I am trying to recreate the following results: http://i.stack.imgur.com/muMxX.jpg from the following data: https://www.dropbox.com/s/mi3szqgzgku29rn/FS40.dat the time is in milliseconds (frequency is 40000 Hz) The article state that they used Complex Morlet wavelet to create the spectrogram: " Power estimates from the averaged LFPs were calculated from time–frequency spectrograms of the data from 1–88 Hz by convolving the signals with a complex Morlet wavelet of the form w(t,f0 ) = Aexp(−t^2 / 2*σ^2 )exp(2*i*π*f0*t) for each frequency of interest f0, where σ = m/2πf0, and i is the imaginary unit. The normalization factor was A = 1 /(σ (2π)^0.5 ), and the constant m defining the compromise between time and frequency resolution was 7. I only managed to get some "good" results using spectrogram function in matlab. But I dont have much idea of how to use the morlet complex wavelet. I got bad result when trying to use cwt with 'morl' window Thank You. P.S. I'm trying to recreate this article: Computational modeling of distinct neocortical oscillations driven by cell-type selective optogenetic drive: separable resonant circuits controlled by low-threshold spiking and fast-spiking interneurons. _____________________________ Posted through www.DSPRelated.com
Spectrogram from Complex Morlet wavelet ( recreating article result from data)
Started by ●November 11, 2013
