"Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote in message news:cDP%a.4090$Jk5.3891444@feed2.centurytel.net...> > > Given the impulse response as stated, the p(t) filters aren't in cascadebut> in parallel with a differential delay of T. At least I don't see how toget> a cascaded structure immediately out of this expression.Hello Fred, It seems that you have your output written as the sum of two fractions, so just find a common denominator to put it all into one fraction, and then see if the numerator has a part that will factor out. It is likely that this will be ugly, but that is how I'd approach it. Clay> > Fred > > > >
combine transfer functions
Started by ●August 15, 2003
Reply by ●August 18, 20032003-08-18
"Clay S. Turner" <physicsNOOOOSPPPPAMMMM@bellsouth.net> wrote in message news:zN50b.1339$a9.1020@fe03.atl2.webusenet.com...> > "Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote in message > news:cDP%a.4090$Jk5.3891444@feed2.centurytel.net... > > > > > > Given the impulse response as stated, the p(t) filters aren't in cascade > but > > in parallel with a differential delay of T. At least I don't see how to > get > > a cascaded structure immediately out of this expression. > > > Hello Fred, > > It seems that you have your output written as the sum of two fractions, so > just find a common denominator to put it all into one fraction, and thensee> if the numerator has a part that will factor out. It is likely that this > will be ugly, but that is how I'd approach it. > > ClayClay, Well, if we're talking about rational transfer functions, OK. But I was talking about the sum of two impulse responses p(t) and p(t-T). That's conceptually pretty easy - particularly if p(t) is a FIR and if we aren't concerned about T being an integral of a sample interval. Hey! Nobody has mentioned my "exercise for the student". I haven't taken the time to figure it out. It must be some simple obvious thing because it tries to get around T not being an integer multiple of the sampling interval. Fred
On Sun, 17 Aug 2003 11:26:05 -0700, "Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote:>>> >> Anyway, the impulse response of two cascaded >> filters (connected in series) is the convolution >> of the two individual filters' impulse rsponses. > >Rick, > >You are correct about the grammar of course. >It should be "impulse response" rather than transfer function. > >Given the impulse response as stated, the p(t) filters aren't in cascade but >in parallel with a differential delay of T. At least I don't see how to get >a cascaded structure immediately out of this expression. > >FredHi Fred, Oops, ... I think you're right. For some reason I thought cascade. Anyway, yep, the impulse response of two filters in parallel is the sum of the imp responses. [-Rick-]
