I've been studying an approach to implementing a lookup table (LUT) to implement a sine function. The two msbs of the phase define the quadrant. I have decided that an 8 bit address for a single quadrant is sufficient with an 18 bit output. Another 11 bits of phase will give me sufficient resolution to interpolate the sin() to 18 bits. If you assume a straight line between the two endpoints the midpoint of each interpolated segment will have an error of ((Sin(high)-sin(low))/2)-sin(mid) Without considering rounding, this reaches a maximum at the last segment before the 90 degree point. I calculate about 4-5 ppm which is about the same as the quantization of an 18 bit number. There are two issues I have not come across regarding these LUTs. One is adding a bias to the index before converting to the sin() value for the table. Some would say the index 0 represents the phase 0 and the index 2^n represents 90 degrees. But this is 2^n+1 points which makes a LUT inefficient, especially in hardware. If a bias of half the lsb is added to the index before converting to a sin() value the value 0 to 2^n-1 becomes symmetrical with 2^n to 2^(n+1)-1 fitting a binary sized table properly. I assume this is commonly done and I just can't find a mention of it. The other issue is how to calculate the values for the table to give the best advantage to the linear interpolation. Rather than using the exact match to the end points stored in the table, an adjustment could be done to minimize the deviation over each interpolated segment. Without this, the errors are always in the same direction. With an adjustment the errors become bipolar and so will reduce the magnitude by half (approx). Is this commonly done? It will require a bit of computation to get these values, but even a rough approximation should improve the max error by a factor of two to around 2-3 ppm. Now if I can squeeze another 16 dB of SINAD out of my CODEC to take advantage of this resolution! lol One thing I learned while doing this is that near 0 degrees the sin() function is linear (we all knew that, right?) but near 90 degrees, the sin() function is essentially quadratic. Who would have thunk it? -- Rick
Sine Lookup Table with Linear Interpolation
Started by ●March 16, 2013
Reply by ●March 16, 20132013-03-16
this *should* be a relatively simple issue, but i am confused On 3/16/13 6:30 PM, rickman wrote:> I've been studying an approach to implementing a lookup table (LUT) to > implement a sine function. The two msbs of the phase define the > quadrant. I have decided that an 8 bit address for a single quadrant is > sufficient with an 18 bit output.10 bits or 1024 points. since you're doing linear interpolation, add one more, copy the zeroth point x[0] to the last x[1024] so you don't have to do any modulo (by ANDing with (1023-1) on the address of the second point. (probably not necessary for hardware implementation.) x[n] = sin( (pi/512)*n ) for 0 <= n <= 1024> Another 11 bits of phase will give me > sufficient resolution to interpolate the sin() to 18 bits.so a 21 bit total index. your frequency resolution would be 2^(-21) in cycles per sampling period or 2^(-21) * Fs. those 2 million values would be the only frequencies you can meaningful> > If you assume a straight line between the two endpoints the midpoint of > each interpolated segment will have an error of > ((Sin(high)-sin(low))/2)-sin(mid) >do you mean "+" instead of the first "-"? to be explicit: ( sin((pi/512)*(n+1)) + sin((pi/512)*n) )/2 - sin((pi/512)*(n+0.5)) that's the error in the middle. dunno if it's the max error, but it's might be.> Without considering rounding, this reaches a maximum at the last segment > before the 90 degree point.at both the 90 and 270 degree points. (or just before and after those points.)> I calculate about 4-5 ppm which is about the > same as the quantization of an 18 bit number. > > There are two issues I have not come across regarding these LUTs. One is > adding a bias to the index before converting to the sin() value for the > table. Some would say the index 0 represents the phase 0 and the index > 2^n represents 90 degrees. But this is 2^n+1 points which makes a LUT > inefficient, especially in hardware. If a bias of half the lsb is added > to the index before converting to a sin() value the value 0 to 2^n-1 > becomes symmetrical with 2^n to 2^(n+1)-1 fitting a binary sized table > properly. I assume this is commonly done and I just can't find a mention > of it.do you mean biasing by 1/2 of a point? then your max error will be *at* the 90 and 270 degree points and it will be slightly more than what you had before.> > The other issue is how to calculate the values for the table to give the > best advantage to the linear interpolation. Rather than using the exact > match to the end points stored in the table, an adjustment could be done > to minimize the deviation over each interpolated segment. Without this, > the errors are always in the same direction. With an adjustment the > errors become bipolar and so will reduce the magnitude by half (approx). > Is this commonly done? It will require a bit of computation to get these > values, but even a rough approximation should improve the max error by a > factor of two to around 2-3 ppm.if you assume an approximate quadratic behavior over that short segment, you can compute the straight line where the error in the middle is equal in magnitude (and opposite in sign) to the error at the end points. that's a closed form solution, i think. dunno if that is what you actually want for a sinusoidal waveform generator. i might think you want to minimize the mean square error.> Now if I can squeeze another 16 dB of SINAD out of my CODEC to take > advantage of this resolution! lol > > One thing I learned while doing this is that near 0 degrees the sin() > function is linear (we all knew that, right?) but near 90 degrees, the > sin() function is essentially quadratic. Who would have thunk it?Newton? Leibnitz? Gauss? sin(t + pi/2) = cos(t) -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
On Mar 16, 11:30�pm, rickman <gnu...@gmail.com> wrote:> I've been studying an approach to implementing a lookup table (LUT) to > implement a sine function. �The two msbs of the phase define the > quadrant. �I have decided that an 8 bit address for a single quadrant is > sufficient with an 18 bit output. �Another 11 bits of phase will give me > sufficient resolution to interpolate the sin() to 18 bits. > > If you assume a straight line between the two endpoints the midpoint of > each interpolated segment will have an error of > ((Sin(high)-sin(low))/2)-sin(mid) > > Without considering rounding, this reaches a maximum at the last segment > before the 90 degree point. �I calculate about 4-5 ppm which is about > the same as the quantization of an 18 bit number. > > There are two issues I have not come across regarding these LUTs. �One > is adding a bias to the index before converting to the sin() value for > the table. �Some would say the index 0 represents the phase 0 and the > index 2^n represents 90 degrees. �But this is 2^n+1 points which makes a > LUT inefficient, especially in hardware. �If a bias of half the lsb is > added to the index before converting to a sin() value the value 0 to > 2^n-1 becomes symmetrical with 2^n to 2^(n+1)-1 fitting a binary sized > table properly. �I assume this is commonly done and I just can't find a > mention of it. > > The other issue is how to calculate the values for the table to give the > best advantage to the linear interpolation. �Rather than using the exact > match to the end points stored in the table, an adjustment could be done > to minimize the deviation over each interpolated segment. �Without this, > the errors are always in the same direction. �With an adjustment the > errors become bipolar and so will reduce the magnitude by half (approx). > � Is this commonly done? �It will require a bit of computation to get > these values, but even a rough approximation should improve the max > error by a factor of two to around 2-3 ppm. > > Now if I can squeeze another 16 dB of SINAD out of my CODEC to take > advantage of this resolution! �lol > > One thing I learned while doing this is that near 0 degrees the sin() > function is linear (we all knew that, right?) but near 90 degrees, the > sin() function is essentially quadratic. �Who would have thunk it? > > -- > > Rickwhy not skip the lut and just do a full sine approximation something like this, page 53-54 http://www.emt.uni-linz.ac.at/education/Inhalte/pr_mderf/downloads/ADSP-2181/Using%20the%20ADSP-2100%20Family%20Volume%201/Using%20the%20ADSP-2100%20Family%20Volume%201.pdf -Lasse
In comp.dsp rickman <gnuarm@gmail.com> wrote:> I've been studying an approach to implementing a lookup table (LUT) to > implement a sine function. The two msbs of the phase define the > quadrant. I have decided that an 8 bit address for a single quadrant is > sufficient with an 18 bit output. Another 11 bits of phase will give me > sufficient resolution to interpolate the sin() to 18 bits.In the early days of MOS ROMs, there were commercial such ROMs, I believe from National. (And when ROMs were much smaller than today.) The data sheet has (I can't find it right now, but it is around somewere) the combination of ROMs and TTL adders to do the interpolation.> If you assume a straight line between the two endpoints the midpoint of > each interpolated segment will have an error of > ((Sin(high)-sin(low))/2)-sin(mid)> Without considering rounding, this reaches a maximum at the last segment > before the 90 degree point. I calculate about 4-5 ppm which is about > the same as the quantization of an 18 bit number.I presume the ROM designers had all this figured out.> There are two issues I have not come across regarding these LUTs. One > is adding a bias to the index before converting to the sin() value for > the table. Some would say the index 0 represents the phase 0 and the > index 2^n represents 90 degrees. But this is 2^n+1 points which makes a > LUT inefficient, especially in hardware. If a bias of half the lsb is > added to the index before converting to a sin() value the value 0 to > 2^n-1 becomes symmetrical with 2^n to 2^(n+1)-1 fitting a binary sized > table properly. I assume this is commonly done and I just can't find a > mention of it.I don't remember anymore. But since you have the additional bit to do the interpolation, it should be easy.> The other issue is how to calculate the values for the table to give the > best advantage to the linear interpolation. Rather than using the exact > match to the end points stored in the table, an adjustment could be done > to minimize the deviation over each interpolated segment. Without this, > the errors are always in the same direction. With an adjustment the > errors become bipolar and so will reduce the magnitude by half (approx). > Is this commonly done? It will require a bit of computation to get > these values, but even a rough approximation should improve the max > error by a factor of two to around 2-3 ppm.I am not sure how you are thinking about doing it. I believe that some of the bits that go into the MSB ROM also go into the lower ROM to select the interpolation slope, and then additional bits to select the actual value. Say you have a 1024x10 ROM for the first one, then want to interpolate that. How many bits of linear interpolation can be done? (That is, before linear isn't close enough any more.) Then the appropriate number of low bits and high bits, but not the in between bits, go into the interpolation ROM, which is then added to the other ROMs output.> Now if I can squeeze another 16 dB of SINAD out of my CODEC to take > advantage of this resolution! lol> One thing I learned while doing this is that near 0 degrees the sin() > function is linear (we all knew that, right?) but near 90 degrees, the > sin() function is essentially quadratic. Who would have thunk it?Well, cos() is known to be quadratic near zero. I once knew someone with a homework problem something like: Take a string all the way around the earth at the equator, and add (if I remember right) 3m. (Assuming the earth is a perfect sphere.) If the string is at a uniform height around the earth, how far from the surface is it? Now, pull it up at one point. How far is that point above the surface? More specifically, as I originally heard it, is it higher than the height of a specific nine story library? As I remember it, the usual small angle approximations to trig. functions aren't enough to do this. The next term is needed. The 3m added might not be right, as the answer is close enough to the certain building height to need the additional term. -- glen
rickman wrote:> I've been studying an approach to implementing a lookup table (LUT) to > implement a sine function. The two msbs of the phase define the > quadrant. I have decided that an 8 bit address for a single quadrant is > sufficient with an 18 bit output. Another 11 bits of phase will give me > sufficient resolution to interpolate the sin() to 18 bits. > > If you assume a straight line between the two endpoints the midpoint of > each interpolated segment will have an error of > ((Sin(high)-sin(low))/2)-sin(mid) > > Without considering rounding, this reaches a maximum at the last segment > before the 90 degree point. I calculate about 4-5 ppm which is about the > same as the quantization of an 18 bit number. > > There are two issues I have not come across regarding these LUTs. One is > adding a bias to the index before converting to the sin() value for the > table. Some would say the index 0 represents the phase 0 and the index > 2^n represents 90 degrees. But this is 2^n+1 points which makes a LUT > inefficient, especially in hardware. If a bias of half the lsb is added > to the index before converting to a sin() value the value 0 to 2^n-1 > becomes symmetrical with 2^n to 2^(n+1)-1 fitting a binary sized table > properly. I assume this is commonly done and I just can't find a mention > of it. > > The other issue is how to calculate the values for the table to give the > best advantage to the linear interpolation. Rather than using the exact > match to the end points stored in the table, an adjustment could be done > to minimize the deviation over each interpolated segment. Without this, > the errors are always in the same direction. With an adjustment the > errors become bipolar and so will reduce the magnitude by half (approx). > Is this commonly done? It will require a bit of computation to get these > values, but even a rough approximation should improve the max error by a > factor of two to around 2-3 ppm. > > Now if I can squeeze another 16 dB of SINAD out of my CODEC to take > advantage of this resolution! lol > > One thing I learned while doing this is that near 0 degrees the sin() > function is linear (we all knew that, right?) but near 90 degrees, the > sin() function is essentially quadratic. Who would have thunk it? >Sounds like you are making excellent improvements on the standard ho-hum algorithms; the net result will be superior to anything done out there (commercially). With the proper offsets, one needs only 22.5 degrees of lookup ("bounce" off each multiple of 45 degrees).
On 3/16/2013 5:30 PM, rickman wrote:> I've been studying an approach to implementing a lookup table (LUT) to > implement a sine function. The two msbs of the phase define the > quadrant. I have decided that an 8 bit address for a single quadrant is > sufficient with an 18 bit output. Another 11 bits of phase will give me > sufficient resolution to interpolate the sin() to 18 bits.An optimal one quadrant LUT with 256 entries and linear interpolation makes for sine approximation with accuracy about 16 bits. If there is a need for better precision, consider different approaches. Vladimir Vassilevsky DSP and Mixed Signal Designs www.abvolt.com
Reply by ●March 17, 20132013-03-17
In comp.dsp rickman <gnuarm@gmail.com> wrote:> I've been studying an approach to implementing a lookup table (LUT) to > implement a sine function. The two msbs of the phase define the > quadrant. I have decided that an 8 bit address for a single quadrant is > sufficient with an 18 bit output. Another 11 bits of phase will give me > sufficient resolution to interpolate the sin() to 18 bits.> If you assume a straight line between the two endpoints the midpoint of > each interpolated segment will have an error of > ((Sin(high)-sin(low))/2)-sin(mid)See: http://ia601506.us.archive.org/8/items/bitsavers_nationaldaMOSIntegratedCircuits_20716690/1972_National_MOS_Integrated_Circuits.pdf The description starts on page 273. -- glen
On Sat, 16 Mar 2013 18:30:51 -0400, rickman wrote:> There are two issues I have not come across regarding these LUTs. One > is adding a bias to the index before converting to the sin() value for > the table. Some would say the index 0 represents the phase 0 and the > index 2^n represents 90 degrees. But this is 2^n+1 points which makes a > LUT inefficient, especially in hardware.An n-bit table has 2^n+1 entries for 2^n ranges. Range i has endpoints of table[i] and table[i+1]. The final range has i=(1<<n)-1, so the last entry in the table is table[1<<n], not table[(1<<n)-1].> One thing I learned while doing this is that near 0 degrees the sin() > function is linear (we all knew that, right?) but near 90 degrees, the > sin() function is essentially quadratic. Who would have thunk it?sin((pi/2)+x) = sin((pi/2)-x) = cos(x), and the Maclaurin series for cos(x) is: cos(x) = 1 - (x^2)/2! + (x^4)/4! - ...
On 3/16/2013 7:13 PM, robert bristow-johnson wrote:> > this *should* be a relatively simple issue, but i am confused > > On 3/16/13 6:30 PM, rickman wrote: >> I've been studying an approach to implementing a lookup table (LUT) to >> implement a sine function. The two msbs of the phase define the >> quadrant. I have decided that an 8 bit address for a single quadrant is >> sufficient with an 18 bit output. > > 10 bits or 1024 points. since you're doing linear interpolation, add one > more, copy the zeroth point x[0] to the last x[1024] so you don't have > to do any modulo (by ANDing with (1023-1) on the address of the second > point. (probably not necessary for hardware implementation.) > > > x[n] = sin( (pi/512)*n ) for 0 <= n <= 1024So you are suggesting a table with 2^n+1 entries? Not such a great idea in some apps, like hardware. What is the advantage? Also, why 10 bit address for a 1024 element table? My calculations indicate a linear interpolation can be done with 4 ppm accuracy with a 256 element LUT. I'm not completely finished my simulation, but I'm pretty confident this much is corrrect.>> Another 11 bits of phase will give me >> sufficient resolution to interpolate the sin() to 18 bits. > > so a 21 bit total index. your frequency resolution would be 2^(-21) in > cycles per sampling period or 2^(-21) * Fs. those 2 million values would > be the only frequencies you can meaningfulNo, that is the phase sent to the LUT. The total phase accumulator can be larger as the need requires.>> If you assume a straight line between the two endpoints the midpoint of >> each interpolated segment will have an error of >> ((Sin(high)-sin(low))/2)-sin(mid) >> > > do you mean "+" instead of the first "-"? to be explicit: > > ( sin((pi/512)*(n+1)) + sin((pi/512)*n) )/2 - sin((pi/512)*(n+0.5)) > > that's the error in the middle. dunno if it's the max error, but it's > might be.Yes, thanks for the correction. The max error? I'm not so worried about that exactly. The error is a curve with the max magnitude near the middle if nothing further is done to minimize it.>> Without considering rounding, this reaches a maximum at the last segment >> before the 90 degree point. > > at both the 90 and 270 degree points. (or just before and after those > points.)I'm talking about the LUT. The LUT only considers the first quadrant.>> I calculate about 4-5 ppm which is about the >> same as the quantization of an 18 bit number. >> >> There are two issues I have not come across regarding these LUTs. One is >> adding a bias to the index before converting to the sin() value for the >> table. Some would say the index 0 represents the phase 0 and the index >> 2^n represents 90 degrees. But this is 2^n+1 points which makes a LUT >> inefficient, especially in hardware. If a bias of half the lsb is added >> to the index before converting to a sin() value the value 0 to 2^n-1 >> becomes symmetrical with 2^n to 2^(n+1)-1 fitting a binary sized table >> properly. I assume this is commonly done and I just can't find a mention >> of it. > > do you mean biasing by 1/2 of a point? then your max error will be *at* > the 90 and 270 degree points and it will be slightly more than what you > had before.No, not quite right. There is a LUT with points spaced at 90/255 degrees apart starting at just above 0 degrees. The values between points in the table are interpolated with a maximum deviation near the center of the interpolation. Next to 90 degrees the interpolation is using the maximum interpolation factor which will result in a value as close as you can get to the correct value if the end points are used to construct the interpolation line. 90 degrees itself won't actually be represented, but rather points on either side, 90�delta where delta is 360� / 2^(n+1) with n being the number of bits in the input to the sin function.>> The other issue is how to calculate the values for the table to give the >> best advantage to the linear interpolation. Rather than using the exact >> match to the end points stored in the table, an adjustment could be done >> to minimize the deviation over each interpolated segment. Without this, >> the errors are always in the same direction. With an adjustment the >> errors become bipolar and so will reduce the magnitude by half (approx). >> Is this commonly done? It will require a bit of computation to get these >> values, but even a rough approximation should improve the max error by a >> factor of two to around 2-3 ppm. > > if you assume an approximate quadratic behavior over that short segment, > you can compute the straight line where the error in the middle is equal > in magnitude (and opposite in sign) to the error at the end points. > that's a closed form solution, i think.Yes, it is a little tricky because at this point we are working with integer math (or technically fixed point I suppose). Rounding errors is what this is all about. I've done some spreadsheet simulations and I have some pretty good results. I updated it a bit to generalize it to the LUT size and I keep getting the same max error counts (adjusted to work with integers rather than fractions) �3 no matter what the size of the interpolation factor. I don't expect this and I think I have something wrong in the calculations. I'll need to resolve this.> dunno if that is what you actually want for a sinusoidal waveform > generator. i might think you want to minimize the mean square error.We are talking about the lsbs of a 20+ bit word. Do you think there will be much of a difference in result? I need to actually be able to do the calculations and get this done rather than continue to work on the process. Also, each end point affects two lines, so there are tradeoffs, make one better and the other worse? It seems to get complicated very quickly.>> Now if I can squeeze another 16 dB of SINAD out of my CODEC to take >> advantage of this resolution! lol >> >> One thing I learned while doing this is that near 0 degrees the sin() >> function is linear (we all knew that, right?) but near 90 degrees, the >> sin() function is essentially quadratic. Who would have thunk it? > > Newton? Leibnitz? Gauss? > > sin(t + pi/2) = cos(t)How does that imply a quadratic curve at 90 degrees? At least I think like the greats! -- Rick
On 3/16/2013 8:02 PM, langwadt@fonz.dk wrote:> On Mar 16, 11:30 pm, rickman<gnu...@gmail.com> wrote: >> I've been studying an approach to implementing a lookup table (LUT) to >> implement a sine function. The two msbs of the phase define the >> quadrant. I have decided that an 8 bit address for a single quadrant is >> sufficient with an 18 bit output. Another 11 bits of phase will give me >> sufficient resolution to interpolate the sin() to 18 bits. >> >> If you assume a straight line between the two endpoints the midpoint of >> each interpolated segment will have an error of >> ((Sin(high)-sin(low))/2)-sin(mid) >> >> Without considering rounding, this reaches a maximum at the last segment >> before the 90 degree point. I calculate about 4-5 ppm which is about >> the same as the quantization of an 18 bit number. >> >> There are two issues I have not come across regarding these LUTs. One >> is adding a bias to the index before converting to the sin() value for >> the table. Some would say the index 0 represents the phase 0 and the >> index 2^n represents 90 degrees. But this is 2^n+1 points which makes a >> LUT inefficient, especially in hardware. If a bias of half the lsb is >> added to the index before converting to a sin() value the value 0 to >> 2^n-1 becomes symmetrical with 2^n to 2^(n+1)-1 fitting a binary sized >> table properly. I assume this is commonly done and I just can't find a >> mention of it. >> >> The other issue is how to calculate the values for the table to give the >> best advantage to the linear interpolation. Rather than using the exact >> match to the end points stored in the table, an adjustment could be done >> to minimize the deviation over each interpolated segment. Without this, >> the errors are always in the same direction. With an adjustment the >> errors become bipolar and so will reduce the magnitude by half (approx). >> Is this commonly done? It will require a bit of computation to get >> these values, but even a rough approximation should improve the max >> error by a factor of two to around 2-3 ppm. >> >> Now if I can squeeze another 16 dB of SINAD out of my CODEC to take >> advantage of this resolution! lol >> >> One thing I learned while doing this is that near 0 degrees the sin() >> function is linear (we all knew that, right?) but near 90 degrees, the >> sin() function is essentially quadratic. Who would have thunk it? >> >> -- >> >> Rick > > why not skip the lut and just do a full sine approximation > > something like this, page 53-54 > > http://www.emt.uni-linz.ac.at/education/Inhalte/pr_mderf/downloads/ADSP-2181/Using%20the%20ADSP-2100%20Family%20Volume%201/Using%20the%20ADSP-2100%20Family%20Volume%201.pdfI'm not sure this would be easier. The LUT an interpolation require a reasonable amount of logic. This requires raising X to the 5th power and five constant multiplies. My FPGA doesn't have multipliers and this may be too much for the poor little chip. I suppose I could do some of this with a LUT and linear interpolation... lol -- Rick
