Hello, I am looking for algorithms to calculate a minimum phase FIR filter from a desired frequency responce or from zero phase impulse response. Thank you, Frederic
Minimum phase FIR filter algorithm
Started by ●September 16, 2003
Reply by ●September 16, 20032003-09-16
Frederic Le Bas wrote:> > Hello, > > I am looking for algorithms to calculate a minimum phase FIR filter from a > desired frequency responce or from zero phase impulse response.This has been covered many times in this group. Google is your friend: http://groups.google.com/groups?as_q=minimum%20phase%20FIR&as_ugroup=comp.dsp&lr=&hl=en I also believe that there is an entry in the comp.dsp FAQ. Erik -- +-----------------------------------------------------------+ Erik de Castro Lopo nospam@mega-nerd.com (Yes it's valid) +-----------------------------------------------------------+ "Microsoft, and other companies with shoddy security, ....." -- Bruce Schneier, cryto-guru, to a US Senate committee.
On Tue, 16 Sep 2003 21:03:49 +0000, Erik de Castro Lopo wrote:> Frederic Le Bas wrote: >> I am looking for algorithms to calculate a minimum phase FIR filter from a >> desired frequency responce or from zero phase impulse response. > > This has been covered many times in this group. Google is your > friend: > > http://groups.google.com/groups?as_q=minimum%20phase%20FIR&as_ugroup=comp.dsp&lr=&hl=en > > I also believe that there is an entry in the comp.dsp FAQ.I don't know about the FAQ, but I know there is something at http://www.dspguru.com/howto/tech/minph.htm -- Matthew Donadio (m.p.donadio@ieee.org)
Reply by ●September 18, 20032003-09-18
Thank you all, I have found the FAQ at http://www.bdti.com/faq/dsp_faq.htm Since calculation methods are clearly explained, I presume that code should exist. --------------------------------------------------------------------------- "Matthew Donadio" <m.p.donadio@ieee.org> a �crit dans le message de news:pan.2003.09.17.01.25.48.374233@ieee.org...> On Tue, 16 Sep 2003 21:03:49 +0000, Erik de Castro Lopo wrote: > > Frederic Le Bas wrote: > >> I am looking for algorithms to calculate a minimum phase FIR filterfrom a> >> desired frequency responce or from zero phase impulse response. > > > > This has been covered many times in this group. Google is your > > friend: > > > >http://groups.google.com/groups?as_q=minimum%20phase%20FIR&as_ugroup=comp.dsp&lr=&hl=en> > > > I also believe that there is an entry in the comp.dsp FAQ. > > I don't know about the FAQ, but I know there is something at > > http://www.dspguru.com/howto/tech/minph.htm > > -- > Matthew Donadio (m.p.donadio@ieee.org) >
