complex exponential
Started by manishp June 15, 2013
Sirs,
I am going through comllex description I wiki ...
In one place, it is written "eix traces unit circle ... as x ranges through
different real x"
But when I take different values of x such as 30, 45, 60 I see the value of
sinx on x and cosx on y axis eventually leads to values < 1. Only for x eq
0 and 90, I see val eq 1.
Can someone clarify pls that eix does not trace unit circle for all values
of x
Thanks, manish
"manishp" <58525@dsprelated> writes:
> Sirs, > I am going through comllex description I wiki ... > In one place, it is written "eix traces unit circle ... as x ranges through > different real x" > But when I take different values of x such as 30, 45, 60 I see the value of > sinx on x and cosx on y axis eventually leads to values < 1. Only for x eq > 0 and 90, I see val eq 1. > > Can someone clarify pls that eix does not trace unit circle for all values > of x
Manish, The magnitude r of a point (x, y) in a Cartesian coordinate plane is defined as r = sqrt(x^2 + y^2). If x = cos(theta) y = sin(theta) then r = sqrt(cos^2(theta) + sin^2(theta)). Now there is a trig identity that states cos^2(theta) + sin^2(theta) = 1 for any value of theta. Thus the radius r of the circle traced by x = cos(theta) y = sin(theta) is indeed (precisely) 1, even though the x or y values are less than 1 at certain values of theta. Basic trigonometry (I learned it in high school). If you don't know it, learn it ASAP as it is required for this field. -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
On Fri, 14 Jun 2013 22:50:46 -0500, manishp wrote:
> Sirs, > I am going through comllex description I wiki ... In one place, it is > written "eix traces unit circle ... as x ranges through different real > x" > But when I take different values of x such as 30, 45, 60 I see the value > of sinx on x and cosx on y axis eventually leads to values < 1. Only for > x eq 0 and 90, I see val eq 1. > > Can someone clarify pls that eix does not trace unit circle for all > values of x > > Thanks, manish
I'm not sure what part you're not understanding. If you plot sin x on the x axis, and cos x on the y axis, you should plot a circle with radius 1. You're trying to do math experimentally again. Try looking up your trig identities for the value of (cos x)^2 + (sin x)^2. What is it equal to for x a real number? What does that tell you about e^(i x) and the unit circle? -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
>On Fri, 14 Jun 2013 22:50:46 -0500, manishp wrote: > >> Sirs, >> I am going through comllex description I wiki ... In one place, it is >> written "eix traces unit circle ... as x ranges through different real >> x" >> But when I take different values of x such as 30, 45, 60 I see the
value
for
>> x eq 0 and 90, I see val eq 1. >> >> Can someone clarify pls that eix does not trace unit circle for all >> values of x >> >> Thanks, manish > >I'm not sure what part you're not understanding. If you plot sin x on >the x axis, and cos x on the y axis, you should plot a circle with radius
>1. > >You're trying to do math experimentally again. Try looking up your trig >identities for the value of (cos x)^2 + (sin x)^2. What is it equal to >for x a real number? What does that tell you about e^(i x) and the unit >circle? > >-- >My liberal friends think I'm a conservative kook. >My conservative friends think I'm a liberal kook. >Why am I not happy that they have found common ground? > >Tim Wescott, Communications, Control, Circuits & Software >http://www.wescottdesign.com
Thanks. Yes, I should have tried solving on a piece of paper first ...
On Fri, 14 Jun 2013 22:50:46 -0500, "manishp" <58525@dsprelated>
wrote:
>Sirs, >I am going through comllex description I wiki ... >In one place, it is written "eix traces unit circle ... as x ranges through >different real x" >But when I take different values of x such as 30, 45, 60 I see the value of >sinx on x and cosx on y axis eventually leads to values < 1. Only for x eq >0 and 90, I see val eq 1. > >Can someone clarify pls that eix does not trace unit circle for all values >of x > >Thanks, manish
Hello manish, Check the following web page. It might be of some help to you. http://www.dsprelated.com/showarticle/192.php [-Rick-] No. 6: "Where am I?" No. 2: "In the Village." No. 6: "What do you want?" No. 2: "Information." No. 6: "Who are you?" No. 2: "I am the new No. 2." No. 6: "Who is No. 1?" No. 2: "You are No. 6." No. 6: "I am not a number. I am a free man!"
>On Fri, 14 Jun 2013 22:50:46 -0500, "manishp" <58525@dsprelated> >wrote: > >>Sirs, >>I am going through comllex description I wiki ... >>In one place, it is written "eix traces unit circle ... as x ranges
through
>>different real x" >>But when I take different values of x such as 30, 45, 60 I see the value
of
eq
>>0 and 90, I see val eq 1. >> >>Can someone clarify pls that eix does not trace unit circle for all
values
>>of x >> >>Thanks, manish > >Hello manish, > Check the following web page. It might be of >some help to you. > >http://www.dsprelated.com/showarticle/192.php > >[-Rick-] >No. 6: "Where am I?" >No. 2: "In the Village." >No. 6: "What do you want?" >No. 2: "Information." >No. 6: "Who are you?" >No. 2: "I am the new No. 2." >No. 6: "Who is No. 1?" >No. 2: "You are No. 6." >No. 6: "I am not a number. I am a free man!"
Thank you, sir
On 6/14/13 8:50 PM, manishp wrote:
> > I am going through comlpex description I wiki ... > In one place, it is written "eix traces unit circle ... as x ranges through > different real x" > But when I take different values of x such as 30, 45, 60
um, don't feed degrees into exp(i*theta). theta should be in radians. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge." (coming to you from the Starbucks on the PCH in Malibu.)
On 2013-06-16 00:40, Rick Lyons wrote:
> No. 6: "Where am I?" > No. 2: "In the Village." > No. 6: "What do you want?" > No. 2: "Information." > No. 6: "Who are you?" > No. 2: "I am the new No. 2." > No. 6: "Who is No. 1?" > No. 2: "You are No. 6." > No. 6: "I am not a number. I am a free man!"
Hi Rick, this signature is new, how it comes? Big fan of "The Prisoner"? bye, -- piergiorgio
robert bristow-johnson <rbj@audioimagination.com> writes:
> [...] > um, don't feed degrees into exp(i*theta).
Correct. You could kill the poor thing. -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
On Monday, June 17, 2013 5:08:36 AM UTC-5, Randy Yates wrote:
  > robert bristow-johnson <rbj@audio.....com> writes:
 > Randy Yates
 > Digital Signal Labs
Cruel and unusual punishment indeed, since you
are killing the thing by degrees instead of a
swift sharp stroke!
