Hi, I am looking for low pass interpolation filter - C code or pseudo code/algorithm descriptions etc. MatLab has one such function "interp"- the algorithm is described in "programs for digital signal processing",IEEE Press,1979. Unfortunately I do not have the book with me. Could anbody help with online resource. Regards, Santosh
Low pass interpolation!!
Started by ●September 18, 2003
Reply by ●September 18, 20032003-09-18
On 18 Sep 2003, santosh nath wrote:> I am looking for low pass interpolation filter - C code or pseudo > code/algorithm descriptions etc. MatLab has one such function > "interp"- the algorithm is described in "programs for digital signal > processing",IEEE Press,1979. > Unfortunately I do not have the book with me.Try a web search on "Oetken Parks Schussler". Tak-Shing
santosh nath wrote:> > Hi, > I am looking for low pass interpolation filter - C code or pseudo > code/algorithm descriptions etc. MatLab has one such function > "interp"- the algorithm is described in "programs for digital signal > processing",IEEE Press,1979. > Unfortunately I do not have the book with me. > > Could anbody help with online resource.Secret Rabbit Code? http://www.mega-nerd.com/SRC/ Erik -- +-----------------------------------------------------------+ Erik de Castro Lopo nospam@mega-nerd.com (Yes it's valid) +-----------------------------------------------------------+ "Therapists typically base the nuttiness of a patient on the strength of their convictions, on which basis this 43,000 word opus alone stands as a kind of testament to Bill's (Gates) madness." - The Register
"santosh nath" <santosh.nath@ntlworld.com> wrote in message news:6afd943a.0309180901.7ca83c48@posting.google.com...> Hi, > I am looking for low pass interpolation filter - C code or pseudo > code/algorithm descriptions etc. MatLab has one such function > "interp"- the algorithm is described in "programs for digital signal > processing",IEEE Press,1979. > Unfortunately I do not have the book with me. > > Could anbody help with online resource.If you're satisfied with time-domain processing (which isn't necessarily the fastest method but is simple to implement), you can implement a FIR filter with coefficients that are obtained from the half-band filter design program I've posted at: ftp://ftp.mission-systems-inc.com/outgoing/Halfband/ The filters designed by this program provide 1/2 the bandwidth / 1/4 the sample rate passband. So, they are used by zero-filling the time array first and applying the filter next. I suppose you could make a polyphase implementation because of all the zero coefficients in the filter and all of the zeros in the filled time array. The interpolation can be repeated as above for as many factors of 2 of interpolation as you may need. The same filter can be used over and over for this purpose. There are more sophisticated and more efficient methods. This one is probably the easiest to understand and to implement and debug. Fred
