Hello, My question is related to discrete signal using complex exponential for the sake of analysis. Assume fundamental complex exponential is exp((2*pi*)/N)*n). Now I get harmonics of above fundamental frequency frequency such as exp((2*pi)*/N)*nk) for different value of k. Assume for a given value of N, if we have all the samples for the fundamental frequency then would the samples of the harmonics be strictly sub-set of the samples of the fundamental frequency. I think they do and I will do some computation to understand this but wanted a get a view here _____________________________ Posted through www.DSPRelated.com
discrete complex exponential
Started by ●December 22, 2013
Reply by ●December 22, 20132013-12-22
On 12/22/13 11:18 AM, Sharan123 wrote:> Hello, > > My question is related to discrete signal using complex exponential for the > sake of analysis. > > Assume fundamental complex exponential is exp((2*pi*)/N)*n). > Now I get harmonics of above fundamental frequency frequency such as > exp((2*pi)*/N)*nk) for different value of k. >you need a "j" (or whatever you call the imaginary unit) in there. perhaps exp(j*(2*pi*)/N)*n)> Assume for a given value of N, if we have all the samples for the > fundamental frequency then would the samples of the harmonics be strictly > sub-set of the samples of the fundamental frequency. > > I think they do and I will do some computation to understand this but > wanted a get a view here >this sounds a little like an NCO (numerically-controlled oscillator) or DDS (direct digital synthesis) or, in the computer music discipline we might call it additive synthesis using a sinusoidal wavetable. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Reply by ●December 23, 20132013-12-23
On Sun, 22 Dec 2013 10:18:31 -0600, Sharan123 wrote:> Hello, > > My question is related to discrete signal using complex exponential for > the sake of analysis. > > Assume fundamental complex exponential is exp((2*pi*)/N)*n). > Now I get harmonics of above fundamental frequency frequency such as > exp((2*pi)*/N)*nk) for different value of k.As Robert says, you're missing i (or j) in there. As written, that's the exponential that has me staring at a check plot saying "oh damn. I did it again." (You'll start by saying "what the @$%#?")> Assume for a given value of N, if we have all the samples for the > fundamental frequency then would the samples of the harmonics be > strictly sub-set of the samples of the fundamental frequency.As written, yes. In fact, if you look at the detailed development of the FFT, you'll see that this repetition is what is leveraged to reduce the number of computations.> I think they do and I will do some computation to understand this but > wanted a get a view hereI hope that in your opening statement about using the complex exponential for analysis that you are aware that the utility of Fourier techniques only carries you so far; there's a lot of linear signal analysis that is much more profitably done using the z transform. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
>you need a "j" (or whatever you call the imaginary unit) in there.Right. I did miss that ...>As written, yes. In fact, if you look at the detailed development of the>FFT, you'll see that this repetition is what is leveraged to reduce the >number of computations.Thanks. I will look into this in details when I read fast fourier transform. I have not reached that far in my DSP joourney, yet.>I hope that in your opening statement about using the complex exponential>for analysis that you are aware that the utility of Fourier techniques >only carries you so far; there's a lot of linear signal analysis that is >much more profitably done using the z transform.My interest is pure theory of LTI system at the moment. The part I am reading right now deals with representing a periodic signal using complex exponentials, analyze the output for each of these individual signal and then generate the output for the complete input. _____________________________ Posted through www.DSPRelated.com
On Mon, 23 Dec 2013 03:27:23 -0600, Sharan123 wrote:>>you need a "j" (or whatever you call the imaginary unit) in there. > Right. I did miss that ... > >>As written, yes. In fact, if you look at the detailed development of >>the > >>FFT, you'll see that this repetition is what is leveraged to reduce the >>number of computations. > > Thanks. I will look into this in details when I read fast fourier > transform. > I have not reached that far in my DSP joourney, yet. > >>I hope that in your opening statement about using the complex >>exponential > >>for analysis that you are aware that the utility of Fourier techniques >>only carries you so far; there's a lot of linear signal analysis that is >>much more profitably done using the z transform. > > My interest is pure theory of LTI system at the moment. The part I am > reading right now deals with representing a periodic signal using > complex exponentials, analyze the output for each of these individual > signal and then generate the output for the complete input.What book are you studying out of, or are you trying to harvest this stuff piecemeal off the web? You really, really want to do this out of one good book at first -- there are a bunch of valid ways to do this that are each self-consistent but which appear to contradict each other for a surface reading. In a book- length treatment of this material the author should make sure that the material is self-consistent, even if it means going back and editing chapters 1 through N-1 when a contradiction is found in the last chapter. When you scarf it up in pieces off the web, that won't have been done, and until you have a consistent understanding, it can take more time to try to tie everything together than it does to actually absorb the "good stuff". -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Tim Wescott <tim@seemywebsite.really> writes:> On Mon, 23 Dec 2013 03:27:23 -0600, Sharan123 wrote: > >>>you need a "j" (or whatever you call the imaginary unit) in there. >> Right. I did miss that ... >> >>>As written, yes. In fact, if you look at the detailed development of >>>the >> >>>FFT, you'll see that this repetition is what is leveraged to reduce the >>>number of computations. >> >> Thanks. I will look into this in details when I read fast fourier >> transform. >> I have not reached that far in my DSP joourney, yet. >> >>>I hope that in your opening statement about using the complex >>>exponential >> >>>for analysis that you are aware that the utility of Fourier techniques >>>only carries you so far; there's a lot of linear signal analysis that is >>>much more profitably done using the z transform. >> >> My interest is pure theory of LTI system at the moment. The part I am >> reading right now deals with representing a periodic signal using >> complex exponentials, analyze the output for each of these individual >> signal and then generate the output for the complete input. > > What book are you studying out of, or are you trying to harvest this > stuff piecemeal off the web? > > You really, really want to do this out of one good book at first -- there > are a bunch of valid ways to do this that are each self-consistent but > which appear to contradict each other for a surface reading. In a book- > length treatment of this material the author should make sure that the > material is self-consistent, even if it means going back and editing > chapters 1 through N-1 when a contradiction is found in the last > chapter. When you scarf it up in pieces off the web, that won't have > been done, and until you have a consistent understanding, it can take > more time to try to tie everything together than it does to actually > absorb the "good stuff".Hear hear. I was considering a similar post, but I'll just agree with you, Tim. Sharan, my absolute favorite book for this sort of thing is "Signals and Systems." It's a bit dated, but linear system theory, like the laws of physics, doesn't change. @BOOK{signalsandsystems, title = "{Signals and Systems}", author = "{Alan~V.~Oppenheim, Alan~S.~Willsky, with Ian~T.~Young}", publisher = "Prentice Hall", year = "1983"} -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
On Mon, 23 Dec 2013 14:46:22 -0500, Randy Yates wrote:> Tim Wescott <tim@seemywebsite.really> writes: > >> On Mon, 23 Dec 2013 03:27:23 -0600, Sharan123 wrote: >> >>>>you need a "j" (or whatever you call the imaginary unit) in there. >>> Right. I did miss that ... >>> >>>>As written, yes. In fact, if you look at the detailed development of >>>>the >>> >>>>FFT, you'll see that this repetition is what is leveraged to reduce >>>>the number of computations. >>> >>> Thanks. I will look into this in details when I read fast fourier >>> transform. >>> I have not reached that far in my DSP joourney, yet. >>> >>>>I hope that in your opening statement about using the complex >>>>exponential >>> >>>>for analysis that you are aware that the utility of Fourier techniques >>>>only carries you so far; there's a lot of linear signal analysis that >>>>is much more profitably done using the z transform. >>> >>> My interest is pure theory of LTI system at the moment. The part I am >>> reading right now deals with representing a periodic signal using >>> complex exponentials, analyze the output for each of these individual >>> signal and then generate the output for the complete input. >> >> What book are you studying out of, or are you trying to harvest this >> stuff piecemeal off the web? >> >> You really, really want to do this out of one good book at first -- >> there are a bunch of valid ways to do this that are each >> self-consistent but which appear to contradict each other for a surface >> reading. In a book- length treatment of this material the author >> should make sure that the material is self-consistent, even if it means >> going back and editing chapters 1 through N-1 when a contradiction is >> found in the last chapter. When you scarf it up in pieces off the web, >> that won't have been done, and until you have a consistent >> understanding, it can take more time to try to tie everything together >> than it does to actually absorb the "good stuff". > > Hear hear. I was considering a similar post, but I'll just agree with > you, Tim. > > Sharan, my absolute favorite book for this sort of thing is "Signals and > Systems." It's a bit dated, but linear system theory, like the laws of > physics, doesn't change. > > @BOOK{signalsandsystems, > title = "{Signals and Systems}", > author = "{Alan~V.~Oppenheim, Alan~S.~Willsky, with Ian~T.~Young}", > publisher = "Prentice Hall", > year = "1983"}I second Randy's book recommendation. Not only is that book complete and timeless, but most of the veterans on this group (myself included) learned out of some variation of it, so when you ask questions your knowledge pool will be on the same wavelength. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Tim Wescott <tim@seemywebsite.really> wrote:> On Mon, 23 Dec 2013 03:27:23 -0600, Sharan123 wrote:(snip)>> Thanks. I will look into this in details when I read fast fourier >> transform. >> I have not reached that far in my DSP joourney, yet.(snip)> What book are you studying out of, or are you trying to > harvest this stuff piecemeal off the web?> You really, really want to do this out of one good book at > first -- there are a bunch of valid ways to do this that are > each self-consistent but which appear to contradict each other > for a surface reading.(snip) Reminds me of the story about a Quantum Mechanics books written using a left-handed coordinate system. All consistent, but the minus signs will be in different places from other books. It is supposed to be good enough, though, to keep around. In the DSP case, that would be the signs of the exponential in the forward and inverse Fourier transform. -- glen
"Sharan123" <99077@dsprelated> writes:> Hello, > > My question is related to discrete signal using complex exponential for the > sake of analysis. > > Assume fundamental complex exponential is exp((2*pi*)/N)*n). > Now I get harmonics of above fundamental frequency frequency such as > exp((2*pi)*/N)*nk) for different value of k.Not harmonics, no. What you do have are images. (And I'm presuming you've left out a "j" as a few others have already pointed out.)> Assume for a given value of N, if we have all the samples for the > fundamental frequency then would the samples of the harmonics be strictly > sub-set of the samples of the fundamental frequency. > > I think they do and I will do some computation to understand this but > wanted a get a view hereA view? You don't need a view, you need mathematics. Let's say you're sampling at Fs ==> period Ts = 1/Fs a complex sinusoid of frequency f1. Then the baseband signal is exp(j * 2 * pi * f1 * n * Ts) If -Fs/2 <= f1 < Fs/2, then there's nothing you can do to simplify this expression. But let f2 = f1 + k * Fs, where k is an integer. Then exp(j * 2 * pi * f2 * n * Ts) = exp[j * 2 * pi * (f1 + k * Fs) * n * Ts] = exp[(j * 2 * pi * f1 * n * Ts) + (j * 2 * pi * k * Fs * n * Ts)] But Fs * Ts = 1, therefore = exp[(j * 2 * pi * f1 * n * Ts) + (j * 2 * pi * k * n)] = exp[(j * 2 * pi * f1 * n * Ts)] * exp[(j * 2 * pi * k * n)] = exp[(j * 2 * pi * f1 * n * Ts)] -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
Randy Yates <yates@digitalsignallabs.com> writes:> "Sharan123" <99077@dsprelated> writes: > >> Hello, >> >> My question is related to discrete signal using complex exponential for the >> sake of analysis. >> >> Assume fundamental complex exponential is exp((2*pi*)/N)*n). >> Now I get harmonics of above fundamental frequency frequency such as >> exp((2*pi)*/N)*nk) for different value of k. > > Not harmonics, no. What you do have are images. (And I'm presuming > you've left out a "j" as a few others have already pointed out.) > >> Assume for a given value of N, if we have all the samples for the >> fundamental frequency then would the samples of the harmonics be strictly >> sub-set of the samples of the fundamental frequency. >> >> I think they do and I will do some computation to understand this but >> wanted a get a view here > > A view? You don't need a view, you need mathematics. > > Let's say you're sampling at Fs ==> period Ts = 1/Fs a complex > sinusoid of frequency f1. Then the baseband signal is > > exp(j * 2 * pi * f1 * n * Ts) > > If -Fs/2 <= f1 < Fs/2, then there's nothing you can do to simplify > this expression. But let > > f2 = f1 + k * Fs, where k is an integer. > > Then > > exp(j * 2 * pi * f2 * n * Ts) > = exp[j * 2 * pi * (f1 + k * Fs) * n * Ts] > = exp[(j * 2 * pi * f1 * n * Ts) + (j * 2 * pi * k * Fs * n * Ts)] > > But Fs * Ts = 1, therefore > > = exp[(j * 2 * pi * f1 * n * Ts) + (j * 2 * pi * k * n)] > = exp[(j * 2 * pi * f1 * n * Ts)] * exp[(j * 2 * pi * k * n)] > = exp[(j * 2 * pi * f1 * n * Ts)]I should have concluded that this is one way to see why you have images with a discrete-time complex exponential. -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
