Hi, I've been trying lately to plot an 2D array beamforming diagram, pointing in a direction ele and az as a function of the incident angle. From the textbooks I've managed to understand that to plot the array pattern as a function of the incidence angle then the array pattern value depends on the difference of the sines rather than the difference of the angles themselves. At least for an D array. I've been trying to expand this to an 2D array using u=sin()*cos() and v=sin()*sin() and taking the difference between that and the pointing angle, however, it simply does not seem to work out. The matlab code looks something like this: ele=0; az=0; % array pointing direction lambda=2; w=[1 1 1 1 1]; % lambda / array weights xpos=[1 1 1 1 1]; ypos=[1 2 3 4 5]; % position of elements step=0.01; pattern=[]; pu=xpos*cos(ele); pv=ypos*cos(az); c1=1; fx=-j*2*pi/lambda; for phi=-1:step:1 c2=1; for the=-1:step:1 af=0; k=[sin(0.5*pi*phi)*cos(0.5*pi*the)-sin(ele)*cos(az) sin(0.5*pi*phi*sin(0.5*pi*the)-sin(ele)*sin(az) 0]; for m=1:length(w) af=af+w(m)*exp(fx*k*[pu(m); pv(m); 0]); end; pattern(c1,c2)=af; c2=c2+1; end; c1=c1+1; end; imagesc(abs(pattern)) I guess I'm simply doing an incorrect rotation or adding up something incorrectly in the k=[] line. Could anyone please shed more light and helpe me fix this ? I think if i just replace in the following k=[u-2*ele/pi v-2*az/pi 0]; then I get the plot in the wavenumber domain which seem to be OK, but in a real life situation I want to plot it as a function of the incidence angle. Thank you.
2d array pattern
Started by ●January 28, 2014
Reply by ●January 28, 20142014-01-28
On Tuesday, January 28, 2014 2:37:24 AM UTC-6, mra...@gmail.com wrote:> Hi, > > > > I've been trying lately to plot an 2D array beamforming diagram, pointing in a direction ele and az as a function of the incident angle. From the textbooks I've managed to understand that to plot the array pattern as a function of the incidence angle then the array pattern value depends on the difference of the sines rather than the difference of the angles themselves. At least for an D array. > > I've been trying to expand this to an 2D array using u=sin()*cos() and > > v=sin()*sin() and taking the difference between that and the pointing > > angle, however, it simply does not seem to work out. > > > > The matlab code looks something like this: > > > > ele=0; az=0; % array pointing direction > > lambda=2; w=[1 1 1 1 1]; % lambda / array weights > > xpos=[1 1 1 1 1]; ypos=[1 2 3 4 5]; % position of elements > > step=0.01; > > > > pattern=[]; > > pu=xpos*cos(ele); > > pv=ypos*cos(az); > > c1=1; fx=-j*2*pi/lambda; > > for phi=-1:step:1 > > c2=1; > > for the=-1:step:1 > > af=0; > > k=[sin(0.5*pi*phi)*cos(0.5*pi*the)-sin(ele)*cos(az) sin(0.5*pi*phi*sin(0.5*pi*the)-sin(ele)*sin(az) 0]; > > for m=1:length(w) > > af=af+w(m)*exp(fx*k*[pu(m); pv(m); 0]); > > end; > > pattern(c1,c2)=af; > > c2=c2+1; > > end; > > c1=c1+1; > > end; > > imagesc(abs(pattern)) > > > > I guess I'm simply doing an incorrect rotation or adding up something > > incorrectly in the k=[] line. Could anyone please shed more light and helpe me fix this ? I think if i just replace in the following k=[u-2*ele/pi v-2*az/pi 0]; then I get the plot in the wavenumber domain which seem to be OK, but in a real life situation I want to plot it as > > a function of the incidence angle. > > > > Thank you.What is _the_ in the line beginning with k=[sin(0.5*pi*phi)*cos(0.5*pi*the)-sin(ele)*cos(az)
Reply by ●January 29, 20142014-01-29
On Tuesday, January 28, 2014 11:32:14 PM UTC+1, maury wrote:> On Tuesday, January 28, 2014 2:37:24 AM UTC-6, mra...@gmail.com wrote: > Hi, > > > > I've been trying lately to plot an 2D array beamforming diagram, pointing in a direction ele and az as a function of the incident angle. From the textbooks I've managed to understand that to plot the array pattern as a function of the incidence angle then the array pattern value depends on the difference of the sines rather than the difference of the angles themselves. At least for an D array. > > I've been trying to expand this to an 2D array using u=sin()*cos() and > > v=sin()*sin() and taking the difference between that and the pointing > > angle, however, it simply does not seem to work out. > > > > The matlab code looks something like this: > > > > ele=0; az=0; % array pointing direction > > lambda=2; w=[1 1 1 1 1]; % lambda / array weights > > xpos=[1 1 1 1 1]; ypos=[1 2 3 4 5]; % position of elements > > step=0.01; > > > > pattern=[]; > > pu=xpos*cos(ele); > > pv=ypos*cos(az); > > c1=1; fx=-j*2*pi/lambda; > > for phi=-1:step:1 > > c2=1; > > for the=-1:step:1 > > af=0; > > k=[sin(0.5*pi*phi)*cos(0.5*pi*the)-sin(ele)*cos(az) sin(0.5*pi*phi*sin(0.5*pi*the)-sin(ele)*sin(az) 0]; > > for m=1:length(w) > > af=af+w(m)*exp(fx*k*[pu(m); pv(m); 0]); > > end; > > pattern(c1,c2)=af; > > c2=c2+1; > > end; > > c1=c1+1; > > end; > > imagesc(abs(pattern)) > > > > I guess I'm simply doing an incorrect rotation or adding up something > > incorrectly in the k=[] line. Could anyone please shed more light and helpe me fix this ? I think if i just replace in the following k=[u-2*ele/pi v-2*az/pi 0]; then I get the plot in the wavenumber domain which seem to be OK, but in a real life situation I want to plot it as > > a function of the incidence angle. > > > > Thank you. What is _the_ in the line beginning with k=[sin(0.5*pi*phi)*cos(0.5*pi*the)-sin(ele)*cos(az)Well, the (theta) and phi are the angles I run the algorithm over. So the goal is to cover all phi/theta angles from -1 to 1 (scaled with pi/2).
Well, the (theta) and phi are the angles I run the algorithm over. So the goal is to cover all phi/theta angles from -1 to 1 (scaled with pi/2) and then plot them.
Reply by ●January 31, 20142014-01-31
On Wednesday, January 29, 2014 2:11:43 AM UTC-6, mra...@gmail.com wrote:> Well, the (theta) and phi are the angles I run the algorithm over. So the goal is to cover all phi/theta angles from -1 to 1 (scaled with pi/2) and then plot them.Sorry for the delay, I'm giving exams this week, and am a bit busy. I'm trying to determine what you're trying to do. For example, I use the following Matlab code to plot array patterns. It gives me array gain as a function of azimuth for a linear array. For a 2-dimensional array, the general display is still array gain as a function of azimuth, but the array structure must be accounted for. function [x,y,r,a] = PolarPlot(N,D,S) % Function to plot an phased-array antenna pattern % Gives normalized field pattern in polar and rectangular coordinates % % plot(x,y) gives plot using rectangular coordinates % polar(a,r) gives plot using polar coordinates % % N = number of sources % D = spacing, in wavelengths, of the sources % S = phasing of the sources, in radians (e.g., 90 degree = 1.57) y = []; x = []; cd = 6.28*D; j = 1; a = .01:.01:6.27; ca = cos(a); pf = cd*ca + S; r = sin(N*pf/2)./sin(pf/2); r = abs(r); y = r.*ca; x = r.*sin(a); end From your code, it appears that you are trying to plot 3-dimensional data on a 2-dimensional surface, much like the information displayed in a spectrogram. What do you think the display should look like?
