Il giorno luned� 4 novembre 2013 18:42:56 UTC+1, Rob Gaddi ha scritto:> On Sun, 3 Nov 2013 12:14:44 -0800 (PST) > > Ste_ee <stefano.cap91@gmail.com> wrote: > > > > > > > > The problem is this: I want manipulate numbers less than zero with fixed point representation in VHDL, using only std_logic_vector, if is possible..I wouldn't to use fixed_point packages like in vhdl.org. > > > > Please, for the love of all that's holy, don't do that. VHDL is a > > strongly typed language. Don't abuse it with jerry-rigged > > pseudo-types; make the right types. If you want a language that you > > can do whatever you want with so long as you leave a $20 on the > > nightstand after, write Verilog. > > > > As a bare minimum you should be using signed and unsigned > > from the numeric_std package, rather than std_logic_vector, which I can > > only assume you're doing math on by bringing in std_logic_arith and > > friends, which have been poor form since 1993. > > > > Before VHDL-2008, that's how I've always done it. On top of that, I > > write my own subtypes to keep everything clear and rigidly defined in > > the code. > > > > -- Data is S2.16 > > -- Filter coefficients are S1.17 > > -- Data * coefficient is S3.33 > > -- Accumulator needs no overflow bits by design. > > subtype t_data is signed(17 downto 0); > > subtype t_coef is signed(17 downto 0); > > subtype t_product is signed(35 downto 0); > > subtype t_accum is signed(35 downto 0); > > > > As Allan mentioned hwoever, now VHDL-2008 brings in the fixed_pkg as a > > standard part of the language. A lot of people substantially more > > knowledgeable than you spent a lot of time writing that (in pure VHDL, > > by the way) and making it work. You ignore it at your peril. > > > > -- > > Rob Gaddi, Highland Technology -- www.highlandtechnology.com > > Email address domain is currently out of order. See above to fix.All you have been gentiles and thanks very much. I know how 2'complement and vhdl work but i was only confused about the fixed point representation. Now is all clearly.
Fixed Point Analysis and VHDL
Started by ●November 3, 2013
Reply by ●November 4, 20132013-11-04
