DC shift of the h(impulse response of the room) when using NLMS adaptive filtering
Started by Andrew Xiang September 16, 2003
Anyone encountered this problem when using NLMS? The h shifts up after
running for sometime, I noticed this for both white noise and color
voice signals. What caused the shift and how to avoid it?
thanks
Andrew
Andrew Xiang wrote:
> > Anyone encountered this problem when using NLMS? The h shifts up after > running for sometime, I noticed this for both white noise and color > voice signals. What caused the shift and how to avoid it?
Place a good HPF in front of NLMS. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
DC is high cut off, however, there is some low freq stuff. The HPF is
a second order IIR filter with slow roll off but about -80dB at DC.
Vladimir Vassilevsky <vlv@abvolt.com> wrote in message news:<3F679238.95F1E113@abvolt.com>...
> Andrew Xiang wrote: > > > > Anyone encountered this problem when using NLMS? The h shifts up after > > running for sometime, I noticed this for both white noise and color > > voice signals. What caused the shift and how to avoid it? > > Place a good HPF in front of NLMS. > > Vladimir Vassilevsky > > DSP and Mixed Signal Design Consultant > > http://www.abvolt.com
LMS requires an infinite attenuation at DC. Even the smallest DC shift
at the input will eventually cause an error buildup which I believe you
are observing.
Andrew Xiang wrote:
> > DC is high cut off, however, there is some low freq stuff. The HPF is > a second order IIR filter with slow roll off but about -80dB at DC. > > Vladimir Vassilevsky <vlv@abvolt.com> wrote in message news:<3F679238.95F1E113@abvolt.com>... > > Andrew Xiang wrote: > > > > > > Anyone encountered this problem when using NLMS? The h shifts up after > > > running for sometime, I noticed this for both white noise and color > > > voice signals. What caused the shift and how to avoid it? > > > > Place a good HPF in front of NLMS. > > > > Vladimir Vassilevsky > > > > DSP and Mixed Signal Design Consultant > > > > http://www.abvolt.com
Hmmm, infinite attenuation? how to realize that? Is it possible?
Vladimir Vassilevsky <vlv@abvolt.com> wrote in message news:<3F693329.F22BEB71@abvolt.com>...
> LMS requires an infinite attenuation at DC. Even the smallest DC shift > at the input will eventually cause an error buildup which I believe you > are observing. > > > Vladimir Vassilevsky > > DSP and Mixed Signal Design Consultant > > http://www.abvolt.com > > Andrew Xiang wrote: > > > > DC is high cut off, however, there is some low freq stuff. The HPF is > > a second order IIR filter with slow roll off but about -80dB at DC. > > > > Vladimir Vassilevsky <vlv@abvolt.com> wrote in message news:<3F679238.95F1E113@abvolt.com>... > > > Andrew Xiang wrote: > > > > > > > > Anyone encountered this problem when using NLMS? The h shifts up after > > > > running for sometime, I noticed this for both white noise and color > > > > voice signals. What caused the shift and how to avoid it? > > > > > > Place a good HPF in front of NLMS. > > > > > > Vladimir Vassilevsky > > > > > > DSP and Mixed Signal Design Consultant > > > > > > http://www.abvolt.com
There is no problem with achieving an infinite attenuation at DC or any
particular frequency. Just create zero in the transfer function at that
frequency.
Blocking DC is very simple: the numerator should look like z - z[-1] for
the first order filter or z - 2*z[-1] + z[-2] for the second order. That
condition is satisfied for any Butterworth, Bessel or Chebyshev-1
filter.
Andrew Xiang wrote:
> > Hmmm, infinite attenuation? how to realize that? Is it possible? > > Vladimir Vassilevsky <vlv@abvolt.com> wrote in message news:<3F693329.F22BEB71@abvolt.com>... > > LMS requires an infinite attenuation at DC. Even the smallest DC shift > > at the input will eventually cause an error buildup which I believe you > > are observing. > > > > > > Vladimir Vassilevsky > > > > DSP and Mixed Signal Design Consultant > > > > http://www.abvolt.com > > > > Andrew Xiang wrote: > > > > > > DC is high cut off, however, there is some low freq stuff. The HPF is > > > a second order IIR filter with slow roll off but about -80dB at DC. > > > > > > Vladimir Vassilevsky <vlv@abvolt.com> wrote in message news:<3F679238.95F1E113@abvolt.com>... > > > > Andrew Xiang wrote: > > > > > > > > > > Anyone encountered this problem when using NLMS? The h shifts up after > > > > > running for sometime, I noticed this for both white noise and color > > > > > voice signals. What caused the shift and how to avoid it? > > > > > > > > Place a good HPF in front of NLMS. > > > > > > > > Vladimir Vassilevsky > > > > > > > > DSP and Mixed Signal Design Consultant > > > > > > > > http://www.abvolt.com
Please give me a complete example.
2nd order,
3dB <=180hz.
Vladimir Vassilevsky <vlv@abvolt.com> wrote in message news:<3F69CD29.98C97F52@abvolt.com>...
> There is no problem with achieving an infinite attenuation at DC or any > particular frequency. Just create zero in the transfer function at that > frequency. > > Blocking DC is very simple: the numerator should look like z - z[-1] for > the first order filter or z - 2*z[-1] + z[-2] for the second order. That > condition is satisfied for any Butterworth, Bessel or Chebyshev-1 > filter. > > Vladimir Vassilevsky > > DSP and Mixed Signal Design Consultant > > http://www.abvolt.com > > > > > Andrew Xiang wrote: > > > > Hmmm, infinite attenuation? how to realize that? Is it possible? > > > > Vladimir Vassilevsky <vlv@abvolt.com> wrote in message news:<3F693329.F22BEB71@abvolt.com>... > > > LMS requires an infinite attenuation at DC. Even the smallest DC shift > > > at the input will eventually cause an error buildup which I believe you > > > are observing. > > > > > > > > > Vladimir Vassilevsky > > > > > > DSP and Mixed Signal Design Consultant > > > > > > http://www.abvolt.com > > > > > > Andrew Xiang wrote: > > > > > > > > DC is high cut off, however, there is some low freq stuff. The HPF is > > > > a second order IIR filter with slow roll off but about -80dB at DC. > > > > > > > > Vladimir Vassilevsky <vlv@abvolt.com> wrote in message news:<3F679238.95F1E113@abvolt.com>... > > > > > Andrew Xiang wrote: > > > > > > > > > > > > Anyone encountered this problem when using NLMS? The h shifts up after > > > > > > running for sometime, I noticed this for both white noise and color > > > > > > voice signals. What caused the shift and how to avoid it? > > > > > > > > > > Place a good HPF in front of NLMS. > > > > > > > > > > Vladimir Vassilevsky > > > > > > > > > > DSP and Mixed Signal Design Consultant > > > > > > > > > > http://www.abvolt.com
