HI NG! I'm not shure whether this is the appropriate group for my question so please apologise if I'm wrong. I'm searching a free program (preferrably on linux) which I could use to make electronic music with, typically drum&bass. Ideally, I'd like to compose some bass rythm on 4 measures or so and make it loop, and then add some sound samples on top of it. I don't have the samples but the sound bank of my sound card should be ok. Any hints? Thanks, Bernd Haller
What app to create drum&bass music
Started by ●August 10, 2003
Reply by ●August 11, 20032003-08-11
On 10 Aug 2003 11:04:10 -0700, stacko23@my-deja.com (0) wrote:>HI NG! >I'm not shure whether this is the appropriate group for my question so >please apologise if I'm wrong. >I'm searching a free program (preferrably on linux) which I could use >to make electronic music with, typically drum&bass. Ideally, I'd like >to compose some bass rythm on 4 measures or so and make it loop, and >then add some sound samples on top of it. I don't have the samples but >the sound bank of my sound card should be ok. >Any hints? >Thanks, >Bernd HallerGo on google and look up: "trackers" "mod editors" "Impulse Tracker" "ModPlug" "Mad Tracker" Most of these programs are freeware and will let you make complete tunes using just your computer. Hmm, I am re-reading your message and I see that you want this for linux. Most of the trackers run on DOS/Windows or Amiga. Well I guess there's always C-Sound. That runs in linux but it's just a bitch to figure out.
nospam wrote:> > On 10 Aug 2003 11:04:10 -0700, stacko23@my-deja.com (0) wrote: > > >HI NG! > >I'm not shure whether this is the appropriate group for my question so > >please apologise if I'm wrong. > >I'm searching a free program (preferrably on linux) which I could use > >to make electronic music with, typically drum&bass. Ideally, I'd like > >to compose some bass rythm on 4 measures or so and make it loop, and > >then add some sound samples on top of it. I don't have the samples but > >the sound bank of my sound card should be ok. > >Any hints? > >Thanks, > >Bernd Haller > > Go on google and look up: > "trackers" > "mod editors" > "Impulse Tracker" > "ModPlug" > "Mad Tracker" > > Most of these programs are freeware and will let you > make complete tunes using just your computer. > > Hmm, I am re-reading your message and I see that you > want this for linux. Most of the trackers run on > DOS/Windows or Amiga. Well I guess there's always > C-Sound. That runs in linux but it's just a bitch to > figure out.Google is frugal and Wine is fine. Tada! Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●August 12, 20032003-08-12
