Hey y'all -- So this is one of those times that my lack of serious math chops is coming round to bite me, and none of my usual books is helping me out. I'm hoping someone has some thoughts. I'm trying to approximate either exp(-1/(n+1)) or 4^(-1/n+1). I can convince myself I don't care which. n is an integer from 1-65535, and the result should be fixed-point fractional, probably U0.18. The function output is always between 0-1, and goes up like a rocket for small n before leveling off to a steady cruise of >0.9 for the rest of the function domain. I'm working in an FPGA, so I've got adds, multiplies, and table lookups from tables of reasonable size (10s of kb) cheap, but other things (divides especially) are expensive. I can throw several clock cycles at the problem if need be. Taylor series attacks seem to fail horribly. I feel like there may be some answer where answers for n in [1,127] gets a direct table lookup, and n in [128,65535] gets some other algorithm, possibly with a table boost. Or somehow taking advantage of the fact that log(1-f(n)) is related to log(n)? Anyone have any thoughts? -- Rob Gaddi, Highland Technology -- www.highlandtechnology.com Email address domain is currently out of order. See above to fix.H
Math is hard
Started by ●January 17, 2014
Reply by ●January 17, 20142014-01-17
In comp.arch.fpga Rob Gaddi <rgaddi@technologyhighland.invalid> wrote: (snip)> I'm trying to approximate either exp(-1/(n+1)) or 4^(-1/n+1). I can > convince myself I don't care which. n is an integer from 1-65535, and > the result should be fixed-point fractional, probably U0.18. The > function output is always between 0-1, and goes up like a rocket for > small n before leveling off to a steady cruise of >0.9 for the rest of > the function domain.You want an 18 bit function of a 16 bit input. Fits into one BRAM on most current, and not so current, FPGAs. Generate all 65536 values and store them in BRAM (ROM in verilog/VHDL terms). -- glen
On Fri, 17 Jan 2014 11:00:06 -0800, Rob Gaddi wrote:> Hey y'all -- > > So this is one of those times that my lack of serious math chops is > coming round to bite me, and none of my usual books is helping me out. > I'm hoping someone has some thoughts. > > I'm trying to approximate either exp(-1/(n+1)) or 4^(-1/n+1). I can > convince myself I don't care which. n is an integer from 1-65535, and > the result should be fixed-point fractional, probably U0.18. The > function output is always between 0-1, and goes up like a rocket for > small n before leveling off to a steady cruise of >0.9 for the rest of > the function domain. > > I'm working in an FPGA, so I've got adds, multiplies, and table lookups > from tables of reasonable size (10s of kb) cheap, but other things > (divides especially) are expensive. I can throw several clock cycles at > the problem if need be. > > Taylor series attacks seem to fail horribly. I feel like there may be > some answer where answers for n in [1,127] gets a direct table lookup, > and n in [128,65535] gets some other algorithm, possibly with a table > boost. Or somehow taking advantage of the fact that log(1-f(n)) is > related to log(n)? > > Anyone have any thoughts?First, instead of Taylor's series, try a best-fit polynomial. I suspect you'll be nearly as disappointed, but you can try. Second, when best-fit polynomials let me down, I look to interpolation. Depending on the problem this ends up being somewhere between linear and cubic. You should be aware that for any one way of going from your tables of values to an interpolation, there's way more than one way of coming up with tables of values, some of which are better than others. Depending on how motivated you are you can either generate splines, or do a least-squares best fit, or find an overall minimax solution (minimize the maximum error). Note that this doesn't change the algorithm in your FPGA -- it just changes the values in your look-up tables. Formulating the problem as linear interpolation and using the known points, or formulating the problem as cubic splines and looking up the algorithm to generate your tables is probably the easiest if you've got the typical engineer's "jack of all trades" way with math. If you want to get fancier, then once you have the problem formulated, least-squares can be done with linear algebra on something like Scilab or Matlab in less time than it takes to lift your finger off the enter key. Getting a minimax solution requires more work both in formulating the problem and in waiting for the optimizer to finish. It also means you have to have a decent optimization software package (which Scilab comes with: I'm not sure if it's native to Matlab or if you have to buy yet another package). -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
On 17/01/14 20:00, Rob Gaddi wrote:> Hey y'all -- > > So this is one of those times that my lack of serious math chops is > coming round to bite me, and none of my usual books is helping me out. > I'm hoping someone has some thoughts. > > I'm trying to approximate either exp(-1/(n+1)) or 4^(-1/n+1). I can > convince myself I don't care which. n is an integer from 1-65535, and > the result should be fixed-point fractional, probably U0.18. The > function output is always between 0-1, and goes up like a rocket for > small n before leveling off to a steady cruise of >0.9 for the rest of > the function domain. > > I'm working in an FPGA, so I've got adds, multiplies, and table lookups > from tables of reasonable size (10s of kb) cheap, but other things > (divides especially) are expensive. I can throw several clock cycles > at the problem if need be. > > Taylor series attacks seem to fail horribly. I feel like there may be > some answer where answers for n in [1,127] gets a direct table lookup, > and n in [128,65535] gets some other algorithm, possibly with a table > boost. Or somehow taking advantage of the fact that log(1-f(n)) is > related to log(n)? > > Anyone have any thoughts? >Taylor series are great for the theory, but very rarely a useful calculation technique in practice. In a case like this, I would first look at using a single table - if you can afford the space, use it for simplicity. Failing that, draw a graph and look at the function as it changes. Also draw some graphs of the derivatives. Any areas of the function where you have low second derivatives are suitable for linear interpolation. Where you have high second derivatives, you need either tightly packed linear interpolation or cubic splines of some sort. There are a few different kinds of cubic splines, depending on things like smooth joins between the parts, least maximal errors, least total square error, etc. But for a limited range function like this, it is not unrealistic to get bit-perfect results if that is what you need. So once you have these graphs, you can look at linear interpolation with a fixed step size, linear interpolation with varying step size, cubic splines of some sort, or dividing the range up and using different techniques for different areas.
On Saturday, January 18, 2014 8:00:06 AM UTC+13, Rob Gaddi wrote:> Hey y'all -- > > > > So this is one of those times that my lack of serious math chops is > > coming round to bite me, and none of my usual books is helping me out. > > I'm hoping someone has some thoughts. > > > > I'm trying to approximate either exp(-1/(n+1)) or 4^(-1/n+1). I can > > convince myself I don't care which. n is an integer from 1-65535, and > > the result should be fixed-point fractional, probably U0.18. The > > function output is always between 0-1, and goes up like a rocket for > > small n before leveling off to a steady cruise of >0.9 for the rest of > > the function domain. > > > > I'm working in an FPGA, so I've got adds, multiplies, and table lookups > > from tables of reasonable size (10s of kb) cheap, but other things > > (divides especially) are expensive. I can throw several clock cycles > > at the problem if need be. > > > > Taylor series attacks seem to fail horribly. I feel like there may be > > some answer where answers for n in [1,127] gets a direct table lookup, > > and n in [128,65535] gets some other algorithm, possibly with a table > > boost. Or somehow taking advantage of the fact that log(1-f(n)) is > > related to log(n)? > > > > Anyone have any thoughts? > > > > -- > > Rob Gaddi, Highland Technology -- www.highlandtechnology.com > > Email address domain is currently out of order. See above to fix.Hexp(x)=1+x+x^2/2+x^3/3!+...
On Friday, January 17, 2014 2:00:06 PM UTC-5, Rob Gaddi wrote:> Hey y'all -- > > > > So this is one of those times that my lack of serious math chops is > > coming round to bite me, and none of my usual books is helping me out. > > I'm hoping someone has some thoughts. > > > > I'm trying to approximate either exp(-1/(n+1)) or 4^(-1/n+1). I can > > convince myself I don't care which. n is an integer from 1-65535, and > > the result should be fixed-point fractional, probably U0.18. The > > function output is always between 0-1, and goes up like a rocket for > > small n before leveling off to a steady cruise of >0.9 for the rest of > > the function domain. > > > > I'm working in an FPGA, so I've got adds, multiplies, and table lookups > > from tables of reasonable size (10s of kb) cheap, but other things > > (divides especially) are expensive. I can throw several clock cycles > > at the problem if need be. > > > > Taylor series attacks seem to fail horribly. I feel like there may be > > some answer where answers for n in [1,127] gets a direct table lookup, > > and n in [128,65535] gets some other algorithm, possibly with a table > > boost. Or somehow taking advantage of the fact that log(1-f(n)) is > > related to log(n)? > > > > Anyone have any thoughts? > > > > -- > > Rob Gaddi, Highland Technology -- www.highlandtechnology.com > > Email address domain is currently out of order. See above to fix.HRob, do you have a misplaced parenthesis(ses)? One case -1/(n+1), the other is -1/n+1 Case one's limit is 1 whereas case 2's limit is 4 for large n. You can scale the exponents such as to change the radix with the effect of change an nth root problem to a power problem. Does that help? For example let B=16 and N in the domain of [1,16] 4^(1-1/N) = 4 * (4^(1/B)) ^ P = 4*(C^P) with C = 4^(1/B) and P = B/N Then 4^(1/B) is a precomputed constant and P=B/N is in [16,1] Food for thought! Clay
David Brown <david.brown@hesbynett.no> writes:> On 17/01/14 20:00, Rob Gaddi wrote: >> Hey y'all -- >> >> So this is one of those times that my lack of serious math chops is >> coming round to bite me, and none of my usual books is helping me out. >> I'm hoping someone has some thoughts. >> >> I'm trying to approximate either exp(-1/(n+1)) or 4^(-1/n+1). I can >> convince myself I don't care which. n is an integer from 1-65535, and >> the result should be fixed-point fractional, probably U0.18. The >> function output is always between 0-1, and goes up like a rocket for >> small n before leveling off to a steady cruise of >0.9 for the rest of >> the function domain. >> >> I'm working in an FPGA, so I've got adds, multiplies, and table lookups >> from tables of reasonable size (10s of kb) cheap, but other things >> (divides especially) are expensive. I can throw several clock cycles >> at the problem if need be. >> >> Taylor series attacks seem to fail horribly. I feel like there may be >> some answer where answers for n in [1,127] gets a direct table lookup, >> and n in [128,65535] gets some other algorithm, possibly with a table >> boost. Or somehow taking advantage of the fact that log(1-f(n)) is >> related to log(n)? >> >> Anyone have any thoughts? >> > > Taylor series are great for the theory, but very rarely a useful > calculation technique in practice. > > In a case like this, I would first look at using a single table - if > you can afford the space, use it for simplicity.Or if a "full" table is too big, consider reducing the table size and interpolating between table entries. -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
In comp.arch.fpga Randy Yates <yates@digitalsignallabs.com> wrote:> David Brown <david.brown@hesbynett.no> writes:(snip)>> In a case like this, I would first look at using a single table - >> if you can afford the space, use it for simplicity.> Or if a "full" table is too big, consider reducing the table size > and interpolating between table entries.Using a table of interpolation values and an adder. -- glen
glen herrmannsfeldt wrote:> In comp.arch.fpga Rob Gaddi <rgaddi@technologyhighland.invalid> wrote: > > (snip) >> I'm trying to approximate either exp(-1/(n+1)) or 4^(-1/n+1). I can >> convince myself I don't care which. n is an integer from 1-65535, and >> the result should be fixed-point fractional, probably U0.18. The >> function output is always between 0-1, and goes up like a rocket for >> small n before leveling off to a steady cruise of >0.9 for the rest of >> the function domain. > > You want an 18 bit function of a 16 bit input. Fits into one BRAM > on most current, and not so current, FPGAs. Generate all 65536 > values and store them in BRAM (ROM in verilog/VHDL terms). > > -- glenGlen, What devices are you using. My measly Xilinx parts only have 36K bits at most per BRAM. I'd need 36 of those to do this table. -- Gabor
In comp.arch.fpga GaborSzakacs <gabor@alacron.com> wrote: (snip, I wrote)>> You want an 18 bit function of a 16 bit input. Fits into one BRAM >> on most current, and not so current, FPGAs. Generate all 65536 >> values and store them in BRAM (ROM in verilog/VHDL terms).(snip)> What devices are you using. My measly Xilinx parts only have > 36K bits at most per BRAM. I'd need 36 of those to do this table.Last time I was working with Xilinx, I only needed tiny RAMs. The BRAMs have 18 inputs and 18 outputs (which I remembered) but it seems to be dual port, two 9 bit addresses (the part I didn't remember). The Spartan-6 devices have between 12 and 268 such BRAMs, though. How many such BRAM can you use? Easiest way to do interpolation is with look-up tables for the interpolation values. Start with a 2Kx18 RAM, so 11 address bits. A second 2Kx18 RAM is addresses by the high bits (six in this case) of the address, and the rest (five bits) from the 16 bit address. That, plus an 18 bit adder, possibly pipelined, will give you linear interpolation on the 2Kx18 values. If that isn't enough, two interpolation RAMS, indexed by combinations of the high and low address bits, will do better. One way to look at the interpolation ROM is that the high bits select a slope, and the low bits select an appropriate multiple of that slope to be added. That is what was done when MOS ROMs were about that size. You can also use the block multipliers, with interpolation tables as inputs. A lot depends on how fast it needs to be, and how many of them you need at the same time. -- glen
