I am using the McBSP as a spi master. Can it support only one slave device or does it have the capability to support multiple slaves. I know that dedicated spi master modules on other processors I have worked with have support for more than one device through a few chip selects. Any help is appreciated, Jack
Can McBSP as spi master support only one slave device ?
Started by ●September 13, 2003
Reply by ●September 15, 20032003-09-15
On 13 Sep 2003 09:52:07 -0700, hemrin2000@yahoo.com (Jack) wrote:>I am using the McBSP as a spi master. Can it support only one slave >device or does it have the capability to support multiple slaves. I >know that dedicated spi master modules on other processors I have >worked with have support for more than one device through a few chip >selects. > >Any help is appreciated,Device selection (i.e. the chip selects you mention above) needs to be implemented using some other form of I/O. The McBSP only implements the serial protocol. Best Regards John McCabe To reply by email replace 'nospam' with 'assen'
Reply by ●September 18, 20032003-09-18
Many typical SPI devices have active low chip selects. An easy thing to do to use a two-input OR gate in front of each chip select pin. One input is FSX, the other input comes from a spare DSP output pin. (You need a spare output for each device on the SPI bus.) Pull that output pin low to select a device and high to disable it. David L. Rick Hach Company drick@hach.com hemrin2000@yahoo.com (Jack) wrote in message news:<f313ed98.0309130852.644f2ed6@posting.google.com>...> I am using the McBSP as a spi master. Can it support only one slave > device or does it have the capability to support multiple slaves. I > know that dedicated spi master modules on other processors I have > worked with have support for more than one device through a few chip > selects. > > Any help is appreciated, > Jack
