An old engineer told me that although in theory you get improvements in demodulating FM via a PLL, in practice you cannot make a VCO which has low enough phase noise to compete with say a Quadrature Detector. This is also the feeling in industry. I would have thought that a VCO could be made near perfect with an FPGA nowadays - or am I missing something?
VCO in a PLL
Started by ●January 12, 2014
Reply by ●January 12, 20142014-01-12
On 1/12/14 3:05 PM, gyansorova@gmail.com wrote:> An old engineer told me that although in theory you get improvements in demodulating FM via a PLL,dunno what that theory is. but i *do* remember that "PLL front end" or something like that was a selling point for stereo receivers back in the 70s. i think the PLL was also part of the AFC function.> in practice you cannot make a VCO which has low enough phase noise to compete with say a Quadrature Detector.dunno. have to see the specific circuit, system, and specs on the parts. i dunno what phase noise is in a VCO. i think of "phase noise" as a term applied to roundoff applied to the index to a table-lookup wavetable oscillator.> This is also the feeling in industry. I would have thought that a VCO could be made near perfect with an FPGA nowadays - or am I missing something?do FPGAs have analog components inside? i generally think of them as all-digital parts. or do you mean the digital counterpart to a VCO, usually called an "NCO"? -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
On 12.1.14 22:27, robert bristow-johnson wrote:> On 1/12/14 3:05 PM, gyansorova@gmail.com wrote: >> An old engineer told me that although in theory you get improvements >> in demodulating FM via a PLL, > > dunno what that theory is. but i *do* remember that "PLL front end" or > something like that was a selling point for stereo receivers back in the > 70s. i think the PLL was also part of the AFC function. >That was a different thing. It was the PLL-based frequency synthesis as the first heterodyne oscillator. -- -Tauno Voipio
On Monday, January 13, 2014 9:27:51 AM UTC+13, robert bristow-johnson wrote:> On 1/12/14 3:05 PM, gyansorova@gmail.com wrote: > > > An old engineer told me that although in theory you get improvements in demodulating FM via a PLL, > > > > dunno what that theory is. but i *do* remember that "PLL front end" or > > something like that was a selling point for stereo receivers back in the > > 70s. i think the PLL was also part of the AFC function. > > > > > in practice you cannot make a VCO which has low enough phase noise to compete with say a Quadrature Detector. > > > > dunno. have to see the specific circuit, system, and specs on the > > parts. i dunno what phase noise is in a VCO. i think of "phase noise" > > as a term applied to roundoff applied to the index to a table-lookup > > wavetable oscillator. > > > > > This is also the feeling in industry. I would have thought that a VCO could be made near perfect with an FPGA nowadays - or am I missing something? > > > > do FPGAs have analog components inside? i generally think of them as > > all-digital parts. or do you mean the digital counterpart to a VCO, > > usually called an "NCO"? > > > > > > -- > > > > r b-j rbj@audioimagination.com > > > > "Imagination is more important than knowledge."A PLL VCO need only be a square wave since the higher harmonics get filtered.
In a pll you typically apply the input to a comparator which feeds the phase detector, and whenever you have a thresholding operation you will sample the noise and this causes aliasing. By contrast , a detector based on tuned LC circuits does not suffer from aliasing, but it typically relies on the open- loop phase or amplitude response as a function of frequency, which is not really a straight line. So the distortion tends to be high but the noise is quite good. There's actually a lot of depth in the design of fm radios which is largely lost these days. I should have studied a bit more before trying to tune the IF stage of my old Advent receiver using the "seat- of- the- pants" method! Bob
A PLL based demodulator can enjoy a few dB of threshold extension. The phase noise of the VCO is not usually an issue. Many analog video satellite receivers used a PLL demodulator for threshold extension. See Gardner and search terms threshold extension. Mark
On Monday, January 13, 2014 11:38:45 AM UTC+13, mako...@yahoo.com wrote:> A PLL based demodulator can enjoy a few dB of threshold extension. The phase noise of the VCO is not usually an issue. > > Many analog video satellite receivers used a PLL demodulator for threshold extension. > > See Gardner and search terms threshold extension. > > Markyes that's the theory and Gardner is an old book. As i said, industry prefers the Quad detector since the noise floor is lower (even though the PLL should give a lower noise floor).
On Sunday, January 12, 2014 6:01:14 PM UTC-5, gyans...@gmail.com wrote:> On Monday, January 13, 2014 11:38:45 AM UTC+13, mako...@yahoo.com wrote: > > > A PLL based demodulator can enjoy a few dB of threshold extension. The phase noise of the VCO is not usually an issue. > > > > > > Many analog video satellite receivers used a PLL demodulator for threshold extension. > > > > > > See Gardner and search terms threshold extension. > > > > > > Mark > > > > yes that's the theory and Gardner is an old book. As i said, industry prefers the Quad detector since the noise floor is lower (even though the PLL should give a lower noise floor).One very significant discriminator between ADC-FPGA and analog IC is cost.
radams2000@gmail.com writes:> In a pll you typically apply the input to a comparator which feeds the > phase detector, and whenever you have a thresholding operation you > will sample the noise and this causes aliasing.Bob, If we were doing everything in the digital domain, couldn't we convert the input into a complex envelope and, assuming the VCO was also complex, do a real phase difference, thus avoiding thresholding? -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
