Hello I am starting using the ADSP-21065L EZ-Kit development board. I have an include problem. When compiling a sample project with VisualDSP++ version 2.0 I get the following error: main.h", line 16: catastrophic error #5: could not open source file "ezkit/1819regs.h" #include <ezkit/1819regs.h> //Visual DSP Ver 2.0 In my ldf file I have the statement SEARCH_DIR( $ADI_DSP\21k\lib ). How can I solve this problem? what is that ezkit pre-statement that I have to use within the include statement? The error occurs only when I compile a project that I created myself. When I use a project that is on my server, that was created before by an other engineer, there is no problem with the compilation. (I cannot ask that engineer, he does not work here anymore...) Thank for your help! -- Regards Marco
ADSP-21065L EZ-Kit include problem
Started by ●October 8, 2003
Reply by ●October 8, 20032003-10-08
Marco Schuler wrote: > Hello > > I am starting using the ADSP-21065L EZ-Kit development board. I have an > include problem. When compiling a sample project with VisualDSP++ > version 2.0 I get the following error: > > main.h", line 16: catastrophic error #5: could not open source file > "ezkit/1819regs.h" > #include <ezkit/1819regs.h> //Visual DSP Ver 2.0 > > > In my ldf file I have the statement SEARCH_DIR( $ADI_DSP\21k\lib ). > > How can I solve this problem? what is that ezkit pre-statement that I > have to use within the include statement? > > The error occurs only when I compile a project that I created myself. > When I use a project that is on my server, that was created before by an > other engineer, there is no problem with the compilation. (I cannot ask > that engineer, he does not work here anymore...) > > Thank for your help! > > -- > Regards > Marco > What does the file path look like? Are you files and the former employee's in the same directory? Jerry -- "I view the progress of science as ... the slow erosion of the tendency to dichotomize." Barbara Smuts, U. Mich. ���������������������������������������������������������������������
Reply by ●October 9, 20032003-10-09
Jerry Avins wrote:> Marco Schuler wrote: > > > Hello > > > > I am starting using the ADSP-21065L EZ-Kit development board. I have an > > include problem. When compiling a sample project with VisualDSP++ > > version 2.0 I get the following error: > > > > main.h", line 16: catastrophic error #5: could not open source file > > "ezkit/1819regs.h" > > #include <ezkit/1819regs.h> //Visual DSP Ver 2.0 > > > > > > In my ldf file I have the statement SEARCH_DIR( $ADI_DSP\21k\lib ). > > > > How can I solve this problem? what is that ezkit pre-statement that I > > have to use within the include statement? > > > > The error occurs only when I compile a project that I created myself. > > When I use a project that is on my server, that was created before by an > > other engineer, there is no problem with the compilation. (I cannot ask > > that engineer, he does not work here anymore...) > > > > Thank for your help! > > > > -- > > Regards > > Marco > > > What does the file path look like? Are you files and the former > employee's in the same directory?I figured out that compilation does not work in the former employee's directory too. I am not sure but I think there is maybe something wrong with my installation of VisualDSP++, since in its installation directory, there is no directory ezkit, where the include should be taken from. Any ideas? -- Marco
Reply by ●October 14, 20032003-10-14
This problem occurs as it requires the file "1819regs.h" to be in the directory "ezkit" within the directory . So the file should be placed such that u have the file as include/ezkit/1819regs.h Marco Schuler <dummy@foo.bar> wrote in message news:<3f85154e$1@news.swissonline.ch>...> Jerry Avins wrote: > > Marco Schuler wrote: > > > > > Hello > > > > > > I am starting using the ADSP-21065L EZ-Kit development board. I have an > > > include problem. When compiling a sample project with VisualDSP++ > > > version 2.0 I get the following error: > > > > > > main.h", line 16: catastrophic error #5: could not open source file > > > "ezkit/1819regs.h" > > > #include <ezkit/1819regs.h> //Visual DSP Ver 2.0 > > > > > > > > > In my ldf file I have the statement SEARCH_DIR( $ADI_DSP\21k\lib ). > > > > > > How can I solve this problem? what is that ezkit pre-statement that I > > > have to use within the include statement? > > > > > > The error occurs only when I compile a project that I created myself. > > > When I use a project that is on my server, that was created before by an > > > other engineer, there is no problem with the compilation. (I cannot ask > > > that engineer, he does not work here anymore...) > > > > > > Thank for your help! > > > > > > -- > > > Regards > > > Marco > > > > > What does the file path look like? Are you files and the former > > employee's in the same directory? > > I figured out that compilation does not work in the former employee's > directory too. I am not sure but I think there is maybe something wrong > with my installation of VisualDSP++, since in its installation > directory, there is no directory ezkit, where the include should be > taken from. Any ideas?
