Gentle People, I am on an embedded firmware project that is (gasp) on a short schedule. The manager has decided to put testing on the back burner and simply get _something_ running as fast as possible without doing any testing further than simple checks in the debugger. This bugs me (pun intended). I wasn't sure why; after all, the manager knows this is a bad idea and is clearly willing to take the risk. I examined myself a little deeper, and I found that I don't just want to write/modify code, but I want to create something that is useful and aesthetically pleasing. An analogy that came to my mind was that this is like "painting in the dark." Can anyone else relate? -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
[Semi-OT] Painting in the Dark
Started by ●March 12, 2014
Reply by ●March 12, 20142014-03-12
On Wed, 12 Mar 2014 12:38:50 -0400 Randy Yates <yates@digitalsignallabs.com> wrote:> Gentle People, > > I am on an embedded firmware project that is (gasp) on a short schedule. > The manager has decided to put testing on the back burner and simply get > _something_ running as fast as possible without doing any testing > further than simple checks in the debugger. > > This bugs me (pun intended). I wasn't sure why; after all, the manager > knows this is a bad idea and is clearly willing to take the risk. > > I examined myself a little deeper, and I found that I don't just want to > write/modify code, but I want to create something that is useful and > aesthetically pleasing. > > An analogy that came to my mind was that this is like "painting in the > dark." > > Can anyone else relate? > -- > Randy Yates > Digital Signal Labs > http://www.digitalsignallabs.comElegant is usually the word I use, but yeah I know exactly what you mean. You want to finish the project up and say, "This is elegant. This not only works, but is well documented and maintainable. If I had to step in on this project with no prior knowledge, I would find it a pleasure." Not, "Well, it looks good from the front." -- Rob Gaddi, Highland Technology -- www.highlandtechnology.com Email address domain is currently out of order. See above to fix.
Rob Gaddi <rgaddi@technologyhighland.invalid> writes:> On Wed, 12 Mar 2014 12:38:50 -0400 > Randy Yates <yates@digitalsignallabs.com> wrote: > >> Gentle People, >> >> I am on an embedded firmware project that is (gasp) on a short schedule. >> The manager has decided to put testing on the back burner and simply get >> _something_ running as fast as possible without doing any testing >> further than simple checks in the debugger. >> >> This bugs me (pun intended). I wasn't sure why; after all, the manager >> knows this is a bad idea and is clearly willing to take the risk. >> >> I examined myself a little deeper, and I found that I don't just want to >> write/modify code, but I want to create something that is useful and >> aesthetically pleasing. >> >> An analogy that came to my mind was that this is like "painting in the >> dark." >> >> Can anyone else relate? >> -- >> Randy Yates >> Digital Signal Labs >> http://www.digitalsignallabs.com > > Elegant is usually the word I use, but yeah I know exactly what you > mean. You want to finish the project up and say, "This is elegant. This > not only works, but is well documented and maintainable. If I had to > step in on this project with no prior knowledge, I would find it a > pleasure."Rob, Yes, those are all things I would _hope_ someone would think of my work. -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
Randy Yates wrote:> Gentle People, > > I am on an embedded firmware project that is (gasp) on a short schedule. > The manager has decided to put testing on the back burner and simply get > _something_ running as fast as possible without doing any testing > further than simple checks in the debugger. > > This bugs me (pun intended). I wasn't sure why; after all, the manager > knows this is a bad idea and is clearly willing to take the risk. >Because that is what they do. At least when I get one of those, it's usually for actual business reasons. "Simple checks in the debugger" however won't cut it - at least borrow the reasonable parts of test first. Depending on how things can be decomposed and how you can get test vectors and test results in and out of the product, my experience is that if you don't tell people you're doing it,they don't notice. I can't really separate coding and basic testing much any more.> I examined myself a little deeper, and I found that I don't just want to > write/modify code, but I want to create something that is useful and > aesthetically pleasing. >He may have realized that defects will be more measurable than testing, and he'll get money for defects that he can't get up front. It's the "think I'll code myself a minivan" theory of project management.> An analogy that came to my mind was that this is like "painting in the > dark." > > Can anyone else relate? >To an extent. -- Les Cargill
Les Cargill <lcargill99@comcast.com> writes:> [...] > Randy Yates wrote: >> I examined myself a little deeper, and I found that I don't just want to >> write/modify code, but I want to create something that is useful and >> aesthetically pleasing. >> > He may have realized that defects will be more measurable than testing, > and he'll get money for defects that he can't get up front.Les, I didn't think of that as a possible reason. Good point. -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
On 3/12/14 7:10 PM, Les Cargill wrote:> Randy Yates wrote: >> Gentle People, >> >> I am on an embedded firmware project that is (gasp) on a short schedule. >> The manager has decided to put testing on the back burner and simply get >> _something_ running as fast as possible without doing any testing >> further than simple checks in the debugger. >> >> This bugs me (pun intended). I wasn't sure why; after all, the manager >> knows this is a bad idea and is clearly willing to take the risk. >> > > Because that is what they do. At least when I get one of those, it's > usually for actual business reasons. > > "Simple checks in the debugger" however won't cut it - at least borrow > the reasonable parts of test first. Depending on how things can be > decomposed and how you can get test vectors and test results in and out > of the product, my experience is that if you don't tell people you're > doing it,they don't notice. > > I can't really separate coding and basic testing much any more. > >> I examined myself a little deeper, and I found that I don't just want to >> write/modify code, but I want to create something that is useful and >> aesthetically pleasing. >> > > He may have realized that defects will be more measurable than testing, > and he'll get money for defects that he can't get up front. > > It's the "think I'll code myself a minivan" theory of > project management. > >> An analogy that came to my mind was that this is like "painting in the >> dark." >> >> Can anyone else relate?Randy, they could be setting you up. if it works without "basic testing" (whatever it is you think they should do), the manager was brilliant pushing this along without that unnecessary crap. if it fails at something or 'nother, and consequently delays the schedule more than planned, who will be held to account? and about elegance of code and design, these guys are just fucking clueless. they do not understand how they hurt the project by cutting corners around "unnecessary refactoring" of the code. if it's not short-term, it doesn't matter. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Reply by ●March 13, 20142014-03-13
On Wed, 12 Mar 2014 10:06:45 -0700, Rob Gaddi wrote:> If I had to > step in on this project with no prior knowledge, I would find it a > pleasure." Not, "Well, it looks good from the front."I like that turn of phrase. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
robert bristow-johnson wrote:> On 3/12/14 7:10 PM, Les Cargill wrote: >> Randy Yates wrote: >>> Gentle People, >>> >>> I am on an embedded firmware project that is (gasp) on a short schedule. >>> The manager has decided to put testing on the back burner and simply get >>> _something_ running as fast as possible without doing any testing >>> further than simple checks in the debugger. >>> >>> This bugs me (pun intended). I wasn't sure why; after all, the manager >>> knows this is a bad idea and is clearly willing to take the risk. >>> >> >> Because that is what they do. At least when I get one of those, it's >> usually for actual business reasons. >> >> "Simple checks in the debugger" however won't cut it - at least borrow >> the reasonable parts of test first. Depending on how things can be >> decomposed and how you can get test vectors and test results in and out >> of the product, my experience is that if you don't tell people you're >> doing it,they don't notice. >> >> I can't really separate coding and basic testing much any more. >> >>> I examined myself a little deeper, and I found that I don't just want to >>> write/modify code, but I want to create something that is useful and >>> aesthetically pleasing. >>> >> >> He may have realized that defects will be more measurable than testing, >> and he'll get money for defects that he can't get up front. >> >> It's the "think I'll code myself a minivan" theory of >> project management. >> >>> An analogy that came to my mind was that this is like "painting in the >>> dark." >>> >>> Can anyone else relate? > > Randy, they could be setting you up. if it works without "basic > testing" (whatever it is you think they should do), the manager was > brilliant pushing this along without that unnecessary crap. if it fails > at something or 'nother, and consequently delays the schedule more than > planned, who will be held to account? >Yeah, there's that. At some point, though, all that bad will breaks down the social fabric of the team and ... well, it's not good. Without trust, it all gets a little "The Good, The Bad and the Ugly." Schumpeter awaits. You can't replace trust with formalism.> and about elegance of code and design, these guys are just fucking > clueless.But clueless by design. > they do not understand how they hurt the project by cutting> corners around "unnecessary refactoring" of the code. if it's not > short-term, it doesn't matter. >-- Les Cargill
Randy Yates wrote:> Gentle People, > > I am on an embedded firmware project that is (gasp) on a short schedule. > The manager has decided to put testing on the back burner and simply get > _something_ running as fast as possible without doing any testing > further than simple checks in the debugger. > > This bugs me (pun intended). I wasn't sure why; after all, the manager > knows this is a bad idea and is clearly willing to take the risk. > > I examined myself a little deeper, and I found that I don't just want to > write/modify code, but I want to create something that is useful and > aesthetically pleasing. > > An analogy that came to my mind was that this is like "painting in the > dark." > > Can anyone else relate?Sure can. He is the manager that gets upset when everything doesn't work? He has a ambiguous requirement list? "If he has so much time to do it over how come he doesn't have time to do it right?" w..
On Wed, 12 Mar 2014 12:38:50 -0400, Randy Yates wrote:> Gentle People, > > I am on an embedded firmware project that is (gasp) on a short schedule. > The manager has decided to put testing on the back burner and simply get > _something_ running as fast as possible without doing any testing > further than simple checks in the debugger. > > This bugs me (pun intended). I wasn't sure why; after all, the manager > knows this is a bad idea and is clearly willing to take the risk. > > I examined myself a little deeper, and I found that I don't just want to > write/modify code, but I want to create something that is useful and > aesthetically pleasing. > > An analogy that came to my mind was that this is like "painting in the > dark." > > Can anyone else relate?I can relate. Unless the application is very small indeed, the "risk" becomes a certainty, and the only thing you do by "saving" time on debugging is to bog your whole project down. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
