Hi, I am evaluating some GSM AMR codec, I needed the following details as I am writing a wrapper for it. #define GSM_PCM_SAMPLES_PER_FRAME #define GSM_SAMPLES_PER_FRAME #define GSM_SAMPLES_PER_SECOND #define GSM_BYTES_PER_FRAME #define GSM_FRAMES_PER_SECOND I am new to codecs and esp. to GSM AMR, it would help me if anyone can explain what is the default bitrate, since its a multi bitrate codec( 4.75 to 12.2kbps)...I am not sure which I should be using... I know that its a 20ms frame with 160 samples... But I need to know things like: 1.PCM input sample size per frame for encoding 2. Output sample size of encoded GSM data 3. frame size 4. No. of frames/second 5. No of bytes/frame.. It will help me if you guys can reply ASAP!! -TIA
Need info on GSM AMR frame size ....
Started by ●August 6, 2003
Reply by ●August 7, 20032003-08-07
> I am evaluating some GSM AMR codec, I needed the following details as > I am writing a wrapper for it. > > #define GSM_PCM_SAMPLES_PER_FRAME160> #define GSM_SAMPLES_PER_FRAME160> #define GSM_SAMPLES_PER_SECOND8000> #define GSM_BYTES_PER_FRAMEthis is variable based on the output rate> #define GSM_FRAMES_PER_SECOND50> > I am new to codecs and esp. to GSM AMR, it would help me if anyone can > explain what is the default bitrate, since its a multi bitrate codec( > 4.75 to 12.2kbps)...I am not sure which I should be using... >There is no "default" bit rate. Appropriate bit-rate is selected based on channel quality. Higher bit rates have higher speech quality, lower bit rates have lower speech quality. What you should be using is totally dependent on your application. If your application requires just a fixed rate, don't bother using AMR. It was not developed for landline applications. EFR may be better suited in such applications.> I know that its a 20ms frame with 160 samples... > But I need to know things like: > 1.PCM input sample size per frame for encoding > 2. Output sample size of encoded GSM dataThis is variable. Take a look at tables in GSM 05.03 and GSM 06.90 (available from ETSI).> 3. frame size > 4. No. of frames/second > 5. No of bytes/frame..See above.> It will help me if you guys can reply ASAP!!I am not sure if you realize that "ASAP" is considered offensive in many places. People are less likely to respond (forget ASAP) to your questions if you use words like this. I would recommend not using it in future postings.
