I'm designing a CIC filter to perform a hardware efficient downsample. My application is a little bit different in that the downsample factor isn't very large, we're just doing a CIC in order to save multiplies in the FPGA. I'm running into problems with the compensating filter, however. So far I've looked at a paper that describes using and integrated second order polynomial (ISOP) for the compensating filter. This also takes up very few multiplies but it doesn't perform extremely well for our situation. Maybe I'm trying to squeeze too narrow of a bandwidth out of the CIC - it seems like it won't work as well as a simple low pass filter then downsample. But here's my question. I noticed that the filter design toolbox will create an inverse sinc fir filter using constrained equiripple design criteria. I don't have the filter design toolbox. What are some sources I can look at to find out how to do it myself? Or does anyone have other recommendations for compensating filters? Thanks, in advance.
CIC Compensating filter
Started by ●October 6, 2003
Reply by ●October 7, 20032003-10-07
Eric C. wrote:> ... here's my question. I noticed that the filter design toolbox will > create an inverse sinc fir filter using constrained equiripple design > criteria. I don't have the filter design toolbox. What are some > sources I can look at to find out how to do it myself? Or does anyone > have other recommendations for compensating filters? Thanks, in > advance.There are many sources. http://www.iowegian.com/ is one good one. It's companion site, http://www.DSPguru.com/ may have useful ideas for you. Jerry -- "I view the progress of science as ... the slow erosion of the tendency to dichotomize." Barbara Smuts, U. Mich. ���������������������������������������������������������������������
Reply by ●October 10, 20032003-10-10
Practically speaking, you need to restrict your passband to the region where the uncorrected CIC is less than 6db difference from the corrected signal. Beyond that, your correction filter has too high an order, and more importantly you are losing SNR as you amplify the signal attenuated by the CIC's rolloff. The narrower the portion of the CIC you keep, the easier the compensation. Note that normally, your final passband should be a small fraction (certainly not more than about 25%) of the first null frequency in the CIC response. "Eric C." wrote:> I'm designing a CIC filter to perform a hardware efficient downsample. > My application is a little bit different in that the downsample factor > isn't very large, we're just doing a CIC in order to save multiplies > in the FPGA. I'm running into problems with the compensating filter, > however. > > So far I've looked at a paper that describes using and integrated > second order polynomial (ISOP) for the compensating filter. This also > takes up very few multiplies but it doesn't perform extremely well for > our situation. Maybe I'm trying to squeeze too narrow of a bandwidth > out of the CIC - it seems like it won't work as well as a simple low > pass filter then downsample. > > But here's my question. I noticed that the filter design toolbox will > create an inverse sinc fir filter using constrained equiripple design > criteria. I don't have the filter design toolbox. What are some > sources I can look at to find out how to do it myself? Or does anyone > have other recommendations for compensating filters? Thanks, in > advance.-- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 email ray@andraka.com http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759
