santosh.nath@ntlworld.com (santosh nath) wrote in message news:<6afd943a.0308151407.40e864ae@posting.google.com>...> > I am sorry to reject the second job-meaning the second statement > carries little meaning in our statistics. It looks like "job" is well > defined and "and" specifies no toss to be done in the consequitive > tasks i.e PDF is not needed for the "job". >If the job is well defined and an underlying probability space is defined as a space of all jobs then obviously the pdf is a delta function. That's why I need a clarification from the original poster as to what he actually meant when he asked that question.
PDF of an impulse function?
Started by ●August 14, 2003
Reply by ●August 16, 20032003-08-16
Reply by ●August 18, 20032003-08-18
mgodavarti@ditechcom.com (Mahesh Godavarti) wrote in message news:<d4cb12a3.0308160313.15671d33@posting.google.com>...> santosh.nath@ntlworld.com (santosh nath) wrote in message news:<6afd943a.0308151407.40e864ae@posting.google.com>... > > > > I am sorry to reject the second job-meaning the second statement > > carries little meaning in our statistics. It looks like "job" is well > > defined and "and" specifies no toss to be done in the consequitive > > tasks i.e PDF is not needed for the "job". > > > If the job is well defined and an underlying probability space is > defined as a space of all jobs then obviously the pdf is a delta > function. > > That's why I need a clarification from the original poster as to what > he actually meant when he asked that question.Thanks for your email messages and feedback. Sorry about the delay in replying - I had some flu and didn't read the posts for a while. Anyway, I am interested in the PDF of an impulse function (in the time domain) itself. It is possible to approximate the impulse function using the limit of a number of (time domain) functions, provided the area remains constant. One possibility would be a rectangle with height A=1/W and width W (hence the area is AW=1). The impulse function would then be obtained by letting W approach zero (A approach infinity). The PDF for a fixed W would then be A=1/W? As W approach zero then the PDF would be a single value at infinity? (I suppose one would also have to count the increased number of zeros as W approach zero?). Another possibility would be a triangle with height A=1/(W/2) and width W (hence the area is 0.5AW=1). The PDF for a fixed W would then be uniformly distributed from zero to A=2/W? As W approach zero then the PDF would be be uniformly distributed from zero to infinity? The why? of my post goes back to a previous post in comp.dsp with subject "Kurtosis of constant signal" (date 30-07-2003) in which I ask for the kurtosis of a constant signal (which is distributed uniformly in the time domain - not impulsive). The 'opposite' of the constant signal (as far as time localization is concerned) is an impulse signal (with narrow time localization), hence my interest in the PDF (and kurtosis) of this signal. A related question would be whether the impulse signal would be classified as an unimodal distribution? Best regards, Theo
ntvdml@iafrica.com (Theo van der Merwe) wrote in message news:<25af4009.0308180251.2972c6dd@posting.google.com>...> mgodavarti@ditechcom.com (Mahesh Godavarti) wrote in message news:<d4cb12a3.0308160313.15671d33@posting.google.com>... > > santosh.nath@ntlworld.com (santosh nath) wrote in message news:<6afd943a.0308151407.40e864ae@posting.google.com>... > > > > > > I am sorry to reject the second job-meaning the second statement > > > carries little meaning in our statistics. It looks like "job" is well > > > defined and "and" specifies no toss to be done in the consequitive > > > tasks i.e PDF is not needed for the "job". > > > > > If the job is well defined and an underlying probability space is > > defined as a space of all jobs then obviously the pdf is a delta > > function. > > > > That's why I need a clarification from the original poster as to what > > he actually meant when he asked that question. > > Thanks for your email messages and feedback. Sorry about the delay in > replying - I had some flu and didn't read the posts for a while. > > Anyway, I am interested in the PDF of an impulse function (in the time > domain) itself. It is possible to approximate the impulse function > using the limit of a number of (time domain) functions, provided the > area remains constant. > > One possibility would be a rectangle with height A=1/W and width W > (hence the area is AW=1). The impulse function would then be obtained > by letting W approach zero (A approach infinity). The PDF for a fixed > W would then be A=1/W? As W approach zero then the PDF would be a > single value at infinity?Say, if the rectangle is symmetric around origin(which is very common PDF configuartion in calculating quantization noise of fixed point arithmetics, See Oppenheim,Shafer, Chap 9) then is the PDF located at infinity when w approaches zero-clarify!! (I suppose one would also have to count the> increased number of zeros as W approach zero?). > > Another possibility would be a triangle with height A=1/(W/2) and > width W (hence the area is 0.5AW=1). The PDF for a fixed W would then > be uniformly distributed from zero to A=2/W? As W approach zero then > the PDF would be be uniformly distributed from zero to infinity? > > The why? of my post goes back to a previous post in comp.dsp with > subject "Kurtosis of constant signal" (date 30-07-2003) in which I ask > for the kurtosis of a constant signal (which is distributed uniformly > in the time domain - not impulsive).If it is a continous uniform distribution then, excess kurtosis(EK) is = -6/5 and if it discrete distribution then EK = 6/5(n^2+1)/(n^2-1), n should be sufficiently large to appoximate ensemble average to time average(Ergoticity). EK=Kurtosis -3. The 'opposite' of the constant> signal (as far as time localization is concerned) is an impulse signal > (with narrow time localization),Precisely I think it is a sinc function. By the way, if you mean 'opposite' as FT of uniform distribution or a time domain rectangular function. It is not very clear what statistical informtion you try to exploit from a known constant signal. The basic purpose of higher order satistics ( kurtosis is the forth moment) is to evaluate the signal statistics from its higher order moments- It is surprising at your case when the signal does not need any statistical evaluation. Santosh hence my interest in the PDF (and> kurtosis) of this signal. A related question would be whether the > impulse signal would be classified as an unimodal distribution? > > Best regards, > Theo
Reply by ●August 19, 20032003-08-19
santosh.nath@ntlworld.com (santosh nath) wrote in message news:<6afd943a.0308181303.1a617870@posting.google.com>...> ntvdml@iafrica.com (Theo van der Merwe) wrote in message news:<25af4009.0308180251.2972c6dd@posting.google.com>... > > mgodavarti@ditechcom.com (Mahesh Godavarti) wrote in message news:<d4cb12a3.0308160313.15671d33@posting.google.com>... > > > santosh.nath@ntlworld.com (santosh nath) wrote in message news:<6afd943a.0308151407.40e864ae@posting.google.com>... > > > > > > > > I am sorry to reject the second job-meaning the second statement > > > > carries little meaning in our statistics. It looks like "job" is well > > > > defined and "and" specifies no toss to be done in the consequitive > > > > tasks i.e PDF is not needed for the "job". > > > > > > > If the job is well defined and an underlying probability space is > > > defined as a space of all jobs then obviously the pdf is a delta > > > function. > > > > > > That's why I need a clarification from the original poster as to what > > > he actually meant when he asked that question. > > > > Thanks for your email messages and feedback. Sorry about the delay in > > replying - I had some flu and didn't read the posts for a while. > > > > Anyway, I am interested in the PDF of an impulse function (in the time > > domain) itself. It is possible to approximate the impulse function > > using the limit of a number of (time domain) functions, provided the > > area remains constant. > > > > One possibility would be a rectangle with height A=1/W and width W > > (hence the area is AW=1). The impulse function would then be obtained > > by letting W approach zero (A approach infinity). The PDF for a fixed > > W would then be A=1/W? As W approach zero then the PDF would be a > > single value at infinity? > > Say, if the rectangle is symmetric around origin(which is very common > PDF > configuartion in calculating quantization noise of fixed point > arithmetics, > See Oppenheim,Shafer, Chap 9) then is the PDF located at infinity > when w approaches zero-clarify!!The example I mentioned is not to be found in Oppenheim&Schafer (as far as I know, at least). I am also interested in finite wordlength effects, in which a rectangular uniform distribution is frequently used for modelling the round-off error. But the rectangle I describe have nothing to do with the PDF, it is simply an approximation to an impulse in the time domain! I wish to know the PDF of this impulse function.> > (I suppose one would also have to count the > > increased number of zeros as W approach zero?). > > > > Another possibility would be a triangle with height A=1/(W/2) and > > width W (hence the area is 0.5AW=1). The PDF for a fixed W would then > > be uniformly distributed from zero to A=2/W? As W approach zero then > > the PDF would be be uniformly distributed from zero to infinity? > > > > The why? of my post goes back to a previous post in comp.dsp with > > subject "Kurtosis of constant signal" (date 30-07-2003) in which I ask > > for the kurtosis of a constant signal (which is distributed uniformly > > in the time domain - not impulsive). > > If it is a continous uniform distribution then, > excess kurtosis(EK) is = -6/5 > and if it discrete distribution then EK = 6/5(n^2+1)/(n^2-1), n should > be sufficiently large to appoximate ensemble average to time > average(Ergoticity). > > EK=Kurtosis -3. >Thanks for your feedback. I assume you refer to the PDF of the rectangular function (approximating an impulse) above? My original post (subject "Kurtosis of constant signal") refers to the kurtosis of a constant function. In signal processing terms the kurtosis feature is a measure of the 'spikiness' of a signal. Hence I found it rather surprising that the kurtosis of a constant signal would be infinite (refer to [1]). For the constant signal (unimodal distribution) the kurtosis k with the transformation Z=(X-m)/s as defined in [2], with m the mean value and s the standard deviation of the signal, is k=E(z^4)=V(Z^2)+(E(Z^2))^2 =V(Z^2)+1 with (Z^2) the variance of Z^2. For the unimodal distribution x as defined above the standard deviation s would be zero, hence Z would tend to infinity. Hence it is not clear what the variance of Z^2 would be, as the transformation involves division of zero by zero, and further investigation seems to be required (in [1] it is suggested that V(Z^2) approaches infinity). As a high kurtosis value is frequently associated with 'spikiness' or 'impulsive behaviour' in the time domain, a constant signal would seem to have low 'spikiness', hence low kurtosis.> > > The 'opposite' of the constant > > signal (as far as time localization is concerned) is an impulse signal > > (with narrow time localization), > > Precisely I think it is a sinc function. By the way, if you mean > 'opposite' as FT of uniform distribution or a time domain rectangular > function. >Yes, it is true that the sinc function can also (just like the rectangular and triangular signals) approximate an impulse function with the appropriate choice of parameters. The mathematics and PDF might be more complicated, though. With regard to the second question, I am interested in the FT of a time domain rectangular function (approximating an impulse function).> > It is not very clear what statistical informtion you try to exploit > from a known > constant signal. The basic purpose of higher order satistics ( > kurtosis is the forth moment) is to evaluate the signal statistics > from its higher order moments- It is surprising at your case when the > signal does not need any statistical evaluation. >As mentioned above my interest in the higher order statistics, such as kurtosis, is in practical application for fault detection (more specifically detection of faults in roller bearings under dynamic loading conditions). Hence I am interested in signals minimizing and maximizing the kurtosis respectively. Extreme examples from a signal processing framework seems to be the constant signal and the impulse signal (in statistics probably the unimodal distribution and bimodal distributions). What I find rather surprising at present is that the higher order statistics (kurtosis) of common real word signals (such as the constant signal) does not seem to be defined (or at least is open to interpretation)! To an outsider this seeming aversion to reality is rather strange - surely statistics should also give meaningful answers to real word signals? As another example the normal Gaussian distribution with standard deviation s would have a kurtosis of 3 (EK=Kurtosis -3=0). However, if the standard deviation s tends to zero the resulting signal would be very difficult to distinguish from a constant signal. Yet the kurtosis of the constant signal seems to be infinite according to [1]! Do you perhaps have an explanation for this apparent contradiction? [1] R. B. Darlington. Is Kurtosis Really Peakedness? American Statistician, Vol. 24, pp. 19-22, 1970. [2] J. J.A. Moors. The Meaning of Kurtosis: Darlington Reexamined. American Statistician, Vol. 40, pp. 283-284, 1986.> Santosh > > hence my interest in the PDF (and > > kurtosis) of this signal. A related question would be whether the > > impulse signal would be classified as an unimodal distribution? > > > > Best regards, > > Theo
ntvdml@iafrica.com (Theo van der Merwe) wrote in message news:<25af4009.0308190216.580a550@posting.google.com>...> > The example I mentioned is not to be found in Oppenheim&Schafer (as > far as I know, at least). I am also interested in finite wordlength > effects, in which a rectangular uniform distribution is frequently > used for modelling the round-off error. But the rectangle I describe > have nothing to do with the PDF, it is simply an approximation to an > impulse in the time domain! I wish to know the PDF of this impulse > function. >You are getting confused with terminologies. When somebody says the kurtosis of a deterministic time domain signal they are talking about the following: [int_{t = 0}^T t^4 p(t) dt] / [int_{t = 0}^T p(t) dt] This is a signal which exists from t = 0 to T. If p(t) is constant in the interval [0,T] and then you take the above expression to the limit as T \rightarrow \infty then you will see that the Kurtosis is indeed infinity. The Kurtosis used as a measure of peakedness is the statistical Kurtosis E[z^4] where the time domain signal is a stochastic process and the value that the signal can take at a particular time instant is governed by an underlying pdf. For a constant deterministic time domain signal the statistical Kurtosis is zero and not infinity. This should resolve your confusion without you resorting pdfs of an impulse function.
Reply by ●August 20, 20032003-08-20
mgodavarti@ditechcom.com (Mahesh Godavarti) wrote in message news:<d4cb12a3.0308190942.1dab8d6f@posting.google.com>...> ntvdml@iafrica.com (Theo van der Merwe) wrote in message news:<25af4009.0308190216.580a550@posting.google.com>... > > > > The example I mentioned is not to be found in Oppenheim&Schafer (as > > far as I know, at least). I am also interested in finite wordlength > > effects, in which a rectangular uniform distribution is frequently > > used for modelling the round-off error. But the rectangle I describe > > have nothing to do with the PDF, it is simply an approximation to an > > impulse in the time domain! I wish to know the PDF of this impulse > > function. > > > > You are getting confused with terminologies. > > When somebody says the kurtosis of a deterministic time domain signal > they are talking about the following: > > [int_{t = 0}^T t^4 p(t) dt] / [int_{t = 0}^T p(t) dt] > > This is a signal which exists from t = 0 to T. >Do you mean p(t)is a signal that exists from t = 0 to T? To compute the kurtosis the signal p(t) should be zero mean, if I am not mistaken?> If p(t) is constant in the interval [0,T] and then you take the above > expression to the limit as T \rightarrow \infty then you will see that > the Kurtosis is indeed infinity. >Can you please assist me in showing that this is indeed the case? I am quite sure you will have to compute the limit of zero over zero. How do you handle this mathematically?> The Kurtosis used as a measure of peakedness is the statistical > Kurtosis > E[z^4] where the time domain signal is a stochastic process and the > value that the signal can take at a particular time instant is > governed by an underlying pdf. > > For a constant deterministic time domain signal the statistical > Kurtosis is zero and not infinity. >This seems to contradict your earlier statement about the kurtosis approaching infinity? Please show detailed steps in your derivation of this result.> This should resolve your confusion without you resorting pdfs of an > impulse function.I am afraid it does not, as you have apparently only considered the constant signal, and I fail to see how that is related to the impulse signal? Regards, Theo
