Jay wrote:> > Ok, > > Perhaps I'm way off in suggesting this but what about a hardware > solution? > > Take your sine wave --> Schmitt trigger to make it into a square wave, > time the rising edges with a fast clock(10MHz or faster) and a deep > counter and you'll get a good idea of the period of the waveform in > counter ticks. > > Take counter value * System_Clock_Period and invert that to get a number > in Hz... > > The faster your system clock (which requires a deep counter) the better > resolution you can get. Even with something as "coarse" as 10MHz, at > 6kHz +/- 100 ns will result in a frequency error of ~3.6 Hz. > > -- Jay.Noise will affect the time of zero crossing. Certain waveforms will count a multiple of the fundamental frequency.* Barring such waveforms, the error due to noise can be reduced by measuring the time for more than one cycle; precision is traded for time (sound familiar?). Jerry _____________________________________ * A square wave with inverted fundamental is a simple example of this. -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Frequency Estimator/ Resolution
Started by ●August 1, 2003
Reply by ●August 11, 20032003-08-11
"L. Bawr" <lba@engineer.com> wrote in message news:<3F2D7F90.9050708@engineer.com>...> Thank you very much eveyrone for the pointers. I really appreciate your > interest in this post. It really helps. Thanks for the link with MATLAB > scripts. I'll take some time to try a couple of them. > Do these technics you guys have mentioned perform well on coherent > signals? I was told that technics similar to MUSIC (called parametric > methods in Fred's link) don't. My signal might contain several coherent > single-frequency components. Any feedback on this point. > TIA. > > L.B.Well, I have never really understood what these "coherent signals" that are supposed to be so problematic, really are. From what I see in the literature, one property of coherent signals is that the covariance matrix somehow becomes rank deficient. I can't really see how this can happen with real-life measured data. In the case of one microphone, I interpret two coherent signals as two sines of the same frequency. In that case, MUSIC will (according to my intuitive understanding) "see" only one component. As long as amplitude or phase is not to be estimated, I think MUSIC will find the frequency. In the case of Direction of Arrival (DoA) estimation, I don't see that coherence becomes a problem at all. If two signals of the same frequency impinges from two different directions, they would separate along the wavenumber dimension. The only problematic situation I can see, is when two signals impognes on the array from the same DoA. Again, both frequency and DoA (but not amplitude or phase) should be possible to estimate. But then, MUSIC and thelikes were never designed to estimate amplitude and phase. Only frequency/DoA. Where did I go wrong? Rune
