For those interested in filter design, I want to introduce you to the Adjustable Gauss Polynomial. I am not selling anything here, and I would imagine you could implement this in MatLab if you wanted to. A couple of years ago I was experimenting with polynomial filters such as the Butterworth. My goal was to find a polynomial that was more compatible with digital filter design. One thing I tried was to place equally spaced poles on the z plane in much the same way as Butterworth poles are equally spaced on the s plane. It worked fine, but not as good as the Adjustable Gauss. The problem for me was that I wanted a filter with less distortion than the Butterworth causes (less overshoot and ringing), but with less passband roll off better selectivity than a Bessel. Of course, there is no middle ground between the Bessel and Butterworth. The Adjustable Gauss solves this problem. It is capable of generating a response anywhere from the Gauss to the Bessel to the Butterworth. You simply set the parameter Gamma to give the desired response. I can't paste in plots here, so this link will have to suffice. Frequency responses and pole locations are given for various values of Gamma. The algorithm is also given. http://www.iowahills.com/7AdjustablePolyPage.html Dan _____________________________ Posted through www.DSPRelated.com
Started by ●August 16, 2013
Reply by ●August 20, 20132013-08-20
On 8/16/13 9:38 AM, FilterDan wrote:> > The problem for me was that I wanted a filter with less distortion than the > Butterworth causes (less overshoot and ringing), but with less passband > roll off better selectivity than a Bessel. Of course, there is no middle > ground between the Bessel and Butterworth. >"Of course"??? how are you so sure of that? using the metaphor, it's like you didn't even step off the curb onto the middle ground that is there. and "Gaussian filters" may very well lie in that middle ground. i think there are other cases, but i don't have access to my Claude Lindquist book at the moment. BTW, even though it's outa print (it *is* better than 3 decades old), you can get copies for cheap, it appears: http://www.alibris.com/Active-Network-Design-with-Signal-Filtering-Applications-Claude-S-Lindquist/book/108704 it's an excellent book for analog filters. combine that knowledge with the Bilinear Transform, and you'ld be pretty dangerous, i think. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
On Friday, August 16, 2013 12:38:54 PM UTC-4, FilterDan wrote:> For those interested in filter design, I want to introduce you to the > > Adjustable Gauss Polynomial. I am not selling anything here, and I would > > imagine you could implement this in MatLab if you wanted to. > > > > A couple of years ago I was experimenting with polynomial filters such as > > the Butterworth. My goal was to find a polynomial that was more compatible > > with digital filter design. > > > > One thing I tried was to place equally spaced poles on the z plane in much > > the same way as Butterworth poles are equally spaced on the s plane. It > > worked fine, but not as good as the Adjustable Gauss. > > > > The problem for me was that I wanted a filter with less distortion than the > > Butterworth causes (less overshoot and ringing), but with less passband > > roll off better selectivity than a Bessel. Of course, there is no middle > > ground between the Bessel and Butterworth. > > > > The Adjustable Gauss solves this problem. It is capable of generating a > > response anywhere from the Gauss to the Bessel to the Butterworth. You > > simply set the parameter Gamma to give the desired response. > > > > I can't paste in plots here, so this link will have to suffice. Frequency > > responses and pole locations are given for various values of Gamma. The > > algorithm is also given. > > > > http://www.iowahills.com/7AdjustablePolyPage.html > > > > Dan > > > > _____________________________ > > Posted through www.DSPRelated.comIn fact there is exactly such a filter, called "Transitional Butterworth-Thompson Filter", which has a factor that smoothly varies the step response between Butterworth and something close to Gaussian. Classic paper appeared in 1968. Used in many application, but not very well-known. Bob
combine that knowledge with the Bilinear Transform, and you'ld be pretty dangerous, i think. -- r b-j r...@audioimagination.com "Imagination is more important than knowledge." Thanks, I expected a response such as this, but I had no idea what it would be. I know with absolute certainty that I am not some sort of inventive genius, but topics like this are hard to research if you don't know the right keyword. Now I've learned something, and so will anyone else reading this post. Apologies for being dangerous. Dan _____________________________ Posted through www.DSPRelated.com
On 8/20/13 4:05 PM, FilterDan wrote:> Apologies for being dangerous.no need to. being "dangerous" in this context is being effective. a good book on analog filters combined with some means of mapping the analog filter to a digital filter can be an effective way to get something done. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Reply by ●August 21, 20132013-08-21
On 8/20/2013 5:12 PM, radams2000@gmail.com wrote:> In fact there is exactly such a filter, called "Transitional > Butterworth-Thompson Filter", which has a factor that smoothly varies > the step response between Butterworth and something close to > Gaussian. Classic paper appeared in 1968. Used in many application, > but not very well-known.Another not so well known design is Legendre filter, which has the sharpest possible rolloff while keeping frequency response monotonic. Interestingly, the problem of monotonic response has analytical solution. Vladimir Vassilevsky DSP and Mixed Signal Designs www.abvolt.com
