Thanks for the good hints! After debugging the code as suggested, so far I found one bug in my coding: if(bw == 0.0f){ if(swType > 1 && swType < 5){ bw = halfsq2;} // lp/hp else if(swType == 5 || swType == 6){ bw = 0.9f;} // ls/hs else if(swType == 7){ bw = 30.0f;} // notch } else{ <-- BUG (should be done for ls/hs types only) bw /= 12.0f; } This change helped for issues above 70Hz but still issues below it. I just need to debug some more. Juha _____________________________ Posted through www.DSPRelated.com
NaN issue with NOTCH filter
Started by ●December 10, 2013
Reply by ●December 10, 20132013-12-10
