Target DSP: TMS320LF2407A Target board: eZdsp TMS320lf2407a & custom 1 device in chain. emulator model: XDS510PP Software: Code Composer 4.12, sdconfig 1.35 OS: windows 2000 sp 4 PC: Dell Hi, I'm trying to use our XDS510PP JTAG module, initially on the Spectrum Digital eZdsp TMS320LF2407a, and then on our custom board. When I use sdconfig and have the parallel cable plugged directly into the eZdsp board, doing a 'verify connection' works and reports the following: ** Checking for a valid emulator/eZdsp $$ You are connected to: $$ EmuProductName=XDS510PP_PLUS $$ EmuPortAddr=0x378 $$ EmuPortMode=SPP8 $$ ProductId=10 $$ ProductVersion=81 but when I plug in the XDS510PP and try the verify, I get the following: ** Checking for a valid emulator/eZdsp >> Could not read the product id from the emulator/eZdsp. >> Check the following >> - Power is applied to the emulator/eZdsp >> - EmuPortAddr is set properly in sdopts.cfg >> - Used EmuPortAddr=0x378 >> - Used EmuPortMode=SPP8 If I use the XDS510PP with the older windows 98 software (PRG2XXPP.EXE), it works. Is there some driver or configuration file I need? Thanks in advance for any help. -Mike
XDS510PP problem
Started by ●August 15, 2003
Reply by ●August 19, 20032003-08-19
You might want to try changing the EmuPortMode. We recently had a similar experience with a slow(350Mhz) computer that could get thru the diagnostics most of the time, but would usually have an error when loading code. Changing from SPP to EPP got it working reliably, but it was also the impetus we needed to upgrade the motherboard to improve performance. "Mike Shonle" <mike@psychonic.net> wrote in message news:sCmdncuIHZxg1aCiRTvUpQ@speakeasy.net...> Target DSP: TMS320LF2407A > Target board: eZdsp TMS320lf2407a & custom > 1 device in chain. > emulator model: XDS510PP > > Software: Code Composer 4.12, sdconfig 1.35 > OS: windows 2000 sp 4 > PC: Dell > > > Hi, I'm trying to use our XDS510PP JTAG module, initially on the Spectrum > Digital eZdsp TMS320LF2407a, and then on our custom board. When I use > sdconfig and have the parallel cable plugged directly into the eZdspboard,> doing a 'verify connection' works and reports the following: > > ** Checking for a valid emulator/eZdsp > > $$ You are connected to: > $$ EmuProductName=XDS510PP_PLUS > $$ EmuPortAddr=0x378 > $$ EmuPortMode=SPP8 > $$ ProductId=10 > $$ ProductVersion=81 > > > but when I plug in the XDS510PP and try the verify, I get the following: > > ** Checking for a valid emulator/eZdsp > > >> Could not read the product id from the emulator/eZdsp. > > >> Check the following > >> - Power is applied to the emulator/eZdsp > >> - EmuPortAddr is set properly in sdopts.cfg > >> - Used EmuPortAddr=0x378 > >> - Used EmuPortMode=SPP8 > > If I use the XDS510PP with the older windows 98 software (PRG2XXPP.EXE),it> works. > > Is there some driver or configuration file I need? > > Thanks in advance for any help. > > -Mike > > >
