Calculate group delay from FFT data
Started by Unknown ●November 23, 2013
I want to analyze audio frequency response and group delay from room
measurements with microphone. Unfortunately I have no luck with the
group delay. Because of the cyclic nature of the phase I never know
whether neighborhood frequency bins have a positive or a negative delay.
Current setup:
- Periodic reference signal with 2^18 samples length.
- Measure N periods on 2^18 samples and add the results.
- Calculate transfer function: complex division component by component
   H[f] = FFT(microphone result[i]) / FFT(reference[i])
- Calculate average over all delay by cross correlation (result is stable).
- Calculate delay per frequency by phase difference of neighborhood
   frequencies
   (arg(H[f]) - arg(H[f-1])) / delta f
- Find the delay value closest to the overall delay.
This last one is the point that is often not unique. The complex room
response makes things complicated. Noise is no major problem. Repeated
measurements will show almost the same values.
Any idea how to improve the result?
Marcel
Unwrap  H(f ) first before taking phase derivative. If the unwrapped phase has large bin- to- bin  jumps that indicate that the unwrap failed, then you need a longer sequence (room impulse response may have a longer duration than your sequence length).
You can also obtain the impulse response directly and then apply a window before the fft.
Bob
Am 23.11.2013 12:25, schrieb Marcel M�ller:
> I want to analyze audio frequency response and group delay from room > measurements with microphone. Unfortunately I have no luck with the > group delay. Because of the cyclic nature of the phase I never know > whether neighborhood frequency bins have a positive or a negative delay. > > Current setup: > - Periodic reference signal with 2^18 samples length.
What's the spectral content of that? Is it mostly white?
> - Measure N periods on 2^18 samples and add the results. > - Calculate transfer function: complex division component by component > H[f] = FFT(microphone result[i]) / FFT(reference[i])
Why don't you simply use P. Welch's method for transfer function estimation? In Octave, you would type [transfer,frequency] = pwelch(reference,recorded,... window,overlap,Nfft,Fs,'trans','whole'); You could use a sine sweep or white noise for the reference signal. Make sure that 'reference' and 'recorded' are somewhat aligned (the more the better), otherwise transfer function estimation will be off. The group delay is simply the derivative of the phase response. For an appropriate large Nfft, you can estimate the derivative using a finite difference. Don't forget to scale this according to the sampling rate and Nfft. After zeroing the coefficients in 'transfer' that could not be determined because the frequencies are not part of the reference signal, you could also directly invoke the ifft function to get an idea of the impulse response.
> - Calculate average over all delay by cross correlation (result is stable). > - Calculate delay per frequency by phase difference of neighborhood > frequencies > (arg(H[f]) - arg(H[f-1])) / delta f > - Find the delay value closest to the overall delay. > > This last one is the point that is often not unique. The complex room > response makes things complicated.
I know. Lots of reflections here and there. Basically, it's a multipath channel. I recently determined my room's impulse response (including speaker+mic) by playing white noise + using pwelch --- just to gen an idea of how reverberant it is. Cheers! SG
you can also get derivatives of phase directly from the real and imag parts *before* calculating the phase with any arg() or arctan() function. you can integrate that derivative to get the unwrapped phase. a line of simple MATLAB code i have used is this: numSamples = length(x); X = fft(x); phase = cumsum([angle(X(1)); angle( X(2:numSamples/2) ./ X(1:numSamples/2-1) ) ]); but it still assumes that the change in phase less than +/- 180 degrees between neighboring bins. i have experimented with modeling the phase as quadratically increasing with frequency (like what you would get with a linear "sweep" or chirp) and it looked something like this diff_diff_phase = unwrap(diff(unwrap(( angle( X(2:numSamples/2) ./ X(1:numSamples/2-1) )))); diff_phase = cumsum([angle(X(2)./X(1)); diff_diff_phase]); phase = cumsum([angle(X(1)); diff_phase]); i think that might work, but i could readily find that old code. i'm still looking.
> If the unwrapped phase has large bin-to-bin jumps that indicate that the unwrap failed, then you need a longer sequence (room impulse response may have a longer duration than your sequence length). > You can also obtain the impulse response directly and then apply a window before the fft.
i kinda would assume doing that in a spectrum analyzer that might display group delay. i remember doing this in the past and being a little dissatisfied with the unwrap() function. i found the code i was looking for. here are snippets: alpha = 1.5/((2*pi)/3 - 4/pi) * 1/((frameSize/2)^2); % Peeters and Rodet would prefer 2.65 instead of 1.5 analWindow = linspace(-(frameSize-1)/2, (frameSize-1)/2, frameSize)'; analWindow = sqrt((frameSize/2)^2*alpha)*exp(-pi*alpha*(analWindow.^2)); % gaussian window ... xWindowed = x(round(n)+1:round(n)+frameSize) .* analWindow; % get and window the input audio frame X = fft(fftshift(xWindowed)); % do the FFT ... mag = log( abs(X(1:frameSize/2+1)) ); [maxmag, maxindex] = max(mag); delta = log( X(2:frameSize/2+1) ./ X(1:frameSize/2) ); realDelta = real(delta); realDeltaDelta = [0; diff(realDelta)]; % pad so that realDeltaDelta lines up with mag imagDelta = unwrap(imag(delta)); phaseDeltaDelta = unwrap(diff(imagDelta)); ... phaseDelta = cumsum([imagDelta(1); phaseDeltaDelta - (2*pi)*round(phaseDeltaDelta(maxindex-1)/(2*pi))]); phaseDelta = phaseDelta - (2*pi)*round((phaseDelta(maxindex)+phaseDelta(maxindex))/(4*pi)); % principal value phase = cumsum([angle(X(1)); phaseDelta]); phase = phase - (2*pi)*round(phase(maxindex)/(2*pi)); % principal value you might have to unwrap some lines of code here, but this is how i dealt with the phase unwrapping problem in MATLAB. but group delay (using finite difference instead of derivative) can be calculated directly from the real and imag parts without needing to deal with phase unwrapping. but i agree with Bob that you gotta unwrap phase *somehow* before applying the derivative to the phase to avoid some nasty spikes in the derivative. i just think skipping phase and calculating its derivative directly from real and imag parts obviates the phase unwrapping problem for the same of group delay. maybe you gotta unwrap a higher derivative, i just don't remember. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
in copying (and modifying to exclude some provincial stuff) i messed up
one line sorta obviously.
analWindow =
window
lines up with mag
	phaseDelta = phaseDelta - (2*pi)*round(phaseDelta(maxindex))/(2*pi));	%
principal value
Hi,
in a multipath environment, group delay (as a single number) is not defined
unambiguously. Results will depend on the algorithm.
Here is a code snippet that determines "the" delay by locating the
crosscorrelation peak between input and output:
http://www.dsprelated.com/showcode/288.php
It achieves subsample resolution by oversampling the signal.
If that's what you want, it's fairly robust, if computationally expensive
and not really smart as an algorithm.
I've got an alternative, phase-based algorithm, here:
http://www.dsprelated.com/showarticle/26.php
It's mainly used for radio frequency amplifiers, not recommended for audio
paths with highly varying (or ill-defined) group delay.
Have a look at the blog for comments on phase unwrapping: Generally, it
fails catastrophically if the channel response has zeros or drops below the
noise floor, a single "bad" FFT bin is enough.
_____________________________
If you want the group delay _vs frequency_,  as on a network analyzer
instrument - it is straightforward to detect discontinuities in GD(f) and
correct the phase to minimize them.
Problem is, it doesn't fail gracefully if the signal gets too noisy.
On 23.11.13 18.59, sg wrote:
> Am 23.11.2013 12:25, schrieb Marcel M�ller: >> I want to analyze audio frequency response and group delay from room >> measurements with microphone. Unfortunately I have no luck with the >> group delay. Because of the cyclic nature of the phase I never know >> whether neighborhood frequency bins have a positive or a negative delay. >> >> Current setup: >> - Periodic reference signal with 2^18 samples length. > > What's the spectral content of that? Is it mostly white?
Mostly yes. The weight function is f^-0,25, something between white and pink noise.
>> - Measure N periods on 2^18 samples and add the results. >> - Calculate transfer function: complex division component by component >> H[f] = FFT(microphone result[i]) / FFT(reference[i]) > > Why don't you simply use P. Welch's method for transfer function > estimation? In Octave, you would type
Never heard of that. As far as I see it is mainly a method to estimate the transfer function from an (theoretically) infinite measurement with a infinite long reference (non-deterministic, e.g. a noise generator). I have no need to go this long way round. My reference is deterministic and contains only energy at frequencies that do very exactly fit to the FFT bins. There is almost no energy at other frequencies. In fact it repeats after the FFT's length. So I get a very good SNR even when environment noise is there.
> The group delay is simply the derivative of the phase response. For an > appropriate large Nfft, you can estimate the derivative using a finite > difference.
I know. I hoped that 5.5 seconds FFT length were enough for this purpose. Maybe I was wrong. It turns out that there were some bugs in the code that reduced the maximum length. I fixed that and retried with 2^19 FFT length and now the delay seems to be reasonably smooth. Only at very low frequencies (below 20 Hz) the response is still jumpy. But I do not care about that. Normally this frequencies are turned off.
> After zeroing the coefficients in 'transfer' that could not be > determined because the frequencies are not part of the reference signal, > you could also directly invoke the ifft function to get an idea of the > impulse response.
I find it quite difficult to see any useful information from an impulse response. But I will check that.
>> - Find the delay value closest to the overall delay. >> >> This last one is the point that is often not unique. The complex room >> response makes things complicated. > > I know. Lots of reflections here and there. Basically, it's a multipath > channel.
Ack. Marcel
On Sat, 23 Nov 2013 19:39:13 -0800, robert bristow-johnson
> > > > >in copying (and modifying to exclude some provincial stuff) i messed up >one line sorta obviously. > > > >alpha = 1.5/((2*pi)/3 - 4/pi) * 1/((frameSize/2)^2); % Peeters and >Rodet would prefer 2.65 instead of 1.5 > >analWindow = linspace(-(frameSize-1)/2, (frameSize-1)/2, frameSize)'; >analWindow = >sqrt((frameSize/2)^2*alpha)*exp(-pi*alpha*(analWindow.^2)); % gaussian >window > >... > xWindowed = x(round(n)+1:round(n)+frameSize) .* analWindow; % get and >window the input audio frame > > X = fft(fftshift(xWindowed)); % do the FFT > >... > mag = log( abs(X(1:frameSize/2+1)) ); > [maxmag, maxindex] = max(mag); > delta = log( X(2:frameSize/2+1) ./ X(1:frameSize/2) ); > realDelta = real(delta); > realDeltaDelta = [0; diff(realDelta)]; % pad so that realDeltaDelta >lines up with mag > imagDelta = unwrap(imag(delta)); > phaseDeltaDelta = unwrap(diff(imagDelta)); >... > phaseDelta = cumsum([imagDelta(1); phaseDeltaDelta - >(2*pi)*round(phaseDeltaDelta(maxindex-1)/(2*pi))]); > phaseDelta = phaseDelta - (2*pi)*round(phaseDelta(maxindex))/(2*pi)); % >principal value > phase = cumsum([angle(X(1)); phaseDelta]); > phase = phase - (2*pi)*round(phase(maxindex)/(2*pi)); % principal value
hehehe this script is too dirty for me to run ;-) Mark
On Sat, 23 Nov 2013 12:25:57 +0100, Marcel M&#4294967295;ller
<news.5.maazl@spamgourmet.org> wrote:
>I want to analyze audio frequency response and group delay from room >measurements with microphone. Unfortunately I have no luck with the >group delay. Because of the cyclic nature of the phase I never know >whether neighborhood frequency bins have a positive or a negative delay. >
I'm not sure if I was looking for a meaningful group delay number (what ever you want that to mean for analysing a room) that I would be setting up the measurement system as you have. I think that I would first use some type of deterministic stimulus which has an IF curve weighted to excite the room modes properly. I would then use some type of decomposition method on the recovered data to break the response into analytic signal components. Mark.
