On Mon, 05 Aug 2013 22:13:08 -0400, Randy Yates <yates@digitalsignallabs.com> wrote:>Randy Yates <yates@digitalsignallabs.com> writes: > >> Randy Yates <yates@digitalsignallabs.com> writes: >> >>> eric.jacobsen@ieee.org (Eric Jacobsen) writes: >>> >>>> On Mon, 05 Aug 2013 19:14:00 -0500, Tim Wescott >>>> <tim@seemywebsite.really> wrote: >>>> >>>>>On Mon, 05 Aug 2013 18:56:37 +0000, Eric Jacobsen wrote: >>>>> >>>>>> On Mon, 05 Aug 2013 14:39:44 -0400, Randy Yates >>>>>> <yates@digitalsignallabs.com> wrote: >>>>>> >>>>>>>Consider simple BPSK. Should the computation of Eb given the amplitude >>>>>>>of an ideal bit include the effect of pulse-shaping? >>>>>> >>>>>> It generally doesn't. Eb is just the total power divided by the bit >>>>>> rate. The pulse shape doesn't matter, since since things like Eb/No >>>>>> are power efficiency metrics. If you make a crappy Rx filter that >>>>>> causes a lot of ISI, you'll lose power efficiency. >>>>> >>>>>Actually, if Eb is the total power divided by the bit rate, then as long >>>>>as each bit's pulse is orthogonal to all the other bit's pulses (or is so >>>>>on average), then Eb _is_ taking the pulse shape into account. >>>> >>>> In a sense, yes. >>>> >>>> But measuring Eb, which is what Randy asked about, ... >>> >>> Ah, but that is not what I asked about. I asked about *computing* Eb.Yes, a mis-statement on my part.>>> Let me ask it another way. Let's say I want to generate an ideal, >>> pulse-shaped BPSK signal with a specified Eb. How do I know how to >>> relate the signal's peak value (we can call it A) to Eb? Does that >>> relationship depend on the pulse shape?Not if the receive filter matches the transmit filter, in a matched-filter sense. The bits don't really exist until the slicer, and the slicer only processes (if the system is working properly) the sampling instant where there is no ISI, and it cannot, therefore, tell any difference between pulse shapes since ALL matched filter pulse shapes will provide the same output at that instant.>> Or, given a pulse-shaped ideal BPSK signal with peak A, what is its Eb?Compute power using A, then divide by the symbol period, assuming Eb is for the single bit coming from the BPSK signal (as opposed to after FEC or other overhead). A little on why this works below.>In these last two posts, instead of saying the _signal_, I should have >stated the _pulse_. That is, A is the peak value of the pulse.This can be confusing, because the signal peaks in matched filter systems that use pulse shaping in the modulator happen between the symbol sampling instants, so the "peaks" will be higher than the desired (or noise-free) sliced symbol amplitude. This can be seen in the figures of one of the articles I linked. However, if one transmits unfiltered, NRZ, pulses and uses an integrate-and-dump filter in the receiver, it is a matched-filter system but the transmit signal has a constant amplitude during the entire symbol period. The slicer output will be the integral of that amplitude over the symbol period with the sign dependent on the transmitted bit. Remember, every matched filter system has the same output value at the sampling instant at the match point for a given input power, and the signal power of the unfiltered, NRZ BPSK signal is easy to compute and conceptualize. This means that whatever you figure out for the easy, NRZ, case, will hold for the pulse-shaped case as well. Assume that the transmitted signal is of unity amplitude, i.e., A = 1. The symbol at the matched filter output can also be interpreted at A = 1 (since the scaling, path loss, receiver gain, etc., is arbitrary), and can be used to compute the input power. This would also be true for the ideal, lossless signal transmission case, which is not realizable. The upshot is that "Eb" at the slicer output for BPSK can be arbitrarily chosen as "1", since there is one bit per symbol, as long as the same scaling is used for computing No. In other words, the desired sliced symbol magnitude is Eb = 1, and the sliced error vectors from the received symbols can be used with the same amplitude scaling to compute No (in the normal way that power is computed). Computing Eb with some sort of physical units applied depends on accurately knowing the receiver gain, which usually means having a carefully calibrated AGC and a means to accurately sense the AGC level. It is possible to then also compute the noise power from the sliced error vectors and get an estimate of SNR or Eb/No or Es/No or whatever. None of it depends on the pulse shape used. We've done this a lot where we provided estimated recieved power level and SNR (or similar metrics) from the slicer statistics, and it is independent of which programmable pulse shape might be loaded at the time as long as the transmitter and receiver filters are properly matched. The only difference for higher-order modulations such as QAM is accounting for the average value of the constellation points instead of the magnitude of the constant-modulus signals, and scaling for the number of bits per symbol to get Eb instead of Es. I hope that all makes sense.>-- >Randy Yates >Digital Signal Labs >http://www.digitalsignallabs.comEric Jacobsen Anchor Hill Communications http://www.anchorhill.com
Eb (energy per bit)
Started by ●August 5, 2013
Reply by ●August 6, 20132013-08-06
>Consider simple BPSK. Should the computation of Eb given the amplitude >of an ideal bit include the effect of pulse-shaping? >-- >Randy Yates >Digital Signal Labs >http://www.digitalsignallabs.com >if p(t) is the pulse shape then Eb = integral from -inf to +inf of [p(t)]^2 dt ... this is right out of Proakis. This assumes of course that p(t) is the shape of the "bit" in question. -Doug _____________________________ Posted through www.DSPRelated.com
On Monday, August 5, 2013 8:37:23 PM UTC-5, Randy Yates wrote:> Let me ask it another way. Let's say I want to generate an ideal, > > pulse-shaped BPSK signal with a specified Eb. How do I know how to > > relate the signal's peak value (we can call it A) to Eb? Does that > > relationship depend on the pulse shape?and> If you want to get picky about units, assume > A is in volts and we are driving a resistance > of 1 ohm.Ah, at last a question that I know how to answer. Assuming the baseband signal p(t) is a rectangular pulse of amplitude 1 and duration T seconds, in fact, zero outside the interval [0,T), the simplest form of a BPSK signal is sum_k (-1)^{bk} sqrt{2 Eb/T} p(t-kT)sin(2 pi fc t) where Eb is the signal energy in joules, the carrier frequency fc is n/T, that is, the n-th harmonic of the channel bit rate, and bk is the k-th bit transmitted on the channel. The above result is usable, though not completely exact, even if the carrier frequency is not a harmonic of the channel bit rate as long as fc >> 1/T. Note, however, that at the switching instants mT when bit changes occur, the signal changes discontinuously from one nonzero value to another which is impossible to achieve in practice and so the model is inexact on these grounds as well. The above result is also usable for nonrectangular pulses p(t) as long as they nonzero only on [0,T), are relatively smooth, and enjoy the property that integral from 0 to T [p(t)]^2 dt = T but in this case, we must insist on fc >> 1/T because the analysis has to come to grips with an integral of [p(t)]^2 cos(2 pi 2fc t) over [0,T) and the argument is that [p(t)]^2 is slowly changing and thus can be regarded as essentially constant over one period of the sinusoid; and therefore, if we break up the integral over [0,T) into a sum of integrals over single periods of the sinusoid, each little integral, being the integral of (essentially) a constant times a sinusoid over one period of the sinusoid, is (essentially) zero. Dilip Sarwate
>The above result is also usable for nonrectangular pulses >p(t) as long as they nonzero only on [0,T), are relatively >smooth, and enjoy the property that > >integral from 0 to T [p(t)]^2 dt = T > >Dilip Sarwate > >Yes ... if p(t) is wider than [0,T), then you must integrate 0 to T and find the average over all bit sequences that are at least as long as p(t) to get Eb _____________________________ Posted through www.DSPRelated.com
Reply by ●August 8, 20132013-08-08
On Tuesday, August 6, 2013 10:38:32 AM UTC-5, DougB wrote:> > Yes ... if p(t) is wider than [0,T), then you must integrate 0 to T and > > find the average over all bit sequences that are at least as long as p(t) > > to get EbExcept that the signal is no longer a constant amplitude BPSK signal, and some people might question whether this is indeed BPSK, or, as Eric Jacobsen pointed out, will work at all as intended if the transmitter yanks up the amplitude to get the maximum power out the door. Dilip Sarwate
