Curious of using delta-sigma ADCs for vibration control. For instance, the ADS1271 has a sample rate up to 102kHz, but has a group delay of 39 samples. I'm probably missing something, but the group delay seems to make it not viable for use as a controller of up to 10kHz. _____________________________ Posted through www.DSPRelated.com
ADC for vibration controller
Started by ●December 5, 2013
Reply by ●December 5, 20132013-12-05
Reply by ●December 6, 20132013-12-06
On Thu, 05 Dec 2013 09:17:23 -0600, smc123 wrote:> Curious of using delta-sigma ADCs for vibration control. For instance, > the ADS1271 has a sample rate up to 102kHz, but has a group delay of 39 > samples. I'm probably missing something, but the group delay seems to > make it not viable for use as a controller of up to 10kHz.What leads you to thinking that a sigma-delta ADC should be tried? What's the matter with a good modern 16-bit SAR sampling at 100kHz or faster? -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
>Curious of using delta-sigma ADCs for vibration control. For instancethe>ADS1271 has a sample rate up to 102kHz, but has a group delay of 39 >samples. I'm probably missing something, but the group delay seems tmake>it not viable for use as a controller of up to 10kHz. > >_____________________________ >Posted through www.DSPRelated.com >From a math point of view, I would imagine you could account for thi latency in your system transfer function and determine if you still hav proper gain/phase margins........ _____________________________ Posted through www.DSPRelated.com
On Fri, 06 Dec 2013 09:17:57 -0600, jacobfenton wrote:>>Curious of using delta-sigma ADCs for vibration control. For instance, > the >>ADS1271 has a sample rate up to 102kHz, but has a group delay of 39 >>samples. I'm probably missing something, but the group delay seems to > make >>it not viable for use as a controller of up to 10kHz. >> >>_____________________________ >>Posted through www.DSPRelated.com >> >> > From a math point of view, I would imagine you could account for this > latency in your system transfer function and determine if you still have > proper gain/phase margins........If you want to achieve decent loop closure from DC to 10kHz, you couldn't. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
Is it correct to assume that in this application aliasing is not really an issue? If not then as Tim suggests you can't beat a SAR. The sigma-delta part I mentioned has downloadable FIR coefficients so you could load it with an iir- like truncated impulse response for min delay. Bob
Reply by ●December 7, 20132013-12-07
Thank you for the responses. I agree that the 16 bit SAR would be a good choice. I was curious about the delta sigmas because the data sheets for some vibration controllers claim they achieve 120dB dynamic range using delta sigma converters. I can see a control loop of a few hundred Hz with these, but some claim to go to 5kHz. _____________________________ Posted through www.DSPRelated.com
Yes, of you want those kind of dynamic range numbers then sigma-delta is the way to go. If you have control over the decimation filter then you can optimize the filter for low group delay. If you know what you're doing you can co-design the decimation filter along with the overall feedback control filter so that any large peaks in the group delay of the decimator will happen when the loop gain is less than 0 db. The trade- off is that some of the sigma-delta noise might leak through at high frequencies. Whether or not this is a problem depends on the application. Bob
Reply by ●December 8, 20132013-12-08
On Sat, 07 Dec 2013 10:49:09 -0600, smc123 wrote:> Thank you for the responses. I agree that the 16 bit SAR would be a > good choice. I was curious about the delta sigmas because the data > sheets for some vibration controllers claim they achieve 120dB dynamic > range using delta sigma converters. I can see a control loop of a few > hundred Hz with these, but some claim to go to 5kHz.We are talking about controllers for shaker tables, yes? If the plant is well behaved (which mostly means that it's good and linear) then you could use a sigma-delta in an adaptive loop that acquires the table transfer function and then essentially drives it open- loop to get the desired result. This would work particularly well if the user could stand having a calibration step before the "real" shaking, and if what was being promised was that the power spectral density of the shaking, but not necessarily the time-domain waveform, was on the money. You could probably still approximate the time-domain stuff reasonably well, though. I'm kind of dubious about that whole 120dB dynamic range, unless they mean they can do 10dBg (how does one measure vibe in dB, anyway?) at one point, and then -110dBg later on. Even then the shaker table would have to have a very good suspension system -- if the bladder were made out of the wrong material, or if it were aged too much, then the thing may stick in one place when you're trying to achieve the low-amplitude vibe, even if it rattles enthusiastically enough at the high amplitudes. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
Yes, it is in regards to shaker tables. Thank you for the additional insight. I haven't got a specific requirement. I was looking to construct a simple system, but got curious about the descriptions of systems with high resolution claims. _____________________________ Posted through www.DSPRelated.com
