How to calculate the -3d cut-off frequency of a given digital lowpass-filter? Given is a IIR filter in the form of H(z) = a / (1 - (1-a) z^-1). How to calculate the cut-off frequency? I thought about evaluating the magnitude of the DTFT (z-transform on unit-circle), for values where the DTFT exists. Is this correct? Or are there other possibilities for doing that?
Calculate cut-off frequency of digital IIR lowpass-filter
Started by ●November 12, 2013
Reply by ●November 12, 20132013-11-12
On Tuesday, November 12, 2013 2:11:37 PM UTC-5, Marc Jacob wrote:> How to calculate the -3d cut-off frequency of a given digital lowpass-filter? > > Given is a IIR filter in the form of H(z) = a / (1 - (1-a) z^-1). > > > > How to calculate the cut-off frequency? I thought about evaluating the magnitude of the DTFT (z-transform on unit-circle), for values where the DTFT exists. > > > > Is this correct? Or are there other possibilities for doing that?Marc, Yes, letting z^-1 = e^-jwt and finding where the magnitude = 1/2 is probably the sanest way if you wish to work from first principles. Another way is to look at a table of z-transform pairs and figure it that way. You should find this entry or one like it in the table 1/ (1-b*z^-1) <-> (b^n)*u[n] for |z| < |b| IHTH, Clay
Hi Clay,> Yes, letting z^-1 = e^-jwt and finding where the magnitude = 1/2 is probably the sanest way if you wish to work from first principles.You mean 1/sqrt(2), do you?> Another way is to look at a table of z-transform pairs and figure it that way. > You should find this entry or one like it in the table > 1/ (1-b*z^-1) <-> (b^n)*u[n] for |z| < |b|I know these tables, but how to derive the cut-off frequency omega from that? Cheers Marc
On Wednesday, November 13, 2013 8:11:37 AM UTC+13, Marc Jacob wrote:> How to calculate the -3d cut-off frequency of a given digital lowpass-filter? > > Given is a IIR filter in the form of H(z) = a / (1 - (1-a) z^-1). > > > > How to calculate the cut-off frequency? I thought about evaluating the magnitude of the DTFT (z-transform on unit-circle), for values where the DTFT exists. > > > > Is this correct? Or are there other possibilities for doing that?Unfortunately there is no equivalent easy way (unlike in analogue) of the simple time-constant where you just say 1/T as the cut-off 3dB frequency. You need to do it by computation. You could derive a formula of course but it wouldn't be pretty.
On 11/12/13 12:23 PM, Marc Jacob wrote:> Hi Clay, > > >> Yes, letting z^-1 = e^-jwt and finding where the magnitude = 1/2 is probably the sanest way if you wish to work from first principles. > > You mean 1/sqrt(2), do you? > >> Another way is to look at a table of z-transform pairs and figure it that way. >> You should find this entry or one like it in the table >> 1/ (1-b*z^-1)<-> (b^n)*u[n] for |z|< |b| > > I know these tables, but how to derive the cut-off frequency omega from that? >plug in z = e^(j*omega) = cos(omega) + j*sin(omega) into the expression from the table. then plug-and-chug. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
> z = e^(j*omega) = cos(omega) + j*sin(omega) > into the expression from the table. then plug-and-chug.Just wanted to confirm that I already managed it. Cheers Marc
On 11/12/2013 1:11 PM, Marc Jacob wrote:> How to calculate the -3d cut-off frequency of a given digital > lowpass-filter? Given is a IIR filter in the form of H(z) = a / (1 - > (1-a) z^-1).Fc = - Fs ln a / 2 Pi> How to calculate the cut-off frequency? I thought about evaluating > the magnitude of the DTFT (z-transform on unit-circle), for values > where the DTFT exists.Wow> Is this correct? Or are there other possibilities for doing that?Wow
Reply by ●November 13, 20132013-11-13
On Wednesday, November 13, 2013 1:13:43 PM UTC+13, Vladimir Vassilevsky wrote:> On 11/12/2013 1:11 PM, Marc Jacob wrote: > > > > > How to calculate the -3d cut-off frequency of a given digital > > > lowpass-filter? Given is a IIR filter in the form of H(z) = a / (1 - > > > (1-a) z^-1). > > > > Fc = - Fs ln a / 2 Pi > > > > > How to calculate the cut-off frequency? I thought about evaluating > > > the magnitude of the DTFT (z-transform on unit-circle), for values > > > where the DTFT exists. > > > > Wow > > > > > Is this correct? Or are there other possibilities for doing that? > > > > WowWell I don't know if it's the same but I get Fc = (1/2Pi) Fs arccos(1-x) where x=a^2/(2(1-a))
> Well I don't know if it's the same but I get > Fc = (1/2Pi) Fs arccos(1-x) > where x=a^2/(2(1-a))I cannot agree with your solution. I'm getting fc = (1/2Pi) arccos( (1-2a^2)(2x) + x/2) where x = (1-a) I compared these results with Matlab, and they match. Cheers Marc
On Thursday, November 14, 2013 10:11:23 AM UTC+13, Marc Jacob wrote:> > Well I don't know if it's the same but I get > > > Fc = (1/2Pi) Fs arccos(1-x) > > > where x=a^2/(2(1-a)) > > > > I cannot agree with your solution. I'm getting > > > > fc = (1/2Pi) arccos( (1-2a^2)(2x) + x/2) > > > > where x = (1-a) > > > > I compared these results with Matlab, and they match. > > > > Cheers MarcI'm not going to argue, I did my calculation fairly quickly, it looks like Vlad Vampyre is wrong though too.
