Help with All-Pass Filter Design Method
Started by westocl May 2, 2013
On Thursday, May 2, 2013 6:16:54 AM UTC-7, westocl wrote:
> I would like to generate coefficents for an all pass that approximates a > desired group delay response. I was surfing the net for methods and came > across a ieee article that uses the hilber transform method to design such > a filter. > > http://ieeexplore.ieee.org/xpl/login.jsp?tp=&arnumber=112149&url=http%3A%2F%2Fieeexplore.ieee.org%2Fxpls%2Fabs_all.jsp%3Farnumber%3D112149 >
You might try including a more coherent form of citation with your IEEE reference such as: Digital all-pass filter design through discrete Hilbert transform Circuits and Systems, 1990., IEEE International Symposium on Date of Conference: 1-3 May 1990 Author(s): Reddy, G.R. Swamy, M.N.S. Then people might know that the paper is from a Circuits and Systems Society conference paper and might require a Circuits and Systems Society membership for access (for those without some sort of library privileges). Also a simple search on the title and authors gives some available papers that discuss the methods in the cited paper and offer alternatives: A DIGITAL ALL-PASS FILTER DESIGN BASED ON DISCRETE HILBERT TRANSFORM G. Jovanovic-Dolecek and J. D�az-Carmona available at: http://www.ux.uis.no/norsig/norsig2002/Proceedings/papers/cr1027.pdf Proc. of the 9th Int. Conference on Digital Audio Effects (DAFx-06), Montreal, Canada, September 18-20, 2006 ROBUST DESIGN OF VERY HIGH-ORDER ALLPASS DISPERSION FILTERS Jonathan S. Abel* Julius O. Smith available at: http://www.dafx.ca/proceedings/papers/p_013.pdf ...
> > I figured id throw the equations in Matlab and see what if i could mimic > the resuls and got stuck and the wrong result.
Does this mean you tried your code on the example in the paper and your code didn't work? If not, why not? Dale B. Dalrymple
