LTI vs non-LTI
Started by manishp April 28, 2013
On Sun, 28 Apr 2013 09:58:15 -0700, Rick Lyons wrote:
> > I've always thought of mixers as being nonlinear because a mixer's > output contains spectral components that did not exist at either of its > two inputs.
"Have always thought"? That's wishy-washy. Most physical mixers are not linear from the LO port -- generally the local oscillator signal gets badly distorted. But decent mixers _are_ linear going from the RF port to the IF port, and there's a lot of profit in treating them as such in analysis. (Note, too, that mixers are often the first point of distortion in a radio circuit, because you _want_ them to be perfectly linear, but you have to _work_ to make them so.) -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
On Sun, 28 Apr 2013 17:12:07 +0000, Eric Jacobsen wrote:
<< snip >>
> Another good example was mentioned from different perspectives by Tim > and Rick, namely a mixer. Mixers, when looked at as a whole, are > substantially non-linear and often implemented with non-linear devices. > However, if we constrain out view to a particular region of interest, > say a sub-section of bandwidth, and design it properly, the mixer will > behave linearly within that region of interest, which means we may be > able to treat and analyze it like a linear function. > > So, as is often the case, it depends on your definitions of "linear" and > "time invariant". ;)
It can be more than that. I did not state it in my original response, but in my opinion the choice to approximate one's system as linear and time invariant should always be a conscious one. That way, when your assumption breaks down and you need to make your approximation more accurate you'll be better equipped to know whether you should use a decorated linear approximation (i.e., treat a system as linear with quantization noise), or if you should throw your linear approximation out the window, or if there is some middle path. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
About four years ago, there was a discussion in
this newsgroup with the subject "Is complex
conjugation an LTI operation?" Perhaps some of
the stuff there can be incorporated here too
leading to more fun arguments about what is meant
by a linear operation. After all, complex baseband
signals are everyday stuff for DSP folks.
Dilip Sarwate
Rick Lyons <R.Lyons@_bogus_ieee.org> wrote:
(snip)
> Hi manishp, > I may have to 'take back' my comment about > the absolute value' operation being nonlinear. > I'll have to think more about that issue.
Seems to me that absolute value should be considered non-linear. It is at least not an analytic function, which makes it not so useful in some cases. Least-squares is used not because it is the best solution to the problem, but because the math is easier. Statisticians like absolute value (and so least absolute value for fits) better, but the math is much harder. Also, median is supposed to be better than mean, but again the math is easier for mean. -- glen
> Upsampling and downsampling are time variant
Sir, can you please elaborate? Essentially, you are saying that if I take a sequence, send it to downsampler at different times, I would see different output. Isn't this an issue in practical applications Thanks, manish PS: thanks to all others for responding to my original question
On Mon, 29 Apr 2013 07:50:10 -0500, manishp wrote:
>> Upsampling and downsampling are time variant > > Sir, can you please elaborate? > Essentially, you are saying that if I take a sequence, send it to > downsampler at different times, I would see different output. > > Isn't this an issue in practical applications > > Thanks, manish > > PS: thanks to all others for responding to my original question
Sampling is time varying because the input is ignored for all time except the sampling instant. If you're willing to use impulse functionals in your analysis then sampling is just a form of mixing, in the linear, time- varying sense that I was advocating earlier. Downsampling in the discrete-time world is much like sampling from continuous-time to discrete time, and can be modeled similarly. If you're willing to view continuous-time as the ultimate in discrete-time domains, then it's exactly the same (but taking that view is a hell of a leap, and not to be taken lightly without really thinking through the mathematical implications). I seem to be disagreeing with Rick a lot these days, but upsampling by an integer amount (or, for that matter reconstructing to continuous time), when expressed the way I normally view it, is not time-varying. Rather, it is just taking the "train-of-impulses" and running them through a hold filter. If you view the discrete-time domain as entirely separate from the continuous-time domain, or if you view two different discrete-time domains as being disjoint and not related, then upsampling by an integer amount either is time varying, or the concept is invalid -- I'm not sure which. Upsampling by a non-integer amount _is_ time varying. The easiest way to determine this is by noting that upsampling by any rational but non- integer ratio is tantamount to upsampling by an integer ratio, then downsampling by some other integer ratio -- and that downsampling step is time-varying, which "poisons" the whole process. -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
On 2013-04-29 04:14, glen herrmannsfeldt wrote:
> Also, median is supposed to be better than mean, but again > the math is easier for mean.
Better for what? In which sense? OF course, median returns (if odd) a value belonging to the set, but this does not mean this value is better. It depends. bye, -- piergiorgio
>integer amount (or, for that matter reconstructing to continuous time), >when expressed the way I normally view it, is not time-varying. Rather, >it is just taking the "train-of-impulses" and running them through a hold
>filter. > >If you view the discrete-time domain as entirely separate from the >continuous-time domain, or if you view two different discrete-time >domains as being disjoint and not related, then upsampling by an integer >amount either is time varying, or the concept is invalid -- I'm not sure >which.
In what way does an upsampling operation even change a signal?
Piergiorgio Sartor <piergiorgio.sartor.this.should.not.be.used@nexgo.removethis.de> wrote:
> On 2013-04-29 04:14, glen herrmannsfeldt wrote: > [...] >> Also, median is supposed to be better than mean, but again >> the math is easier for mean.
Better in the statistical, or statistician sense.
> OF course, median returns (if odd) a value > belonging to the set, but this does not mean > this value is better. It depends.
If you know that the data samples a Guassian distribution, then mean and standard deviation should have the appropriate statistical properties. Often, though, they are used where the data is known not to be Gaussian, but where they are easier to compute. The distribution of home sale prices is not Gaussian, and you will more often see median used in economic reports on home prices. -- glen
(snip)
> Sampling is time varying because the input is ignored for all time except > the sampling instant. If you're willing to use impulse functionals in > your analysis then sampling is just a form of mixing, in the linear, time- > varying sense that I was advocating earlier.
> Downsampling in the discrete-time world is much like sampling from > continuous-time to discrete time, and can be modeled similarly. If > you're willing to view continuous-time as the ultimate in discrete-time > domains, then it's exactly the same (but taking that view is a hell of a > leap, and not to be taken lightly without really thinking through the > mathematical implications).
Well, assuming that the signal has the appropriate band limiting. Consider starting with a continuous time signal that is perfectly band limited. Now sample it at different sampling rates above the Nyquist rate, with an ideal sampler. All then contain the exact same information, which is that in the original signal.
> I seem to be disagreeing with Rick a lot these days, but upsampling by an > integer amount (or, for that matter reconstructing to continuous time), > when expressed the way I normally view it, is not time-varying. Rather, > it is just taking the "train-of-impulses" and running them through a hold > filter.
> If you view the discrete-time domain as entirely separate from the > continuous-time domain, or if you view two different discrete-time > domains as being disjoint and not related, then upsampling by an integer > amount either is time varying, or the concept is invalid -- I'm not sure > which.
> Upsampling by a non-integer amount _is_ time varying. The easiest way to > determine this is by noting that upsampling by any rational but non- > integer ratio is tantamount to upsampling by an integer ratio, then > downsampling by some other integer ratio -- and that downsampling step is > time-varying, which "poisons" the whole process.
Maybe I don't understand "time varying" in the sense you use it here, but up sampling by a rational factor should give the same signal you would have seen sampling the original at the higher rate. (Assuming the filters are all ideal, which they usually aren't, except in homework problems.) -- glen
