On 10/25/13 1:56 AM, niarn wrote:>> >> i like to define it as the dB of SNR plus the dB of headroom. > > That makes sense to me because the headroom could just as well be used to > gain up the input and thus increase SNR.to a point. that's why i think you need to specify a decent mid-level output (like 6 dB below the rails is what i would suggest). but if you crank it up too high, you'll lose *both* headroom and SNR.> One practical issue I can think of > with this approach is that if some non-stationary input is used for the > measurement it may be difficult to find or track what the headroom should > be. I assume you mean the margin up to fullscale as being the headroom.yes. my nomenclature for "fullscale" is "rails".> What type of input would you use for your SNR measurement? sweep, > sinusoidal, noise?whatever. that's a spec. but to compare apples to apples, you need to account for that 1.76 dB you get from a sine wave compared to a signal that has uniform p.d.f. up to its maximum value. the margin between the maximum and the rail (or "ceiling" or "fullscale") is, by definition i think, the headroom. i like that uniform distribution (which you get with a triangle or sawtooth wave without DC) for the test signal because then there is no 1.76 dB factor (or any other) and the p.d.f. of the S (in S/N) is the same as the p.d.f. of the N (at least undithered N). and then you get a very clean formula for DynamicRange = (6.02 dB)*(word width in bits). if you use a sinusoid, you would have to add 1.76 dB. and if you use maximum-length sequences for the driving signal and you jacked that up to the rails, i think you get another 3.01 dB S/N more than the sine. but i would never recommend driving a system to the rails with an MLS. nor even a sine wave. just seems like asking for trouble. you may get distortion components in the D/A or something.> >> these two >> quantities add roughly to a constant, at least for mid-level output. > > Do you mean that for mid-level output there is very little risk of internal > wraparound or saturation that could impact the measurement?yeah, like 6 dB below the rails. but the SNR+HR should still be about the same if you're 12 dB below the rails (6 dB less SNR and 6 dB more HR). but you wouldn't want to make this measurement 6 or 12 dB above the LSB. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Butterworth
Started by ●October 4, 2013
Reply by ●October 26, 20132013-10-26
