In the matlab filter design filter box, when I click the Quantization button after design a IIR, the freq response seems very different. I cannot find the place where you can configure how many bits for the system? Where do you specifiy that you are using a 16bit or 32bit system? thanks Andrew
IIR quantization
Started by ●August 11, 2003
Reply by ●August 12, 20032003-08-12
Andrew Xiang wrote:> In the matlab filter design filter box, when I click the > Quantization button after design a IIR, the freq response seems > very different. I cannot find the place where you can configure > how many bits for the system? > > Where do you specifiy that you are using a 16bit or 32bit system? > > thanks > AndrewHi Andrew, 1) read the doc: "Working with Quantizers" in the Filter Design Tool Box Section of the Matlab Help. It will tell you all about it. You should not only read it, but you should even have a profound understanding how quantizers work and influence the result if you use them. "A Quick Guide to Quanized Filters Properties" (also a section in the Matlab help) will lead you directly to what you search. 2) If you call "fdatool" in a command window, the "Filter Design & Analysis Tool" opens. Hold your mouse over the icons on the toolbar, and their meaning will appear. One is named: "Set Quantization Parameters". If you activate "Turn quantization on", you see all quantization parameters which you can set/modify. HTH, Bernhard -- before sending to the above email-address: replace deadspam.com by foerstergroup.de
Reply by ●August 14, 20032003-08-14
ahgu@yahoo.com (Andrew Xiang) writes:> In the matlab filter design filter box, when I click the Quantization > button after design a IIR, the freq response seems very different. I > cannot find the place where you can configure how many bits for the > system? > > Where do you specifiy that you are using a 16bit or 32bit system?If you are making an IIR filter for fixed point math, I *strongly* suggest using a lattice implementation. -- Johan KULLSTAM <kullstj-nn@comcast.net> sysengr
Reply by ●August 15, 20032003-08-15
Johan Kullstam wrote:> > If you are making an IIR filter for fixed point math, I *strongly* > suggest using a lattice implementation. >It depends. Lattice structure has generally larger quantization noise artifacts then cascaded direct form biquads. Vladimir Vassilevsky, Ph.D. DSP and Mixed Signal Design Consultant http://www.abvolt.com
