Observe the following code and it's corresponding output. Any ideas? Code snippet-------------------------> void main() { int one=1; int two=2; LOG_printf(&trace, "test(%d %d)", one, two); //flakey LOG_printf(&trace, "test(%d %d)", 0, one, 0, two); //works?!? return; } Output-------------------------------> 0 test(2 -24576) 1 test(1 2) I am using code composer 2.2 and the project is set up for DSP BIOS using a TMS320F2812 target. I have the LOG_Obj trace set up thru the appropriate api. I have seen some other flakiness with LOG_printf as well but I feel that this example captures the symptom most concisely. Has anyone else seen anything like this? Is there something that needs to be set up differently? It almost looks like the arguments aren't being passed correctly? Any help would greatly be appreciated. Thanks Paul
DSP/BIOS LOG_printf is a little flakey!
Started by ●October 3, 2003
Reply by ●October 5, 20032003-10-05
christmascaroler@excite.com (stressed_out) wrote in message news:<8538c581.0310030509.6fbaf872@posting.google.com>...> Observe the following code and it's corresponding output. > Any ideas? > > Code snippet-------------------------> > void main() { > int one=1; > int two=2; > LOG_printf(&trace, "test(%d %d)", one, two); //flakey > LOG_printf(&trace, "test(%d %d)", 0, one, 0, two); //works?!? > return; > } > > Output-------------------------------> > 0 test(2 -24576) > 1 test(1 2) > > I am using code composer 2.2 and the project is set up for DSP BIOS > using a TMS320F2812 target. I have the LOG_Obj trace set up thru the > appropriate api. > I have seen some other flakiness with LOG_printf as well but I feel > that this example captures the symptom most concisely. > > Has anyone else seen anything like this? > Is there something that needs to be set up differently? > It almost looks like the arguments aren't being passed correctly? > Any help would greatly be appreciated. > Thanks > PaulAs far as i understood the dsp/bios stuff only becomes active after the main() function is completed. Do you experience this problem when calling log_printf from a tsk or swi ?
Reply by ●October 6, 20032003-10-06
qazwsx_1999@yahoo.com (Q) wrote in message news:<397748.0310042004.527e5f64@posting.google.com>...> christmascaroler@excite.com (stressed_out) wrote in message news:<8538c581.0310030509.6fbaf872@posting.google.com>... > > Observe the following code and it's corresponding output. > > Any ideas? > > > > Code snippet-------------------------> > > void main() { > > int one=1; > > int two=2; > > LOG_printf(&trace, "test(%d %d)", one, two); //flakey > > LOG_printf(&trace, "test(%d %d)", 0, one, 0, two); //works?!? > > return; > > } > > > > Output-------------------------------> > > 0 test(2 -24576) > > 1 test(1 2) > > > > I am using code composer 2.2 and the project is set up for DSP BIOS > > using a TMS320F2812 target. I have the LOG_Obj trace set up thru the > > appropriate api. > > I have seen some other flakiness with LOG_printf as well but I feel > > that this example captures the symptom most concisely. > > > > Has anyone else seen anything like this? > > Is there something that needs to be set up differently? > > It almost looks like the arguments aren't being passed correctly? > > Any help would greatly be appreciated. > > Thanks > > Paul > > As far as i understood the dsp/bios stuff only becomes active after > the main() function is completed. Do you experience this problem when > calling log_printf from a tsk or swi ?Yes, the problem occurs from within tasks as well. I only showed the main() because it was the best way to show the smallest example.
Reply by ●August 30, 20052005-08-30
>qazwsx_1999@yahoo.com (Q) wrote in messagenews:<397748.0310042004.527e5f64@posting.google.com>...>> christmascaroler@excite.com (stressed_out) wrote in messagenews:<8538c581.0310030509.6fbaf872@posting.google.com>...>> > Observe the following code and it's corresponding output. >> > Any ideas? >> > >> > Code snippet-------------------------> >> > void main() { >> > int one=1; >> > int two=2; >> > LOG_printf(&trace, "test(%d %d)", one, two); //flakey >> > LOG_printf(&trace, "test(%d %d)", 0, one, 0, two); //works?!? >> > return; >> > } >> > >> > Output-------------------------------> >> > 0 test(2 -24576) >> > 1 test(1 2) >> > >> > I am using code composer 2.2 and the project is set up for DSP BIOS >> > using a TMS320F2812 target. I have the LOG_Obj trace set up thruthe>> > appropriate api. >> > I have seen some other flakiness with LOG_printf as well but I feel >> > that this example captures the symptom most concisely. >> > >> > Has anyone else seen anything like this? >> > Is there something that needs to be set up differently? >> > It almost looks like the arguments aren't being passed correctly? >> > Any help would greatly be appreciated. >> > Thanks >> > Paul >> >> As far as i understood the dsp/bios stuff only becomes active after >> the main() function is completed. Do you experience this problem when >> calling log_printf from a tsk or swi ? > >Yes, the problem occurs from within tasks as well. >I only showed the main() because it was the best way to show the smallestexample.>I would recommend looking at the DSP BIOS examples. You will notice that there is a typedef that declares if you are using a 2812 processor that the LOG_printf functions typecast the arguments to (ARG). This apparently has been cleared up in CCS 3.0 or with the more recent BIOS. This message was sent using the Comp.DSP web interface on www.DSPRelated.com
