On Thursday, November 14, 2013 10:11:23 AM UTC+13, Marc Jacob wrote:> > Well I don't know if it's the same but I get > > > Fc = (1/2Pi) Fs arccos(1-x) > > > where x=a^2/(2(1-a)) > > > > I cannot agree with your solution. I'm getting > > > > fc = (1/2Pi) arccos( (1-2a^2)(2x) + x/2) > > > > where x = (1-a) > > > > I compared these results with Matlab, and they match. > > > > Cheers MarcYou missed Fs
Calculate cut-off frequency of digital IIR lowpass-filter
Started by ●November 12, 2013
Reply by ●November 13, 20132013-11-13
Reply by ●November 14, 20132013-11-14
On Tuesday, November 12, 2013 2:11:37 PM UTC-5, Marc Jacob wrote:> How to calculate the -3d cut-off frequency of a given digital lowpass-filter? > > Given is a IIR filter in the form of H(z) = a / (1 - (1-a) z^-1). > > > > How to calculate the cut-off frequency? I thought about evaluating the magnitude of the DTFT (z-transform on unit-circle), for values where the DTFT exists. > > > > Is this correct? Or are there other possibilities for doing that?From the plug and chug approach I find omega = acos((a^2+2a-2)/(2(a-1))) which is the cutoff frequency (mag^2 = 1/2) in radians per sample. Just multiply omega by Fs/(2pi) to convert to cycles per time. Clay
On Friday, November 15, 2013 5:39:36 AM UTC+13, cl...@claysturner.com wrote:> On Tuesday, November 12, 2013 2:11:37 PM UTC-5, Marc Jacob wrote: > > > How to calculate the -3d cut-off frequency of a given digital lowpass-filter? > > > > > > Given is a IIR filter in the form of H(z) = a / (1 - (1-a) z^-1). > > > > > > > > > > > > How to calculate the cut-off frequency? I thought about evaluating the magnitude of the DTFT (z-transform on unit-circle), for values where the DTFT exists. > > > > > > > > > > > > Is this correct? Or are there other possibilities for doing that? > > > > From the plug and chug approach I find > > > > omega = acos((a^2+2a-2)/(2(a-1))) > > > > which is the cutoff frequency (mag^2 = 1/2) in radians per sample. > > > > Just multiply omega by Fs/(2pi) to convert to cycles per time. > > > > ClaySame as my result above, (a^2+2a-2)/(2(a-1))= (2(a-1) +a^2) / 2(a-1) = 1- (a^2/2(1-a)) so why did the other guy say he checked with Matlab and gets a different answer?
Reply by ●November 15, 20132013-11-15
On Thursday, November 14, 2013 7:36:52 PM UTC-5, gyans...@gmail.com wrote:> On Friday, November 15, 2013 5:39:36 AM UTC+13, cl...@claysturner.com wrote: > > > On Tuesday, November 12, 2013 2:11:37 PM UTC-5, Marc Jacob wrote: > > > > > > > How to calculate the -3d cut-off frequency of a given digital lowpass-filter? > > > > > > > > > > > > > > Given is a IIR filter in the form of H(z) = a / (1 - (1-a) z^-1). > > > > > > > > > > > > > > > > > > > > > > > > > > > > How to calculate the cut-off frequency? I thought about evaluating the magnitude of the DTFT (z-transform on unit-circle), for values where the DTFT exists. > > > > > > > > > > > > > > > > > > > > > > > > > > > > Is this correct? Or are there other possibilities for doing that? > > > > > > > > > > > > From the plug and chug approach I find > > > > > > > > > > > > omega = acos((a^2+2a-2)/(2(a-1))) > > > > > > > > > > > > which is the cutoff frequency (mag^2 = 1/2) in radians per sample. > > > > > > > > > > > > Just multiply omega by Fs/(2pi) to convert to cycles per time. > > > > > > > > > > > > Clay > > > > Same as my result above, > > > > (a^2+2a-2)/(2(a-1))= (2(a-1) +a^2) / 2(a-1) = 1- (a^2/2(1-a)) > > > > so why did the other guy say he checked with Matlab and gets a different answer?Good question! An alternate formulation is omega = 2 asin*( |a| / (2*sqrt(1-a)) ) Clay
