Hi everyone, I must say that this question may sound pretty silly, but I honestly failed to find an answer. A couple of days ago I found an 'old' oscilloscope in the lab which reported a 1 GHz bandwidth, but when we looked up the specs it reported a 20 MS/s sampling rate. Now, my background is probably not supporting me much here, but a 1 GHz bandwidth signal cannot be represented with such a low sampling rate (Nyquist-Shannon sampling theorem). What am I missing here? (I guess a lot) I started to look around in the labs and in catalogs and found that most of the time oscilloscopes' sampling rates are - at least - twice as the input bandwidth, which make perfect sense. Even in the case of oversampling I may understand the reasoning behind (easier to make anti-alias analog filter), but when sampling rate is below Nyquist limit, how can the signal be reproduced correctly? I am aware of the bandpass sampling technique for non-baseband signals, but can an oscilloscope be targeted to such a particular case? I'm sure there's a lot of literature on the topic but I must have missed it in my searches. Thanks, Al -- A: Because it fouls the order in which people normally read text. Q: Why is top-posting such a bad thing? A: Top-posting. Q: What is the most annoying thing on usenet and in e-mail?
why a 1 GHz oscilloscope has a 20 MS/s sampling rate
Started by ●April 4, 2013
Reply by ●April 4, 20132013-04-04
On Thursday, April 4, 2013 3:36:39 PM UTC-4, alb wrote:> Hi everyone, > > > > I must say that this question may sound pretty silly, but I honestly > > failed to find an answer. > > > > A couple of days ago I found an 'old' oscilloscope in the lab which > > reported a 1 GHz bandwidth, but when we looked up the specs it reported > > a 20 MS/s sampling rate. > > > > Now, my background is probably not supporting me much here, but a 1 GHz > > bandwidth signal cannot be represented with such a low sampling rate > > (Nyquist-Shannon sampling theorem). What am I missing here? (I guess a lot) > > > > I started to look around in the labs and in catalogs and found that most > > of the time oscilloscopes' sampling rates are - at least - twice as the > > input bandwidth, which make perfect sense. Even in the case of > > oversampling I may understand the reasoning behind (easier to make > > anti-alias analog filter), but when sampling rate is below Nyquist > > limit, how can the signal be reproduced correctly? > > > > I am aware of the bandpass sampling technique for non-baseband signals, > > but can an oscilloscope be targeted to such a particular case? > > > > I'm sure there's a lot of literature on the topic but I must have missed > > it in my searches. > > > > Thanks, > > > > Al > > > > -- > > A: Because it fouls the order in which people normally read text. > > Q: Why is top-posting such a bad thing? > > A: Top-posting. > > Q: What is the most annoying thing on usenet and in e-mail?Check out this link, under "sampling modes". With a repetitive waveform you can increase the effective sampling rate, but it doesn't work if you need single-shot capture. http://www.ni.com/white-paper/4333/en Bob
Reply by ●April 5, 20132013-04-05
On 04/04/2013 21:56, radams2000@gmail.com wrote: []>> A couple of days ago I found an 'old' oscilloscope in the lab >> which >> >> reported a 1 GHz bandwidth, but when we looked up the specs it >> reported >> >> a 20 MS/s sampling rate.[]> Check out this link, under "sampling modes". With a repetitive > waveform you can increase the effective sampling rate, but it doesn't > work if you need single-shot capture. > > http://www.ni.com/white-paper/4333/enthanks a lot, I was not aware of such kind of sampling modes. Now is much more clear why our signals didn't look at all what we expected!
