I am trying to understand the efficient implementation of FSE, briefly described in http://spsc.inw.tugraz.at/courses/asp/ws01/schwingshackl.pdf (Fig 4) As an example of T/2 FSE, what I understand is that it separates out even and odd sample streams and apply the Tapped Delay Line (TDL) adaptive filters separately. the output of both filters are added. My question is how it is an efficient implementation, in what term it is efficient, memory or cycles? How it is equivalent to ordinary implementation in which the down sampling is done at the output of the equalizer ( Only the alternate output samples are generated and every time the TDL are shifted by 2)? Thanks in Advance S Singh
Efficient implementation of fractionally spaced equalizer
Started by ●September 29, 2003
Reply by ●September 29, 20032003-09-29
singhs21@hotmail.com (S Singh) wrote in message news:<9c5369f0.0309282322.56b5a7ee@posting.google.com>...> I am trying to understand the efficient implementation of FSE, briefly > described in http://spsc.inw.tugraz.at/courses/asp/ws01/schwingshackl.pdf > (Fig 4) > As an example of T/2 FSE, what I understand is that it separates out > even and odd sample streams and apply the Tapped Delay Line (TDL) > adaptive filters separately. the output of both filters are added. > My question is how it is an efficient implementation, in what term it > is efficient, memory or cycles? > How it is equivalent to ordinary implementation in which the down > sampling is done at the output of the equalizer ( Only the alternate > output samples are generated and every time the TDL are shifted by 2)?Hi There, Your questions can not be answered in short notes - an ordinary decimation filter(probably you meant above) will give poor performance for CCI and ACI test cases. You need to implement a MMSE DFE "prefilter" (act as decimator also where we combine the fractionally spaced samples) to get much improved performance.Packet based sytems like EDGE needs "prefiler" to reduce the complexity of bit detection unit like Viterbi or MAP equalizer ..... Fractionally spaced receiver(T/2) consumes most of its cycles at "prefilter" design;There are fast Cholesky prefilters these days mainly for fractionally spaced receivers. There are many more routines to take in an efficient implementation- there is obvious chance of memory overlaying as equalizer has mostly sequential structure. It is however required to know how much memory and cycles one is allocating for equalizer prior to feature implementation. Looking at your requirements I would recommend if you could consult following papers: 1. Ungerboeck "Fractinally spaced equalizer ...",1976,Aug,IEEE trans communication - the original paper for fractinally spaced receiver 2. Al Dhahir et al " Fast computation of channel-estimate based equalizers in packet data transmission", IEEE Trans.Signal processing ... 2462-2473, Nov. 1995 - one of the best papers to discuss MMSE DFE based prefiler for T & T/2 etc spaced equalizers. It also gives algorithm complexity and implemenation support. Hope that helps a little. Santosh> > Thanks in Advance > > S Singh
Reply by ●September 30, 20032003-09-30
Hi Santosh, Thanks for the explanation. Actually my question is on a particular implementation of T/2 Fractionally spaced equalizer (FSE) and not on DFE. This particular implementation is said to be an "efficient implementation of fractionally spaced equalizer" and briefly given (Block Diagram) in FIGURE 4 of the following document: ( please see the link below ) http://spsc.inw.tugraz.at/courses/asp/ws01/schwingshackl.pdf I am trying to understand and looking for more info on this implementation of FSE. I am still looking for the answers and will go through the references you gave, I guess I have gone through the first one sometime back. Regards S. Singh santosh.nath@ntlworld.com (santosh nath) wrote in message news:<6afd943a.0309291329.1ed4a98c@posting.google.com>...> singhs21@hotmail.com (S Singh) wrote in message news:<9c5369f0.0309282322.56b5a7ee@posting.google.com>... > > I am trying to understand the efficient implementation of FSE, briefly > > described in http://spsc.inw.tugraz.at/courses/asp/ws01/schwingshackl.pdf > > (Fig 4) > > As an example of T/2 FSE, what I understand is that it separates out > > even and odd sample streams and apply the Tapped Delay Line (TDL) > > adaptive filters separately. the output of both filters are added. > > My question is how it is an efficient implementation, in what term it > > is efficient, memory or cycles? > > How it is equivalent to ordinary implementation in which the down > > sampling is done at the output of the equalizer ( Only the alternate > > output samples are generated and every time the TDL are shifted by 2)? > > Hi There, > Your questions can not be answered in short notes - an ordinary > decimation filter(probably you meant above) will give poor performance > for CCI and ACI > test cases. You need to implement a MMSE DFE "prefilter" (act as > decimator also where we combine the fractionally spaced samples) to > get much improved performance.Packet based sytems like EDGE needs > "prefiler" to reduce the complexity of bit detection unit like Viterbi > or MAP equalizer ..... > > Fractionally spaced receiver(T/2) consumes most of its cycles at > "prefilter" > design;There are fast Cholesky prefilters these days mainly for > fractionally spaced receivers. There are many more routines to take in > an efficient > implementation- there is obvious chance of memory overlaying as > equalizer > has mostly sequential structure. It is however required to know how > much memory > and cycles one is allocating for equalizer prior to feature > implementation. > > Looking at your requirements I would recommend if you could consult > following papers: > > 1. Ungerboeck "Fractinally spaced equalizer ...",1976,Aug,IEEE trans > communication - the original paper for fractinally spaced receiver > 2. Al Dhahir et al " Fast computation of channel-estimate based > equalizers in packet data transmission", IEEE Trans.Signal processing > ... 2462-2473, Nov. 1995 - one of the best papers to discuss MMSE DFE > based prefiler > for T & T/2 etc spaced equalizers. It also gives algorithm complexity > and implemenation support. > > Hope that helps a little. > Santosh > > > > > > > Thanks in Advance > > > > S Singh
Reply by ●October 1, 20032003-10-01
singhs21@hotmail.com (S Singh) wrote in message news:<9c5369f0.0309300705.38a6aaa@posting.google.com>...> Hi Santosh, > > Thanks for the explanation. > > Actually my question is on a particular implementation of T/2 > Fractionally spaced equalizer (FSE) and not on DFE. > > This particular implementation is said to be an "efficient > implementation of fractionally spaced equalizer" and briefly given > (Block Diagram) in FIGURE 4 of the following document: ( please see > the link below ) > > http://spsc.inw.tugraz.at/courses/asp/ws01/schwingshackl.pdf >Hi ..., I have gone through fig 4. I guess it is using zero-forcing(ZF) solution. My posting is quite similar to fig 6. But FSE block is different. In fact instead of pure decimation filter we use a two feedforward filters; estimate prefilter taps using MMSE criteria(ZF criteria not good for noise dominant case(low SNR).) and filter samples through them and combine. Feedback filter is used to estimate the kernel equalizer taps. So we pass following information to kernel equlaizer(MAP/Viterbi) -filtered samples -new equalizer taps I am sure you will find all these information in the second paper.So it is worth to see. May be for XDSL, you may not need this complex FSE(Fig 6 or modified FSE as described in second paper). So fig 4 could be very useful - anyway check your requirements and decide! Regards, Santosh> I am trying to understand and looking for more info on this > implementation of FSE. > > I am still looking for the answers and will go through the references > you gave, I guess I have gone through the first one sometime back. > > Regards > > S. Singh > > santosh.nath@ntlworld.com (santosh nath) wrote in message news:<6afd943a.0309291329.1ed4a98c@posting.google.com>... > > singhs21@hotmail.com (S Singh) wrote in message news:<9c5369f0.0309282322.56b5a7ee@posting.google.com>... > > > I am trying to understand the efficient implementation of FSE, briefly > > > described in http://spsc.inw.tugraz.at/courses/asp/ws01/schwingshackl.pdf > > > (Fig 4) > > > As an example of T/2 FSE, what I understand is that it separates out > > > even and odd sample streams and apply the Tapped Delay Line (TDL) > > > adaptive filters separately. the output of both filters are added. > > > My question is how it is an efficient implementation, in what term it > > > is efficient, memory or cycles? > > > How it is equivalent to ordinary implementation in which the down > > > sampling is done at the output of the equalizer ( Only the alternate > > > output samples are generated and every time the TDL are shifted by 2)? > > > > Hi There, > > Your questions can not be answered in short notes - an ordinary > > decimation filter(probably you meant above) will give poor performance > > for CCI and ACI > > test cases. You need to implement a MMSE DFE "prefilter" (act as > > decimator also where we combine the fractionally spaced samples) to > > get much improved performance.Packet based sytems like EDGE needs > > "prefiler" to reduce the complexity of bit detection unit like Viterbi > > or MAP equalizer ..... > > > > Fractionally spaced receiver(T/2) consumes most of its cycles at > > "prefilter" > > design;There are fast Cholesky prefilters these days mainly for > > fractionally spaced receivers. There are many more routines to take in > > an efficient > > implementation- there is obvious chance of memory overlaying as > > equalizer > > has mostly sequential structure. It is however required to know how > > much memory > > and cycles one is allocating for equalizer prior to feature > > implementation. > > > > Looking at your requirements I would recommend if you could consult > > following papers: > > > > 1. Ungerboeck "Fractinally spaced equalizer ...",1976,Aug,IEEE trans > > communication - the original paper for fractinally spaced receiver > > 2. Al Dhahir et al " Fast computation of channel-estimate based > > equalizers in packet data transmission", IEEE Trans.Signal processing > > ... 2462-2473, Nov. 1995 - one of the best papers to discuss MMSE DFE > > based prefiler > > for T & T/2 etc spaced equalizers. It also gives algorithm complexity > > and implemenation support. > > > > Hope that helps a little. > > Santosh > > > > > > > > > > > > Thanks in Advance > > > > > > S Singh
