Jon Harris wrote: ...> It seems that you are implying that you can't make amplitude changes with an AP > filter. The standard technique that allows this is to combine the original > unfiltered input with the AP filtered output in various proportions to achieve > amplitude changes. For example, it is easy to make a peaking or notch filter > with a 2nd order AP. At the center frequency, the AP output is shifted 180 > degrees from the input. So adding that to the original gives you a notch and > subtracting it gives you a peak. Those are the easy cases. I was wondering > about other things such as shelving.An all-pass in parallel with the original signal or another all-pass isn't an all-pass structure. If you could affect amplitude with a cascade of all-passes, they wouldn't be all-passes, would they? :-) But now I see what you mean. If pressed to win a bet, I think I could do it over a decade band, but it wouldn't be worth it. I'm thinking of parallel channels two paths per channel roughly in quadrature and ... Forget it! Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Allpass Filter Matlab Functions
Started by ●November 1, 2004
Reply by ●November 4, 20042004-11-04
