Hi! I want to make sure that what I've learned so far about Trellis-Coded Modulation is correct which is why I'm asking for confirmation. d_free^2 is minimal the sum of squared Euclidean distances between two symbol sequences that can be generated by the TCM, right? The coding gain is 10*log10(d_free^2/d_min^2) where d_min is the minimum Euclidean distance for a pair of "uncoded" symbols, right? For example, if I come up with a TCM that maps 2 bits to an 8-PSK symbol (a complex number on the unit circle) and compute d_free^2 to be 5.1716 and then compare it to QPSK where d_min^2 is 2 = norm(1-1i)^2 and say that the coding gain is 4.13 dB would that be correct? Cheers! sg [1] http://complextoreal.com/wp-content/uploads/2013/01/tcm.pdf
Coding Gain for TCM (Trellis-Coded Modulation)
Started by ●November 18, 2013
Reply by ●November 18, 20132013-11-18
On 11/18/2013 10:04 AM, sg wrote:> I want to make sure that what I've learned so far about Trellis-Coded > Modulation is correct which is why I'm asking for confirmation. > > d_free^2 is minimal the sum of squared Euclidean distances between two > symbol sequences that can be generated by the TCM, right? > > The coding gain is 10*log10(d_free^2/d_min^2) where d_min is the minimum > Euclidean distance for a pair of "uncoded" symbols, right?That's the limit of coding gain for ideal decoder when Eb/No goes to infinity.> For example, if I come up with a TCM that maps 2 bits to an 8-PSK symbol > (a complex number on the unit circle) and compute d_free^2 to be 5.1716 > and then compare it to QPSK where d_min^2 is 2 = norm(1-1i)^2 and say > that the coding gain is 4.13 dB would that be correct?You could say that coding gain would be no more then 4.13dB; depending on Eb/No and other things. Vladimir Vassilevsky DSP and Mixed Signal Designs www.abvolt.com
Reply by ●November 19, 20132013-11-19
Am 18.11.2013 18:27, schrieb Vladimir Vassilevsky:> On 11/18/2013 10:04 AM, sg wrote: > >> I want to make sure that what I've learned so far about Trellis-Coded >> Modulation is correct which is why I'm asking for confirmation. >> >> d_free^2 is minimal the sum of squared Euclidean distances between two >> symbol sequences that can be generated by the TCM, right? >> >> The coding gain is 10*log10(d_free^2/d_min^2) where d_min is the minimum >> Euclidean distance for a pair of "uncoded" symbols, right? > > That's the limit of coding gain for ideal decoder when Eb/No goes to > infinity.Right. I should have said "asymptotic coding gain".>> For example, if I come up with a TCM that maps 2 bits to an 8-PSK symbol >> (a complex number on the unit circle) and compute d_free^2 to be 5.1716 >> and then compare it to QPSK where d_min^2 is 2 = norm(1-1i)^2 and say >> that the coding gain is 4.13 dB would that be correct? > > You could say that coding gain would be no more then 4.13dB; depending > on Eb/No and other things.Right. For now, I'm just concerned about the asymptotic gains. Next question. Can somebody confirm that the table in http://complextoreal.com/wp-content/uploads/2013/01/tcm.pdf on page 19 about possible asymptotic coding gains for 8-PSK (taking 2 bits and mapping it to an 8PSK symbol) is correct? Here it is for your convenience: number of states coding gain (dB) ------------------------------------- 4 3 8 3.6 16 4.1 : : I ask because I seem to have found an 8-state code that gives me a gain of 4.1 dB. So, either someone is wrong (me or the author of the paper) or I found an 8-state TCM for 8-PSK that beats publicly known codes. Cheers! SG
Reply by ●November 21, 20132013-11-21
Am 19.11.2013 16:41, schrieb sg:> number of states coding gain (dB) > ------------------------------------- > 4 3 > 8 3.6 > 16 4.1 > : : > > I ask because I seem to have found an 8-state code that gives me a gain > of 4.1 dB. So, either someone is wrong (me or the author of the paper) > or I found an 8-state TCM for 8-PSK that beats publicly known codes.It looks like I screwed up the free distance computation. I thought I could just calculate the free distance between the "zero sequence" and one of the closest other valid symbol sequence outputs. But that does not seem to work. I guess this won't catch Voronoi regions of different shapes and sizes over all possible sequences. For the 8-state recursive rate-2/3 Ungerboeck code for 8-PSK my computation yields the right free distance sqrt(4.58579). So, that's good. But the other 8-state convolutional code I checked yields a free distance of sqrt(5.17157) but performs worse in AWGN simulations. That makes me believe that the way I tried to compute the free distance is wrong. Any suggestions on how to properly compute the free distance?> Cheers! > SG
Reply by ●November 22, 20132013-11-22
Am 22.11.2013 04:37, schrieb sg:> Am 19.11.2013 16:41, schrieb sg: > >> number of states coding gain (dB) >> ------------------------------------- >> 4 3 >> 8 3.6 >> 16 4.1 >> : : >> >> I ask because I seem to have found an 8-state code that gives me a gain >> of 4.1 dB. So, either someone is wrong (me or the author of the paper) >> or I found an 8-state TCM for 8-PSK that beats publicly known codes. > > It looks like I screwed up the free distance computation. [...]I rephrased my question and included some ASCII art describing the TCM for which my free distance calculation failed: http://dsp.stackexchange.com/questions/12832>> Cheers! >> SG
