On Wed, 06 Mar 2013 14:03:00 -0600, Tim Wescott <tim@seemywebsite.com> wrote:>On Wed, 06 Mar 2013 11:03:15 -0800, maury wrote: > >> On Wednesday, March 6, 2013 10:22:22 AM UTC-6, Tim Wescott wrote: >>> On Wed, 06 Mar 2013 08:39:46 -0600, clutchfft wrote: > I have managed >>> to decompose a signal via wavelet transform. I have a > signal with 256 >>> points. The transform produced 256 wavelet > coefficients. In FFT, we >>> use the odd/even samples and combine them > through a butterfly >>> operation using the twiddle factor = e^-i*2PI*kn/N. If by odd/even >>> samples you mean adjoining pairs of samples, then the butterfly >>> operations get carried out on a much more rich set of samples than that >>> (at least if you're doing the whole bit-reversed ordering thing). And I >>> would hardly call something as systemic and organized as the values of >>> the Euler identity at evenly spaced locations on the circle as a >>> "twiddle factor". -- Tim Wescott Control system and signal processing >>> consulting www.wescottdesign.com >> >> Hi Tim, >> Burris uses the term _twiddle factor_ in the paper. > >Well, my issue is with him, then. To me a "twiddle factor" is a constant >associated with a kludge that you use to iron out minor differences >between theory and reality, or a calibration constant that you use to >iron out differences between one unit and the next. It is (in my mind) >about the farthest thing from the appropriate term to use for the elegant >and self-consistent math that you see in any of the various Fourier >transforms. > >I suspect (particularly if it's a tutorial paper) that his intent was to >show the similarities between wavelets and the FFT (which, it is my >understanding, is one of the ways that you can view the FFT). But it >still sticks sideways in my craw. > >-- >My liberal friends think I'm a conservative kook. >My conservative friends think I'm a liberal kook. >Why am I not happy that they have found common ground? > >Tim Wescott, Communications, Control, Circuits & Software >http://www.wescottdesign.comHmm...I've found "twiddle factor" to be in pretty common use regarding the butterfly coefficients in an FFT stage. Wikipedia has a hint about the etymology: http://en.wikipedia.org/wiki/Twiddle_factor And one of Rick's articles talks about them: http://www.dsprelated.com/showarticle/107.php A brief search will probably yield quite a few results. I've seen quite a few formal papers that use the term this way. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
Wavelet Decomposition/ FFT
Started by ●March 6, 2013
Reply by ●March 6, 20132013-03-06
Eric Jacobsen <eric.jacobsen@ieee.org> wrote:> On Wed, 06 Mar 2013 14:03:00 -0600, Tim Wescott <tim@seemywebsite.com>(snip)>>Well, my issue is with him, then. To me a "twiddle factor" is a >> constant ssociated with a kludge that you use to iron out minor >> differences etween theory and reality, or a calibration constant >> that you use to iron out differences between one unit and the next. >> It is (in my mind) about the farthest thing from the appropriate term >> to use for the elegant and self-consistent math that you see in >> any of the various Fourier transforms.(snip)> Hmm...I've found "twiddle factor" to be in pretty common use regarding > the butterfly coefficients in an FFT stage. Wikipedia has a hint > about the etymology:> http://en.wikipedia.org/wiki/Twiddle_factorIt does seem to be the usual term, but I at least slightly agree with what Tim said about them. In the usual use, twiddle factors are unknown numbers, such as the position of a calibration pot. (That is, you twiddle it until the calibration is right.) -- glen
I am making some progress but there's something I'm not quite getting. For example, my signal x = [1 2 3 4]. The FFT of X = 10.0000 -2.0000 - 2.0000i -2.0000 -2.0000 + 2.0000i I then compute the Wavelet decomposition (2 levels using Haar filter). The wavelet coefficient after the 1st decomposition is Approximate_Level1 = 2.1213 4.9497 Detailed_Level1 = -0.7071 -0.7071 Then I apply the wavelet decomposition a second time using the approximate and detailed coefficients and end up with Approximate_Level2 = 5 Approximate_Level2 = -1 Detailed_Level2 = -2 Detailed_Level2 = 0 So basically, these last 4 wavelet coefficients are on the last level of the wavelet decomposition. The paper from Guo then indicates to compute the DFT of the wavelet filters. I use the wavelet coefficients and compute the DFT using the FFT for the approximate level coeffcients and then the detailed level coefficients : FFT([5 -1]) = 4 6 FFT([-2 0]) = -2 -2 I think I am close but I'm stuck. The paper from GUO indicates that through butterfly operations, use the twiddle factors to compute the FFT which should equal the results from the classic FFT that I provided on the top. I don't know how to combine the results from here to get the desired FFT result : 10.0000 -2.0000 - 2.0000i -2.0000 -2.0000 + 2.0000i
