What means Zero-Forcing (ZF)? Thanks, Luca
What is Zero-Forcing (ZF)?
Started by ●August 1, 2003
Reply by ●August 1, 20032003-08-01
On Fri, 01 Aug 2003 13:19:06 GMT, Luca <luksaiyan@libero.it> wrote:>What means Zero-Forcing (ZF)?In what context? Best Regards John McCabe To reply by email replace 'nospam' with 'assen'
Luca wrote:> What means Zero-Forcing (ZF)? > > Thanks, > LucaDo you mean this? (ZIF) A kind of socket for integrated circuits. A ZIF socket can be opened and closed by means of a lever or screw. When open, there the chip may be placed in the socket without any pressure at all, the socket is then closed, causing its contacts to grip the pins of the chip. Such sockets are used where chips must be inserted and removed frequently, such as in test equipment. They are more expensive and usually take up more space than conventional IC sockets. ciao Ban
"Luca" <luksaiyan@libero.it> wrote in message news:o4qkiv00q99vonbqqc5fnd2lneks2hhus2@4ax.com...> What means Zero-Forcing (ZF)? > > Thanks, > LucaAre you referring to a zero-forcing equalizer (ZFE) or something else? Cheers Bhaskar
Reply by ●August 2, 20032003-08-02
Excuse me ... :-) I'm referring to the Zero-Forcing decoder or equalizer: what is the algorithm, what is the idea ... what does he work??? :-) Thanks, Luca Il Fri, 1 Aug 2003 09:16:46 -0700, "Bhaskar Thiagarajan" <bhaskart@deja.com> ha scritto:>"Luca" <luksaiyan@libero.it> wrote in message >news:o4qkiv00q99vonbqqc5fnd2lneks2hhus2@4ax.com... >> What means Zero-Forcing (ZF)? >> >> Thanks, >> Luca > >Are you referring to a zero-forcing equalizer (ZFE) or something else? > >Cheers >Bhaskar >
Hello Luca, If the channel has a response H(s), the zero forcing EQ is attempting to match the response 1/H(s). So, the influence of the channel is completely canceled ideally. Obviously this is not the best algorithm, since it optimizes the response. The optimal equalizer should optimize the SNR. Vladimir Vassilevsky, Ph.D. DSP and Mixed Signal Design Consultant http://www.abvolt.com Luca wrote:> > Excuse me ... :-) > > I'm referring to the Zero-Forcing decoder or equalizer: what is the > algorithm, what is the idea ... what does he work??? :-) > > Thanks, > Luca > > Il Fri, 1 Aug 2003 09:16:46 -0700, "Bhaskar Thiagarajan" > <bhaskart@deja.com> ha scritto: > > >"Luca" <luksaiyan@libero.it> wrote in message > >news:o4qkiv00q99vonbqqc5fnd2lneks2hhus2@4ax.com... > >> What means Zero-Forcing (ZF)? > >> > >> Thanks, > >> Luca > > > >Are you referring to a zero-forcing equalizer (ZFE) or something else? > > > >Cheers > >Bhaskar > >
> If the channel has a response H(s), the zero forcing EQ is attempting to > match the response 1/H(s). So, the influence of the channel is > completely canceled ideally. > Obviously this is not the best algorithm, since it optimizes the > response. The optimal equalizer should optimize the SNR.Buongiorno, according to what I remember about this subject, ZF equalizers should never be used since the noise power could become infinite. E.
On Sat, 02 Aug 2003 09:32:54 -0500, Vladimir Vassilevsky <vlv@abvolt.com> wrote:>Hello Luca, > >If the channel has a response H(s), the zero forcing EQ is attempting to >match the response 1/H(s). So, the influence of the channel is >completely canceled ideally. > >Obviously this is not the best algorithm, since it optimizes the >response. The optimal equalizer should optimize the SNR. > >Vladimir Vassilevsky, Ph.D."Best" should be evaluated in the context of the application. If ISI drives the performance of a system (as it often does) then a Zero-Forcing equalizer can be a very good solution, I would even argue that it is sometimes "best". Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
"Vladimir Vassilevsky" <vlv@abvolt.com> wrote in message news:3F2BCB96.8CF92DB5@abvolt.com...> Hello Luca, > > If the channel has a response H(s), the zero forcing EQ is attempting to > match the response 1/H(s). So, the influence of the channel is > completely canceled ideally. > > Obviously this is not the best algorithm, since it optimizes the > response. The optimal equalizer should optimize the SNR. > > Vladimir Vassilevsky, Ph.D. > > DSP and Mixed Signal Design Consultant > > http://www.abvolt.comVladimir, This sounds like an equalizer to get low intersymbol interference. That's a pretty typical application. It appears you're assuming that the pulse waveform into the "system" has zero intersymbol interference. That may not be the case. Then 1/H(s) wouldn't be the solution. Fred
