"Randy Yates" <yates@ieee.org> wrote in message news:3F272526.DC84F022@ieee.org...> Hi Matt, > > I wasn't clear when I stated "digital signal." What I meant was a signal > that is digitized (or re-digitized) using a simple N-bit quantizer. The > noise is about 6*N dB below the full-scale signal.You were clearer than I was, I think. My concern is that this only holds as long as the input is inside the full scale range of the quantizer. In the S-D modulator, the quantizer is quantizing the feedback, and I can't find a mechanism that limits the feedback to that range, even if the input signal is guaranteed to be so limited.> I believe what you are talking about is the stability of the modulator > due to the feedback loop.Right, but stability isn't quite sufficient. Certain inputs may be amplified by the quantizer enough to drive the feedback outside of the quantizer's input range. At that point, the quantization noise increases with the feedback magnitude, or, more likely, the feedback hits a supply rail and the analysis goes out the window.> That's a whole other subject and one that is > quite complex from what I've gathered. I think they've analyzed first- > and second-order loops analytically for stability, but higher-order > loops are still a shot in the dark (I think). I have some material on > analyzing stability at work - I'd be happy to provide the references when > I get in tomorrow if you're interested.Yes, please ;-)
sigma-delta : unintuitive
Started by ●July 28, 2003
Reply by ●July 30, 20032003-07-30
kbc32@yahoo.com (kbc) wrote in message news:<a382521e.0307280611.7dbc8958@posting.google.com>...> I am finding the sigma-delta adc difficult to understand. > > The only way, i feel, to reduce the quantization noise , > given the bit-resolution , is to sample non-uniformly. > > Is that what happens ? > > shankarNo, that's not what happens. What one does is to oversample by a lot, and use noise-shaping filters. This means that you can move the quantization noise way up in frequency, where it doesn't matter, and then take it out with a simple filter. Look in Jayant and Noll at "A*PCM".
Reply by ●August 1, 20032003-08-01
"Matt Timmermans" <mt0000@sympatico.nospam-remove.ca> wrote in message news:<O3PVa.4088$537.656342@news20.bellglobal.com>...> "Randy Yates" <yates@ieee.org> wrote in message > news:3F272526.DC84F022@ieee.org... > > I have some material on > > analyzing stability at work - I'd be happy to provide the references when > > I get in tomorrow if you're interested. > > Yes, please ;-)Okie dokie, Matt. Here is a list of articles I've collected on delta sigma conversion in general, not just stability. I have the electronic forms so if you email me at randy.yates@sonyericsson.com I can attach and send them to you: 1. "Stability Analysis of the Second Order Sigma Delta Modulator," Philip Steiner and Woodward Yang, Division of Applied Sciences, Harvard; 2. "A Higher Order Topology for Interpolative Modulators for Oversampling A/D Converters," Chao, Nadeem, Lee, and Sodini, IEEE Transactions on Circuits and Systems, vol. 37, no. 3, March 1990. 3. "An Empirical Study of High-Order Single-Bit Delta-Sigma Modulators," Richard Schreier, IEEE Transactions on Circuits and Systems, vol. 40, no. 8, August 1993. 4. "Effective Dithering of Sigma-Delta Modulators," Steven R. Norsworthy, AT&T Bell Laboratories, 5. "A Comparison of Dithered and Chaotic Sigma-Delta Modulators," Chris Dunn and Mark Sandler, JAES, April 1996. 6. "Psychoacoustically Optimal Sigma Delta Modulation," Chris Dunn and Mark Sandler, JAES, April 1997.
