HI, i'm implementing all the steps of music algorithm, but i believe there are some problems. This is m script: N= 50; % number of antenna K= 6; %number of signal f0=10; %frequency of signal fs=100; %sampling frequency d = 0.5; %distance/lambda ratio t = 0:1/fs:1; x1= sin(2*pi*3*f0*t); x2= 2*sin(2*pi*f0*t); x3 = cos(2*pi*f0*t); x = x1+x2+x3 + wgn(1,length(t),0); % signal + white noise [t_matrix Rx]= corrmtx(x,N-1,'mod'); %Rx is autocorrelation matrix NxN. [a_vector a_value] = eig(Rx); % find eigenvalues and eigenvector [a_val_sort index]= sort(diag(a_value),1,'descend'); a_vett_sort=a_vector (:,index); Qn = a_vett_sort(:,K+1:N); %noise subspace angles = -90:1:90; steering = exp(-i*2*pi*d*(0:N-1)'*sind(angles)); %steering matrix for m= 1:length(angles) spectrum(m)= 1/(steering(:,m)'*Qn*Qn'*steering(:,m)); end grid on; plot(angles,abs(spectrum)); I'm not sure of value of K and its relation with signals x1,x2,x3. The spectrum is very strange, i don't understand why it's simmetric! I find always +/- angles. If is use SVD insted eig?? Rx is always square, and i believe i don't need SVD. Is there anyone who may help me? Thanks very much to all!
Implementation of all steps of Music algorithm
Started by ●September 30, 2013
Reply by ●October 1, 20132013-10-01
