Hello everybody, I would like to post-proccess output LDR file that contains description of my program (and hex code as well). This post-proccessed file will be used by VisualDSP to FILL L2 memory space of BF535, or by JTAG debugger to fill external memory (SDRAM). Since LDR file stores HEX op-codes as they are (Intel HEX-32 format), and memory FILL command uses little endian format, things are getting mixed-up. Any suggestions how to proccess LDR (or DXE) file into format used by FILL operation (or JTAG download format) ? appreciate your comments, Dubi
VisualDSP, HEX op-codes from LDR file
Started by ●August 25, 2003
Reply by ●August 26, 20032003-08-26
"DB" <dbiruski@yahoo.com> wrote in news:bidoa6$gmd$1@news01.intel.com:> Any suggestions how to proccess LDR (or DXE) file into format used by > FILL operation (or JTAG download format) ?The ICE will use the ELF file (.DXE). Read up on ELF format. I think you can get the document on the standard from Intel's website, part of the Tool Interchange Standard. ADI provides elfdump.exe for dumping out DXE's for inspection. -- Kenneth Porter http://www.sewingwitch.com/ken/
"Kenneth Porter" <ken.blacklist@sewingwitch.com> wrote in message news:Xns93E34216FDFF4shivawellcom@64.164.98.50...> "DB" <dbiruski@yahoo.com> wrote in news:bidoa6$gmd$1@news01.intel.com: > > > Any suggestions how to proccess LDR (or DXE) file into format used by > > FILL operation (or JTAG download format) ? > > The ICE will use the ELF file (.DXE). Read up on ELF format. I think you > can get the document on the standard from Intel's website, part of theTool> Interchange Standard. ADI provides elfdump.exe for dumping out DXE's for > inspection.Kenneth thanks for the hint - elfdump (and its switches) is what I was looking for. I just tried it, and I am getting exactly what I need. thanks, Dubi
