On Thu, 29 Aug 2013 22:06:34 +0000 (UTC), glen herrmannsfeldt <gah@ugcs.caltech.edu> wrote:>Eric Jacobsen <eric.jacobsen@ieee.org> wrote: > >(snip, someone wrote) > >>>> Converting from IF to baseband is, IMHO, more a tuning >>>> operation than "demodulation". De-modulating implies >>>> undoing the modulation, which may not, and usually doesn't, >>>> have anything to do with frequency conversion. > >(then I wrote) >>>Reminds me of the discussion about whether a device is, or is not, >>>a modem based on whether it does, or does not, modulate and >>>demodulate anything. > >>>To me, though IF to baseband is demodulating, where RF to IF is, >>>in the systems I know, frequency conversion. > >> So does direct conversion do demodulation or frequency conversion? > >My old favorite reference on such is the "ARRL Handbook." > >In the chapter titled "Mixers, Modulators and Demodulators" >(and given that, you might guess that they are related). > > "Translating information into radio form entails a process > we call modulation, and demodulation, is its reverse. > >The chapter then goes on to explain mixers and their use for >modulation and demodulation.And I think the ARRL deserves a whack in the head for promoting that as a definition of what mixers do.>> The issue is that the terms are overloaded and used ambiguously. > >>>But OK, detection is the non-linear operation that demodulates >>>an AM signal. So, you want to separate the conversion to baseband >>>(as not demodulation) and detection. > >>>Do you agree that AF to IF is modulation? So, IF to RF is not? > >> What is AF? > >Must be that I read too many old radio books, when the output >was AF, or Audio Frequency. I suppose now there are enough more uses >for radios that doesn't make sense. Still, I believe it is commonly >used in describing transistors not designed for higher frequencies.In that case, no I don't agree that AF->IF or IF->RF is "modulation". It's "tuning" or "frequency translation" or whatever, but by the usual definition of "modulation"in this context, there's no information added to the signal by the process.>(snip on complex signals) > >>>> Unfortunately some do use the term "demodulation" the way you have, >>>> but I think it is more confusing than helpful. > >>>Seems to me that the operation of a mixer is commonly modulation >>>when going up, and it also could be going down. > >> I think a mixer mixes, and the resulting frequency conversion is best >> referred to as "frequency conversion" or "tuning" or "mixing". >> Modulation, in this context, to me, implies that something is being >> modulated to carry a recoverable information signal. Mixing doesn't >> do that. AM, FM, PM, MSK, etc., etc., does, and "demodulating" those >> signals recovers the information used in the "modulation". > >But mixing does do that! You might want to separate balanced >and double balanced mixers. Conventional AM comes from a singly >balanced mixer, which allows the carrier through even with no >input on the other port. AM-SC, like the FM stereo subcarrier, >and NTSC chrominance subcarrier, from a double balanced mixer.It is unfortunate that these limited (but historic) cases have produced such a great and continuing source of confusion. I think it much better that the concepts or processes of adding and recovering information from a signal and translating it in frequency would have different nomenclatures.>> The sad fact is that the terms are already ambiguous and in common use >> in their overloaded cases, so it's all just opinion on both sides. > >That is true just about everywhere, and might just as well be here.I think reducing confusion is a desirable goal.> >-- glenEric Jacobsen Anchor Hill Communications http://www.anchorhill.com
Demodulation with Hilberttransformation
Started by ●August 27, 2013
Reply by ●August 29, 20132013-08-29
