Implement a near brick-wall filter for non-realtime data
Started by Bob April 2, 2014
I'm not a DSP programmer, just an ordinary C++/C# guy. I'd like to
figure a simple way to process a .WAV file for doing very steep
low-pass and high-pass functions. Hopefully very little ripple within
passband. No realtime constraints, and the frequencies would be fixed,
so it probably amounts to implementation of a stock algorithm. There's
no actual spec for slope, as I'm just experimenting.  Just 'steep as
possible' for reasonable coding effort.
I'll read up on whatever is necessary, but it's difficult to tell
where to start. It's probably a very basic problem to most here. Any
leads?  Maybe there's a site that will compute coefficients?
On Tue, 01 Apr 2014 23:11:01 -0400, Bob wrote:
> I'm not a DSP programmer, just an ordinary C++/C# guy. I'd like to > figure a simple way to process a .WAV file for doing very steep low-pass > and high-pass functions. Hopefully very little ripple within passband. > No realtime constraints, and the frequencies would be fixed, > so it probably amounts to implementation of a stock algorithm. There's > no actual spec for slope, as I'm just experimenting. Just 'steep as > possible' for reasonable coding effort. > > I'll read up on whatever is necessary, but it's difficult to tell where > to start. It's probably a very basic problem to most here. Any leads? > Maybe there's a site that will compute coefficients?
In these degenerate times, if the file is short enough you just read the whole damn thing into a computer, do an FFT, window, then do an IFFT. If it's longer than that, then doing some sort of overlapping FFT (which I've never had to do, because I don't work with files that long!) would probably be easiest. It'll sound terrible when you're done, of course. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
On Tue, 01 Apr 2014 22:20:52 -0500, Tim Wescott
<tim@seemywebsite.really> wrote:
>On Tue, 01 Apr 2014 23:11:01 -0400, Bob wrote: > >> I'm not a DSP programmer, just an ordinary C++/C# guy. I'd like to >> figure a simple way to process a .WAV file for doing very steep low-pass >> and high-pass functions. Hopefully very little ripple within passband. >> No realtime constraints, and the frequencies would be fixed, >> so it probably amounts to implementation of a stock algorithm. There's >> no actual spec for slope, as I'm just experimenting. Just 'steep as >> possible' for reasonable coding effort. >> >> I'll read up on whatever is necessary, but it's difficult to tell where >> to start. It's probably a very basic problem to most here. Any leads? >> Maybe there's a site that will compute coefficients? > >In these degenerate times, if the file is short enough you just read the >whole damn thing into a computer, do an FFT, window, then do an IFFT. > >If it's longer than that, then doing some sort of overlapping FFT (which >I've never had to do, because I don't work with files that long!) would >probably be easiest. > >It'll sound terrible when you're done, of course.
I was liking your reply up until that last bit, Tim. Even at 24 bit / 192k sample rate, a 3 minute file should take 'only' about 207MB in RAM, so that approach seems do-able. But I'm not clear on how that would work phase-wise (otherwise FFT would seem to be a great data compression method for music). I do like the idea of infinite attenuation, with no phase shift, if that is practical. (But if so, why are filters still used for audio apps?) So...why would it sound terrible, aside from losing part of the frequency spectrum? Or are you referring to a side-effect of the round trip through FFT/IFFT.
On 2.4.14 08:44, Bob wrote:
> On Tue, 01 Apr 2014 22:20:52 -0500, Tim Wescott > <tim@seemywebsite.really> wrote: > >> On Tue, 01 Apr 2014 23:11:01 -0400, Bob wrote: >> >>> I'm not a DSP programmer, just an ordinary C++/C# guy. I'd like to >>> figure a simple way to process a .WAV file for doing very steep low-pass >>> and high-pass functions. Hopefully very little ripple within passband. >>> No realtime constraints, and the frequencies would be fixed, >>> so it probably amounts to implementation of a stock algorithm. There's >>> no actual spec for slope, as I'm just experimenting. Just 'steep as >>> possible' for reasonable coding effort. >>> >>> I'll read up on whatever is necessary, but it's difficult to tell where >>> to start. It's probably a very basic problem to most here. Any leads? >>> Maybe there's a site that will compute coefficients? >> >> In these degenerate times, if the file is short enough you just read the >> whole damn thing into a computer, do an FFT, window, then do an IFFT. >> >> If it's longer than that, then doing some sort of overlapping FFT (which >> I've never had to do, because I don't work with files that long!) would >> probably be easiest. >> >> It'll sound terrible when you're done, of course. > > I was liking your reply up until that last bit, Tim. > > Even at 24 bit / 192k sample rate, a 3 minute file should take 'only' > about 207MB in RAM, so that approach seems do-able. But I'm not clear > on how that would work phase-wise (otherwise FFT would seem to be a > great data compression method for music). I do like the idea of > infinite attenuation, with no phase shift, if that is practical. (But > if so, why are filters still used for audio apps?) > > So...why would it sound terrible, aside from losing part of the > frequency spectrum? Or are you referring to a side-effect of the > round trip through FFT/IFFT.
You'll start hearing the superposition of the missing harmonics as ringing. To demonstrate, start with the well-known Fourier series of a perfect square wave and look at the sums of the lower harmonics only. The resultants are quite un-square. Another demonstration (though not quite the same as a filter) would be to put the speaker at the end of a length of water pipe and listening at the other end. < nag mode > A different story is the 24/192 audio, see: <http://people.xiph.org/~xiphmont/demo/neil-young.html#toc_1ch>. </ nag mode off > For preserving the time relationships in the filtered signal, consider a constant-delay (symmetric, linear phase) FIR filter. Please note that a constant-delay filter does not change the phase of different frequencies by the same amount. -- Tauno Voipio
Bob wrote:
> I'm not a DSP programmer, just an ordinary C++/C# guy. I'd like to > figure a simple way to process a .WAV file for doing very steep > low-pass and high-pass functions. Hopefully very little ripple within > passband. No realtime constraints, and the frequencies would be fixed, > so it probably amounts to implementation of a stock algorithm. There's > no actual spec for slope, as I'm just experimenting. Just 'steep as > possible' for reasonable coding effort. > > I'll read up on whatever is necessary, but it's difficult to tell > where to start. It's probably a very basic problem to most here. Any > leads? Maybe there's a site that will compute coefficients? >
http://www-users.cs.york.ac.uk/~fisher/mkfilter/trad.html -- Les Cargill
There are a lot of different ways to make filters for digital audio.
Because you're "bucket stomping" the FFT data. The discontinuity in the FFT version of the data will be expressed as artifacts when you reverse FFT it.
> aside from losing part of the > frequency spectrum? Or are you referring to a side-effect of the > round trip through FFT/IFFT. >
Newp. Roundtripping should not be bad with FFTW using 64 bit float samples. I will stop short of saying "it's lossless" but it's not far off from lossless if it is lossy. But perhaps I misremember. -- Les Cargill
On Tue, 01 Apr 2014 23:11:01 -0400, Bob <bob@nope.com>
wrote:
>I'm not a DSP programmer, just an ordinary C++/C# guy. I'd like to >figure a simple way to process a .WAV file for doing very steep >low-pass and high-pass functions. Hopefully very little ripple within >passband. No realtime constraints, and the frequencies would be fixed, >so it probably amounts to implementation of a stock algorithm. There's >no actual spec for slope, as I'm just experimenting. Just 'steep as >possible' for reasonable coding effort. > >I'll read up on whatever is necessary, but it's difficult to tell >where to start. It's probably a very basic problem to most here. Any >leads? Maybe there's a site that will compute coefficients?
I'd vote for a simple FIR filter. If you're not familar with one of these, it is just a "tapped delay line" consisting of a long chain of 1-sample delays, with the output of each stage multiplied by a particular factor for that stage, and all summed together to get a single output sample. Then the next input sample goes in, pushes everything up one position, and repeat. "Simple" here may be misleading, because it can have hundreds of taps, but the design is simple. The tap weights are essentially the impulse response of the filter you want, which in your case is trivial because it's a rectangular function... you don't need to do an (I)FFT to get it. That would make a true "brick wall" filter, but that's not what you want because it would exhibit "Gibbs phenomenon" .. apparent "overshoot" and "ringing". (Those are descriptive terms from resonant-type filters that are applied here because the response sorta looks the same, if you don't notice that the FIR filter seems to also anticipate the next transition.) The cause of Gibbs phenomenon is using a finite set of taps, but using more doesn't help (perhaps surprisingly). But the cure is pretty simple: Instead of using the set of computed tap weights as-is, you apply a window function to taper the ends gently to zero... exactly the same as when windowing an FFT, and you can use the same functions. There are lots of options, but I'd recommend Hann. I use this method to generate band-limited noise from broadband noise (random number generator). I use up to 512 taps, which are really only 256 unique weights mirrored about the center. You can use arrays to index the weights and data points into a multiplier that feeds an accumulator. The delay line can be done with a circular buffer, so you don't really need to move any data along, just keep overwriting the oldest point with the newest, and advance the pointer. The advantage of this over an FFT is that it can handle any length of data easily. A single FFT for an entire WAV file isn't generally practical, and even though you can in principle use multiple smaller FFTs with windowed-overlap-and-add, I think the FIR is simpler. Best regards, Bob Masta DAQARTA v7.50 Data AcQuisition And Real-Time Analysis www.daqarta.com Scope, Spectrum, Spectrogram, Sound Level Meter Frequency Counter, Pitch Track, Pitch-to-MIDI FREE Signal Generator, DaqMusiq generator Science with your sound card!
On Wed, 02 Apr 2014 01:44:41 -0500, Les Cargill wrote:
> Bob wrote: >> On Tue, 01 Apr 2014 22:20:52 -0500, Tim Wescott >> <tim@seemywebsite.really> wrote: >> >>> On Tue, 01 Apr 2014 23:11:01 -0400, Bob wrote: >>> >>>> I'm not a DSP programmer, just an ordinary C++/C# guy. I'd like to >>>> figure a simple way to process a .WAV file for doing very steep >>>> low-pass and high-pass functions. Hopefully very little ripple within >>>> passband. No realtime constraints, and the frequencies would be >>>> fixed, >>>> so it probably amounts to implementation of a stock algorithm. >>>> There's no actual spec for slope, as I'm just experimenting. Just >>>> 'steep as possible' for reasonable coding effort. >>>> >>>> I'll read up on whatever is necessary, but it's difficult to tell >>>> where to start. It's probably a very basic problem to most here. Any >>>> leads? Maybe there's a site that will compute coefficients? >>> >>> In these degenerate times, if the file is short enough you just read >>> the whole damn thing into a computer, do an FFT, window, then do an >>> IFFT. >>> >>> If it's longer than that, then doing some sort of overlapping FFT >>> (which I've never had to do, because I don't work with files that >>> long!) would probably be easiest. >>> >>> It'll sound terrible when you're done, of course. >> >> I was liking your reply up until that last bit, Tim. >> >> Even at 24 bit / 192k sample rate, a 3 minute file should take 'only' >> about 207MB in RAM, so that approach seems do-able. But I'm not clear >> on how that would work phase-wise (otherwise FFT would seem to be a >> great data compression method for music). I do like the idea of >> infinite attenuation, with no phase shift, if that is practical. (But >> if so, why are filters still used for audio apps?) >> >> > There are a lot of different ways to make filters for digital audio. > >> So...why would it sound terrible, > > Because you're "bucket stomping" the FFT data. The discontinuity in the > FFT version of the data will be expressed as artifacts when you reverse > FFT it. > > > >> aside from losing part of the frequency spectrum? Or are you referring >> to a side-effect of the round trip through FFT/IFFT. >> >> > Newp. Roundtripping should not be bad with FFTW using 64 bit float > samples. > > I will stop short of saying "it's lossless" but it's not far off from > lossless if it is lossy. But perhaps I misremember.
Given infinite precision the FFT is lossless. Since the IFFT is basically the FFT with one or two multiplication factors changed, it's lossless, too. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
On Wed, 02 Apr 2014 01:44:10 -0400, Bob wrote:
> On Tue, 01 Apr 2014 22:20:52 -0500, Tim Wescott > <tim@seemywebsite.really> wrote: > >>On Tue, 01 Apr 2014 23:11:01 -0400, Bob wrote: >> >>> I'm not a DSP programmer, just an ordinary C++/C# guy. I'd like to >>> figure a simple way to process a .WAV file for doing very steep >>> low-pass and high-pass functions. Hopefully very little ripple within >>> passband. No realtime constraints, and the frequencies would be fixed, >>> so it probably amounts to implementation of a stock algorithm. There's >>> no actual spec for slope, as I'm just experimenting. Just 'steep as >>> possible' for reasonable coding effort. >>> >>> I'll read up on whatever is necessary, but it's difficult to tell >>> where to start. It's probably a very basic problem to most here. Any >>> leads? Maybe there's a site that will compute coefficients? >> >>In these degenerate times, if the file is short enough you just read the >>whole damn thing into a computer, do an FFT, window, then do an IFFT. >> >>If it's longer than that, then doing some sort of overlapping FFT (which >>I've never had to do, because I don't work with files that long!) would >>probably be easiest. >> >>It'll sound terrible when you're done, of course. > > I was liking your reply
I aim to please
but I'm not God.
> > Even at 24 bit / 192k sample rate, a 3 minute file should take 'only' > about 207MB in RAM, so that approach seems do-able. But I'm not clear on > how that would work phase-wise (otherwise FFT would seem to be a great > data compression method for music). I do like the idea of infinite > attenuation, with no phase shift, if that is practical. (But if so, why > are filters still used for audio apps?) > > So...why would it sound terrible, aside from losing part of the > frequency spectrum? Or are you referring to a side-effect of the round > trip through FFT/IFFT.
First, you need to try it and listen to it. If you just "stomp buckets" (thanks Les) then it'll cause ringing. You can reduce, but not eliminate, the ringing with a shaped window (a flat top with smooth curvy bits down to the floor works well). You may like the result, in which case you're home free. You'll be implementing the "symmetric FIR" filter that Tauno mentioned -- basically, the FFT/IFFT pair will closely emulate any filtering that you can dream up. As to why filters are still used in audio apps -- I'm not an audio guy, but I do know that sometimes those filters are implemented by doing FFT/ IFFT pairs in blocks. There's a whole ocean of knowledge about how you do this in a continuous fashion so the joints between blocks isn't audible, and I've never even stuck my toe in there. So I can't tell you exactly how to do it. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
On Wed, 02 Apr 2014 13:37:41 GMT, N0Spam@daqarta.com (Bob
Masta) wrote:
>"Simple" here may be misleading, because it can have >hundreds of taps, but the design is simple. The tap weights >are essentially the impulse response of the filter you want, >which in your case is trivial because it's a rectangular >function... you don't need to do an (I)FFT to get it.
Here's some working code, in my Daqarta macro language, but hopefully readable. This is macro code I wrote to emulate what I was doing in assembler, to insure I got the identical results for this simple rectangular filter before experimenting with complex shapes. So 'L.0.BandRise' is the rising corner frequency (ie. the low-pass cutoff) in Hz for the Left stream 0 noise band generator. The '65536 * 2' is a scale factor to match the integer-based real-time scheme. Buf1[] is a buffer that holds all the tap weights. The first FIR is the style you see most commonly, with and odd number of taps (an even number, half above and half below zero, which is the odd tap). Here I'm using 255-0-255, for 511 total. Typically, FIR taps are numbered with 0 at the center, so here I've just shifted the index values up so 0 is at index 256. R=L.0.BandRise F=L.0.BandFall W=(F-R) * 2 / SmplRate Buf1[256]=W * 65536 * 2 ;Center tap weight R=R * 2 * pi / SmplRate ;Step, radians/sample F=F * 2 * pi / SmplRate A=R ;Accums start on 1st step B=F UN=1 ;255-0-255 taps (511 total) WHILE.UN=<256 X=(sin(B) - sin(A)) / (UN * pi) * 65536 * 2 Buf1[256+UN]=X ;Upper taps Buf1[256-UN]=X ;Mirrored lower taps A=A+R ;Next accum steps B=B+F UN=UN+1 ;Next tap WEND. Here's a variant with an even number of taps (512), still centered about 0, which is in fact missing: R=L.0.BandRise * 2 * pi / SmplRate ;Step,radians/sample F=L.0.BandFall * 2 * pi / SmplRate A=R/2 ;Accums start at 0.5 step B=F/2 UN=0 ;Tap counter WHILE.UN=<256 ;Taps per side (512 total) X=(sin(B) - sin(A)) / ((UN + 0.5) * pi) * 65536 * 2 Buf1[256+UN]=X ;Upper taps Buf1[255-UN]=X ;Mirrored lower taps A=A+R ;Next accum steps B=B+F UN=UN+1 ;Next tap WEND. Note that this doesn't show the window function which is applied to these later. The Hann window which I recommended is just a raised cosine function, such that it is unity at the 0 tap and tapers to zero at the end taps. Note that all this is done ahead of time and stored, so the actual filtering just pulls the values from the array and multiplies by the passing data points. Hope this helps! Bob Masta DAQARTA v7.50 Data AcQuisition And Real-Time Analysis www.daqarta.com Scope, Spectrum, Spectrogram, Sound Level Meter Frequency Counter, Pitch Track, Pitch-to-MIDI FREE Signal Generator, DaqMusiq generator Science with your sound card!
