on price and GPIO > pinouts I selected the TI part and got the eZDSP system kit thinking > (incorrectly it appears) that I could develop and then move a design to a > prototype board and debug the prototype without additional hardware. It is > now sinking in that I seem to need to spend several $1000's to get > programming and debugging support on my prototype board. > > We make extensive use of PIC and Motorola microcontrollers where the $200 > kit gets you everything you need to do onboard programming and debugging, so > it appears that that experience led me to make some bad assumptions about > the DSP development. > > What is the least expensive way on either TI or Motorola to get a > programmable and debugable DSP board? > > Thanks in advance... > > Rob > > > >With TI, look for "DSK". These are available for several processors, and come with at least assembler and debugger. Jerry -- "I view the progress of science as ... the slow erosion of the tendency to dichotomize." Barbara Smuts, U. Mich. ���������������������������������������������������������������������
I've done a little more of my homework and found that there is a somewhat reasonable system from SpectrumDigital at $1300 that appears to do what I want. I'm still unclear on what is necessary in the way of upgrades to make CodeComposer work with my device but it seems doable. On the other hand, I'm taking a second look at motorola. Our board designer does not like the size of the JTAG connnector required for the TI part and I'm wondering if the project might go better with Motorola. I've use older versions of CodeWarrior and like the interface and like the idea that, as Francois mentioned, there is no need for an expensive (for us) emulator. Thanks for the responses... "Francois Anderson" <anderson_tsm@hotmail.com> wrote in message news:vx3hb.887$X_.167371@wagner.videotron.net...> Robert, > > You can get a board from motorola for their new DSP56F8322 for $79. > It include a CodeWarrior IDE with 8Kx16 of FREE Compiler with plenty ofFree> "Beans" from Processor Expert. > No fancy JTAG Emulator to buy like with TI @ $1000 or $1500. > If you look at the board schematic it's easy to build your own or even use > the small DEMO board to program your target. > In fact every part come with a Serial Bootloader. > >>With TI, look for "DSK". These are available for several processors, and >come with at least assembler and debugger. > >Jerry
